Wheel Chair Ramp To Curved Step - Project Showcase - DIY Chatroom Home Improvement Forum
Old 10-27-2009, 04:35 AM   #1
Tool Geek
PaliBob's Avatar
Rewards Points: 2,160
Wheel Chair Ramp to Curved Step
This is a ramp that is to be temporarily used as a removable assisted wheel chair ramp that I built for an acquaintance. The ramp cannot be used as a self propelled wheel chair ramp because the slope is 7 which is more than the maximum ADA slope of ~ 5 (1:12 slope). In this case the 1:12 slope was not possible because the overall ramp length is limited by the room dimensions.
http://www.mobility-advisor.com/whee...amp-specs.html
The biggest challenge was devising the transition to the curved step and plush carpet.
The solution was to connect the crescent shaped transition piece to the ramp 7
bevel edge, by using pocket screws and Titebond II glue on the bottom side of the ramp.
http://www.amazon.com/Kreg-R3-Pocket.../dp/B000J43A7W
The biggest asset was building the 32" wide ramp (ADA says s/b 36") using 1-1/8" Sturd-I-Floor Plywood. This is tremendously strong subfloor plywood that is popular here in California.
http://shop.mccoys.com/Building%20Ma...nderlay/p.1767
The biggest aid was using a Festool TS55 saw to rip down the 4x8 1-1/8”,plywood sheets. I also built two shorter ramps for outside. The 1-1/8” thickness is only available in tongue and groove panels, But cutting the sheets with the Festool on the guide rails made it easy cutting. Another plus was cutting the bevels with the TS55.
The ramps were covered with Indoor-Outdoor carpeting from HD
Wheel Chair Ramp to Curved Step-ramp1-steps1.jpg   Wheel Chair Ramp to Curved Step-ramp1-steps2.jpg   Wheel Chair Ramp to Curved Step-ramp1-top.jpg   Wheel Chair Ramp to Curved Step-ramp1-btm-1.jpg   Wheel Chair Ramp to Curved Step-ramp1-final.jpg
Disclaimer
& Stay Safe
.....Bob Lavery
Last edited by PaliBob; 10-27-2009 at 06:16 PM. Reason: sp, bad link, added kreg jig
Installing Chair Rail up staircase? tomrash Carpentry 7 07-14-2011 12:42 PM
Unfinished step around wood laminate floors markq Flooring 7 07-17-2009 07:19 PM
tiling outdoor step kristinmcdonald Tiling, ceramics, marble 6 06-08-2009 11:02 PM
Step footing has gaps joshoc Building & Construction 4 05-06-2009 04:11 PM
Don't want to build a wheel chair ramp. Any ideas? jizzle Building & Construction 7 12-22-2008 10:47 AM
