A VERY Big Thank You To All Who Have Helped. Especially Atlantic... - Project Showcase - Page 2 - DIY Chatroom Home Improvement Forum
Old 12-07-2007, 10:31 AM   #16
Incredible basement! This has inspired me to clean mine out and make it into a game room.
powerjack is offline   Reply With Quote
Old 12-10-2007, 05:26 PM   #17
Rewards Points: 1,910
Looks great. But the built in bookcase under the electric panel is a violation of code. Too late now for your project but if anyone else is remodeling keep in mind that the area in front of the electric panel can't be blocked.
Old 09-17-2008, 09:16 AM   #18
They're all fixer-uppers
J187's Avatar
Rewards Points: 516
Does the code give exact proximities? I had a friend of the family who is a home inspector look at that. He said that as long as there is an area that is (I don't remember his exact dimensions) but it was something like 36" high and 6' to ceiling extending out 36" that you could stand in and easily reach and access the panel, then it is ok. Is this not the case?
J187 is offline   Reply With Quote
Old 09-17-2008, 09:48 AM   #19
Registered User
Termite's Avatar
Technically, your friend is incorrect. Jogr is 100% correct. The space 36" out from the panel and 30" wide across the panel is space that is dedicated to electrical. As a building inspector, I encounter this issue with casework pretty often, and have to be reasonable about enforcing it. I sometimes look the other way when small ledges or shallow bookcases are present, provided that easy access to the panel is achieved.
The basement looks great.
Old 09-17-2008, 10:04 AM   #20
Is anyone else not seeing the "after" pictures?
proofer is offline   Reply With Quote
Old 09-17-2008, 10:28 AM   #21
J187's Avatar
Rewards Points: 516
They are there for me. Also, they are on the same server as the others....
Try right clicking where they should be and selecting the "show picture" option from the shortcut menu.
Old 09-17-2008, 10:46 AM   #22
Yep. I already tried that. Well, anyway, I'm sure the pictures show some great improvements.
Old 09-17-2008, 12:47 PM   #23
J187's Avatar
Rewards Points: 516
Can you see this:?
Old 09-18-2008, 05:05 AM   #24
Yes, thanks, I can see it now. What a great basement that is. I sure like that wall color.
Old 09-18-2008, 04:40 PM   #25
J187's Avatar
Rewards Points: 516
Thanks. I think the only time this would become a problem is if someone brought up the code in reference and challenged our interpretation I guess. In other words, there is no problem whatsoever working in the panel from in front of the shelf. Maybe the pictures are decieving but I have no problem accessing all sides of that panel and I'm 5'9". I hope it never becomes an issue, but thanks for your assessment!
Atlantic et al: Soundproofing Ceiling between 1st and 2nd floors BigJimmy Building & Construction 3 10-25-2007 05:35 AM
basement renovation yummy mummy Remodeling 156 05-08-2007 10:15 AM
Do you need to insulate behind soffit? yummy mummy Building & Construction 7 04-10-2007 09:54 PM
Insulation for basement-which R-value should I purchase yummy mummy Building & Construction 6 01-28-2007 06:45 PM
Getting Contractor Assistance, Doing Work Myself Sean Building & Construction 4 12-27-2006 06:13 AM
