TV Center Update - Project Showcase - DIY Chatroom Home Improvement Forum
Old 01-25-2015, 12:16 PM   #1
Rewards Points: 698
TV Center Update
I recently bought a new widescreen. Its the same screen-size as the old, but its a few inches narrower in width, and about 8" shorter. So I made a riser for my TV Center, about 7" tall, so it fits better in the hole in the unit. Made the riser mostly with 20mm MDF, and covered with gloss black laminate on the outside, and gloss black paint on areas that are hidden. But I made the riser two-piece with drawer slides, so I can pull out the TV to get to the cables or back of the TV. Two L brackets hold the riser to the back of the TV center so it cant tip when the TV is pulled full out. I used to dread having to get to the back of my TV. Had to empty out the cabinets and then man-handle them away from the wall.
I didn't originally make the entertainment center myself, but about 8-10 years ago, I did pretty much rebuild the whole think. It was originally sized to fit a 4:3 tube TV. When I got my first widescreen, I rebuilt it to the sizes you see here (about a foot wider). The only thing left of the original is the two side plates.
SPS-1 is offline   Reply With Quote
Old 01-25-2015, 01:54 PM   #2
nap
You talking to me?
nap's Avatar
Rewards Points: 2,538
TV Center Update
Looks great but a couple questions, concerns;
Is it still stable with the tv drawer pulled out? It wouid be a shame for it to tip over due to an imbalance.
Have you incorporated any means to hold the tv steady so when sliding it in and out there is no chance of it tipping ?
Old 01-25-2015, 03:46 PM   #3
Rewards Points: 698
TV Center Update
The entertainment center easily weighs a few hundred pounds (that's a big reason I had so much trouble moving it to get to the back of the TV). Its not even close to tipping when the TV is slid forward. The TV itself is only 31 pounds.
Jacking up house, full length joists raised beam off of center colums. Suggestions? slowjo Building & Construction 9 09-16-2014 07:56 AM
Load Center For Barn swiederin Electrical 2 02-05-2014 01:29 PM
House on Crawl Space - Sagging Center Beam - Need Advise stevenrossi Building & Construction 8 12-23-2012 12:35 PM
Can you drill Load Center? Ralph III Electrical 18 02-24-2012 01:24 PM
Space between mounted TV and entertainment Center BeaglesBuddy Interior Decorating 3 05-31-2011 12:09 PM
