Window Project That Turned Into A Bit More - Project Showcase - DIY Chatroom Home Improvement Forum
Old 07-12-2008, 08:11 PM   #1
Rewards Points: 156
Window project that turned into a bit more
Found alot of rot after knocking out the first window. This is the east side of the house and the worst. I had to reframe and replywood around each window. Thought about going to vinyl but we like the wood siding even though we plan on painting over it. Also found 2" insulation in the walls, replaced it with 3", wish I could do the rest of the house. Above the top plate you can also see the celluose insulation I added into the attic last fall, originally only had 3" up in the attic, what a difference this winter and summer going from roughly R 11 to near R 40.
Edit: 10/19/08
This summer went fast! Only 1 more window to go, that will be replaced next spring. I plan on putting in a small front patio deck,residing the rest of the house,a new back patio door and maybe a back patio deck if time permits, all next year. I can now install these windows in a few hours after all the practice
Window project that turned into a bit more-100_1698.jpg   Window project that turned into a bit more-100_1919.jpg   Window project that turned into a bit more-house-east-side-siding.jpg   Window project that turned into a bit more-100_2259.jpg   Window project that turned into a bit more-100_2260.jpg
Last edited by creamaster; 10-19-2008 at 05:47 PM. Reason: Man where did the summer go!
creamaster is offline   Reply With Quote
Old 07-12-2008, 09:46 PM   #2
Registered User
Termite's Avatar
Funny how these projects seem to snowball into bigger projects. If it didn't cost money, it might be fun!
Looks like nice work to me.
Old 07-13-2008, 10:05 AM   #3
Lic. Builder/GC/Remodeler
AtlanticWBConst.'s Avatar
This is an example of why there is no such thing as a "How much to install window price?".
Members keep coming on this site and asking the same thing. (how much to install...)
Every window situation, every home's condition, every construction process, every home's design, extent of rot, etc....is different and can make a job easy, or very, vey complex $$.
BTW: To the poster; job looks good so far. I might suggest that you consider installing housewrap and a flexible membrane fashing over the window-fins on future installations. See diagrams on Pages 8 -15 of this PDF: http://www.milgard.com/_doc/products/aama-2400-02.pdf
Good luck on your future projects, and thanks for posting your project pictures.
- Build Well -
Old 07-16-2008, 04:00 PM   #4
Dorf dude...
shumakerscott's Avatar
Rewards Points: 1,190
Difference in buildings
My God what a difference in structures between your house and mine! I am not knocking your place just making an observation. I think maybe the old way might be better in the long run. The Europeans have no respect for the American way of building. They build it to last and not make a quick buck. I'm caught here riding both sides of the fence. I am leaning towards the European way just because mine has stood for over 100 years. The cost difference is not that much. Build massive or "green" with straw bails. Many options than what is stuffed down our throats as this is a house and you must pay for 30 years $1500 a month. Ok rant over!
Today is only yesterdays tomorrow, Now get to work!
shumakerscott is offline   Reply With Quote
Shrink Film Window Insulation miserlou General DIY Discussions 10 11-24-2008 06:19 AM
Shower in Window jchri66 Remodeling 1 05-27-2008 12:50 PM
Sweating windows big daddy-o General DIY Discussions 15 01-06-2008 02:41 PM
Small project turned into a renovation Logan/Kim Project Showcase 11 11-29-2007 06:29 PM
Replacing aluminum window with a vinyl one? Doug Crf Building & Construction 2 04-23-2007 04:49 AM
