Yes Dear, I'll Build You A Better Mousetrap.... - Project Showcase - Page 3 - DIY Chatroom Home Improvement Forum
Old 10-23-2010, 12:58 PM   #31
cocobolo's Avatar
Rewards Points: 5,474
We have used the rotating can and 5 gallon bucket system for some time now. Works well.
But we have a real squirrel problem here. So I like that first trap of yours. About how big is that one? I think I'll need to rig one up here.
Thanks DM.
I knew there had to be a reason you're called Danger MOUSE!
cocobolo is online now   Reply With Quote
Old 10-23-2010, 02:16 PM   #32
the Musigician
DangerMouse's Avatar
You'd be better off building one like the one I made for raccoons.... VERY strong and they cannot get out until YOU let them out. I can draw up the plans if you like.
DM
The Following User Says Thank You to DangerMouse For This Useful Post:
cocobolo (10-23-2010)
Old 10-23-2010, 02:28 PM   #33
cocobolo's Avatar
DM
Is there a pic of the one for the 'coons?
Old 10-23-2010, 02:36 PM   #34
the Musigician
Nope, it got recycled when it got too old.
DM
Old 10-23-2010, 03:15 PM   #35
cocobolo's Avatar
DM
The 'coon or the trap...
In that case, plans would be wonderful...thank you!
Old 10-23-2010, 03:26 PM   #36
the Musigician
The trap, ya big goof.... That darn thing caught coons, rats, cats, dogs and a chicken once too!
You'll need a little talent in carpentry to make one..... do you have any experience building things?
*gbeg*
DM
Old 10-23-2010, 03:32 PM   #37
cocobolo's Avatar
*gbeg*
DM
Uhhhmmm, I'll have to see if I can find something I made...I did make a pencil box in school when I was 11. Does that count?
Old 10-23-2010, 03:34 PM   #38
the Musigician
Oh sure!
If you can glue popsicle sticks together and make THAT, you should have no problems at all building this!
DM
Old 10-23-2010, 03:40 PM   #39
Floor Installer
sam floor's Avatar
Rewards Points: 154
Just put explosives all around your house. Leave your doors open. When the varmints go inside, blow up everything.
sam floor is offline   Reply With Quote
Old 10-23-2010, 03:47 PM   #40
the Musigician
You'll need:
" solder screen.
1", 1", and 2" drywall screws. (galvanized if for outdoor use)
2"X2"s, 2"X4"s
Old door latch from old doorknob.
Catch from same.
4 or 5 screw-in eyehooks.
Smooth steel rod.
" plywood.
Door hinges.
Spring. (trampoline springs work great)
Clothesline.
All of these screwed together make a pretty cool trap. I always prayed I never had a skunk in it.... (luckily I never did)
She took our camera to kid's b-day party, I'll take a shot of what's left later and post it.
I think it's a hen's roost now? ....Might be a rodent cage.....?
DM
Old 10-23-2010, 03:51 PM   #41
the Musigician
This worked well for the neighbors we hated back in the old neighborhood....
DM
Old 10-23-2010, 05:44 PM   #42
cocobolo's Avatar
You'll need:
" solder screen.
2"X2"s, 2"X4"s
Catch from same.
Smooth steel rod.
" plywood.
Door hinges.
Clothesline.
DM
I think I have everything except the 1/4" solder screen. My smooth steel rod is 3/8"...is that a good size? In 10' lengths right now.
I'll get the screen.
Old 10-23-2010, 06:18 PM   #43
the Musigician
That's an OK size.... just be sure it passes easily through the eyehooks.
3/16" rod would do.... easier to bend a loop at one end to tie the line to....
You could hammer the 3/8" flat on an anvil, then drill a hole I guess....?
DM
Old 10-23-2010, 06:23 PM   #44
the Musigician
I had it set up so I could use a kite string to open the door from a distance determined only by the length of the string....
That came in real handy with a coon once.... I think if I build another one new, I'll use some clear plexi all around the outside as well, just in CASE we get a skunk. But they normally don't seem to go for the baits, they like their grubs...... which is a good thing. Po)
DM
Old 10-23-2010, 07:40 PM   #45
cocobolo's Avatar
DM
No skunks here, just mice, very rarely a rat, mink and sea otters. Which I sincerely hope will be too big to get into a trap.
can you build your own drywall lift?....done! DangerMouse Drywall & Plaster 33 04-14-2016 10:04 PM
Build or buy a shed and costs? Piedmont Building & Construction 7 05-19-2009 08:13 PM
Arcade Cabinet build from scratch in MDF and Plexi lokesen Project Showcase 20 10-05-2008 09:50 AM
Sister floor joists or build support wall? Bcoleman6 Building & Construction 3 02-21-2008 02:06 PM
To Build or Not To Build scoby1978 General DIY Discussions 6 05-27-2007 05:39 PM
