Ok, I finally got a moment to put some pics together of the progress on this massive project. Mind you, I've got some other projects that have some priority over this one like
repairing the roof leaks,
fixing the busted water line, and some
electrical rehab planning, but once I've made sure the roof no longer leaks on this area and the water lines are approved by the county, it will be full-speed ahead!! In the mean time, here's the latest:
Me and my sexy beer belly tearin' down the remaining sheetrock in the moldy bathroom...
This was a nice touch: mold AND mouse poop found on some of the cieling panels...
A couple of shots of the now-exposed roof beams and plywood showing all the water leakage that's been going on for probably 30 years...
My over-engineered temporary electrical splice to be replaced once the new subpanel is installed...
Here's a good view of the area that used to hold the tub surround. You can see the gap under the back bathroom tub where the ill-fated cat came through and into the front tub to pass on! Of note is all the bent over nails coming from the sole plate. I believe this area was once a doorway and has since been modified (poorly) to be the dividing wall between two showers...
Here I've capped off the original water lines to this bathroom. You can see some of the foam sealing I've done around this area (also just temporary)...
Here's an overall shot of the wall again after I added a piece of insulation using expanding foam as an adhesive...
I have plans to completely re-frame this wall but I'm going to keep these studs in place during most of the work so I won't lose the support of the cement board that's holding the tile on the back bathroom in the process. More on that to come in the weeks ahead!
And finally here's an overall shot of the entire area. You can see how much we have lost in our kitchen in the process!! My wife sure can't wait for this project to be OVER!!
So, wish us all luck!!
