Go Back   DIY Chatroom - DIY Home Improvement Forum > DIY Repair > Project Showcase
Old 02-24-2011, 09:15 PM   #1
Learning by Doing
Leah Frances's Avatar
Uncovering Hidden Windows in my guest room
My latest project is my large guest room. We knew that one of the walls was 'false' and concealing a pair of windows (you could see the windows from outside).
Demolition - I rented a dumpster and hucked all the debris out the window - very satisfying. Here's a pic of halfway through the demo.
Peeled off three layers of wallpaper. They conveniently PAINTED between the first and second layer making it quite a PITA to scrape.
They also PAINTED the hidden windows shut from the outside! You can easily see the paint on the upper sash. It took a bit of patient work to remove the sashes. I kept the interlocking weather-stripping in place because it was in good shape and engaged with the sashes nicely.
I removed all the old paint, sanded and rehabbed the sashes. This involved re-attaching loose muntins and re-squaring a corner or two. The upper sash is still raked out of square by 1/4 inch, but it opens and lowers nicely in the window. The lower sash is perfectly square and also performs nicely.
If I could only remember to THINK about what I was doing before I did it.
Leah Frances is offline   Reply With Quote
Old 02-24-2011, 09:24 PM   #2
Learning by Doing
I planned to keep the old unbroken glass (3 out of 4 panes were in good shape). It wasn't 'wavy' or particularly old, but I hate throwing things away. It proved to be such a time waster to scrape all the old paint that I elected to replace it with new glass - two trips to lowes later I had a nice dry fit.
I set the points and tried my hand at glazing! I've never done this before, but I read a book and watched a video on youtube . After about 45 minutes I got the hang of it and could run a straight line.
Couldn't get a good glazing pic, but I'll post some tomorrow.
The Following 2 Users Say Thank You to Leah Frances For This Useful Post:
oh'mike (02-26-2011), Tom Struble (02-24-2011)
Room Air Purifier - which is best? nhart Appliances 16 12-07-2012 07:00 AM
Any restitution for VERY late windows? msbriggs Building & Construction 21 10-05-2010 07:25 AM
uneven heat: testing ceiling radiant heat /finding cables/fix cables martinradiant Electrical 1 10-03-2010 09:22 PM
replacing windows.. modifying a rough opening by less than 2 inches? diy'er on LI Building & Construction 14 09-18-2010 07:43 PM
new windows juliejules4 HVAC 12 12-06-2006 02:37 PM
