Vertical Wooden Blinds - Project Showcase - DIY Chatroom Home Improvement Forum
Old 05-29-2009, 04:45 PM   #1
the Musigician
DangerMouse's Avatar
Vertical wooden blinds
I got these vertical blinds free and after cutting this one down to size and reassembling it, and thinking I hated the fabric slats, realized I REALLY hated the fabric. (it looks like my doctor's office...) Sooo...what about if I do this? (see below) birch slats to match the ceiling? maybe rip some edge "C" trim to cover the edges out of walnut? that should help keep them from warping too, yes? then the birch/walnut curtains will REALLY match the ceiling!!! opinions?
tnkx!
DM
Old 05-29-2009, 05:08 PM   #2
Rewards Points: 372
Cool idea. It'll look great. Can you cover the white track at the top?
gma2rjc is offline   Reply With Quote
Old 05-29-2009, 05:12 PM   #3
the Musigician
i was thinking of paint, but maybe covering it with another slat of oak or walnut WOULD be better? maybe 'scallop' the bottom?
DM
Old 05-29-2009, 05:13 PM   #4
Yes that is a good idea. I think that looks awesome. I would make sure that the same amount of finish coats are on each side of the wood.
jordy3738 is offline   Reply With Quote
Old 05-29-2009, 05:15 PM   #5
the Musigician
satin or gloss?
DM
Old 05-29-2009, 05:21 PM   #6
Rewards Points: 372
Satin. I don't know how it would look if you scallop it. Not sure.
Old 05-29-2009, 05:31 PM   #7
Is that photoshopped or an actual slat?
I would be concerned about warpage over time
But looks good
Old 05-29-2009, 06:14 PM   #8
the Musigician
actual slat.
here's a shot of it now. i wrapped the edges in walnut.
grooved, routed (rounded) and oiled. i kinda like it this way!
think i should do the top awning in walnut or oak to match the casement?
opinions?
DM
Old 05-29-2009, 06:21 PM   #9
the Musigician
i wonder about the bottoms too, think i should mitre in a small piece of walnut there too, or just let it 'hang'? the top will be hidden....
and i think the walnut edges will help prevent warping once glued in place.
DM
Old 05-29-2009, 06:24 PM   #10
Rewards Points: 372
Normally I would say oak to match the casement. But I think the walnut would look better. I think it would balance the two colors.
Old 05-29-2009, 06:27 PM   #11
the Musigician
you don't think the darker walnut awning would make it feel too top heavy?
DM
Old 05-29-2009, 06:49 PM   #12
the Musigician
here's what the ceiling looks like.
someone mentioned i should show it in case someone actually never SAW the ceiling....
i rigged the fan from 3 free, broken ones. works great!
DM
Old 05-29-2009, 06:50 PM   #13
Rewards Points: 372
It might. How hard would it be to put a little piece of each kind of wood up there (one at a time, of course) to compare the two?
Old 05-29-2009, 06:59 PM   #14
Rewards Points: 372
When I look at it with the ceiling, I think the walnut might look better to cover the track. The oak would definitely look good too though.
Old 05-29-2009, 07:03 PM   #15
the Musigician
here's the scalloping in the living room 12' up in the air.
flou. lights inside. this goes across the whole 17 ft'.
DM
Wooden Windows or Plastic? Richuw Windows and Doors 15 04-05-2012 11:16 AM
Max horizontal load on vertical basement support beam supa Building & Construction 8 02-27-2011 02:51 PM
adapting header from vertical blinds to drapes MARTENMAVEN Interior Decorating 0 10-12-2009 11:27 AM
Buy Wooden Blinds Online jimmy rimmer Interior Decorating 7 02-29-2008 05:32 PM
