From Trees To Retirement Home. - Project Showcase - DIY Chatroom Home Improvement Forum
Old 02-27-2015, 02:48 PM   #1
Rewards Points: 123
From trees to retirement home.
Here's a quick summary of my retirement home build.
I retired at 62 with no pension, just S.S.
Since our current house was paid for, I figured that I could supplement S.S. by selling our current house after building a house on the cheap by myself.
Realizing the truth of the old adage, 'cheap, easy, good, pick any two', I decided to go with cheap and good.
Though I knew that the 'easy' was out, what I didn't know was that it would be 6 years before I was living in it.
The site is 24 acres on a rocky ridge with a valley on one side and a mountain on the other.
The size of the house is 24'x48' with porches front and rear.
It has an open D.R., L.R.,Kit., 2 bedrooms, bath, pantry and utility room.
I managed to do all the work myself except for drilling the well and digging the septic hole and leach trenches.
I started by finding the highest point of ground and clearing out for the house spot.
I didn't have a tractor at that time, just a Yamaha 4 wheeler.
So, I built a log arch to use with the Yahama to get the logs to the mill.
Then I set up my chainsaw mill (Swedish Logosol), and begin milling the lumber.
The saw is a Husky 395XL that I did a muffler mod on.
This pic is a different location where I first tried out the mill.
(more to come...)
Arky217 is offline   Reply With Quote
Old 02-27-2015, 02:53 PM   #2
Rewards Points: 123
I started milling for the house with the posts. They are 6”x6”x(28”to34”long).
They are milled from the red heart of cedar trees.
Old 02-27-2015, 02:58 PM   #3
Rewards Points: 123
First cedar cant milled; fresh milled cedar sure smells good.
Old 02-27-2015, 03:08 PM   #4
kwikfishron's Avatar
Rewards Points: 2,626
Very nice Arky217, I'm looking forward to fallowing this.
kwikfishron is online now   Reply With Quote
Old 02-27-2015, 04:23 PM   #5
Rewards Points: 123
Then I begin milling the 6”x8”x12' beams since they take the longest to dry.
They are milled (as is the rest of the lumber) from yellow pine.
After the beams, I milled the rest of the lumber (joists, plates, studs, braces, truss members, etc).
Here's a pic bringing in an 8' log.
It also shows the milled lumber stacks; they are stickered and covered to air dry.
Old 02-27-2015, 04:26 PM   #6
Rewards Points: 123
Here's another pic bringing in a 16' log.
The log arch is extendable to accommodate the longer logs.
Old 02-27-2015, 04:29 PM   #7
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 4,524
I am so stoked about watching this thread develop as well.
Old 02-27-2015, 04:32 PM   #8
BradMM's Avatar
Rewards Points: 44
What kind of mill???
I'm replying to get the email notification of updates! Awesome!
BradMM is offline   Reply With Quote
Old 02-27-2015, 04:39 PM   #9
Remodel and New Build GC
MTN REMODEL LLC's Avatar
Rewards Points: 2,978
me too
MTN REMODEL LLC is offline   Reply With Quote
Old 02-27-2015, 04:47 PM   #10
Rewards Points: 123
Here's a log ready to load on the mill.
Same log after I loaded it via home made loading device.
Same log again, ready to mill.
The Following User Says Thank You to Arky217 For This Useful Post:
BigJim (02-27-2015)
Old 02-27-2015, 04:54 PM   #11
Rewards Points: 123
Another view of the lumber stacks.
Here's a cant (that's a log with all the slabs milled off).
Got a lot of truss members from this log.
Old 02-27-2015, 05:00 PM   #12
Rewards Points: 123
Some of the logs were right at the capacity of the mill.
And had to be notched a little.
Old 02-27-2015, 05:04 PM   #13
Rewards Points: 123
Here's Mr. logger...
And of course, Mrs. logger...
The Following 2 Users Say Thank You to Arky217 For This Useful Post:
kwikfishron (02-27-2015), oh'mike (03-24-2015)
Old 02-27-2015, 05:07 PM   #14
Rewards Points: 123
Now for a pic of the finished product.
Wife said outhouse was too far away, so I put the facility just outside the door.
The frying pan is bear protection while on the potty.
And of course, just couldn't do without DISH.
Old 02-27-2015, 05:11 PM   #15
Rewards Points: 123
Well, as it turns out, I did a little better job than than the previous pic
as the following posts will show....
Since the ground is really solid, I decided to go with a pier and post foundation.
I dug the pier holes by hand, having to use a rock bar after the first couple of inches.
They are 10” dia. at the top, 16” at the bottom and 18” deep.
Each pier has a 5/8” rebar embedded
with an anchor cross piece welded to the bottom.
The top of the rebar has a plate welded through
which the posts and braces are anchored.
There are 4 rows of piers (8' joist span) spaced 6' apart,
for a total of 36.
Finally finished the piers (what a chore).
Need home plans for a simple barn home! RUMBLON General DIY Discussions 0 06-02-2011 03:05 PM
mobile home service to bond or not to bond rikmac Electrical 35 03-17-2010 03:47 PM
Owning a home (not a mobile home) on leased land? Badfish740 Off Topic 11 03-30-2008 09:34 AM
A facelift for your home Grumpy Remodeling 0 07-07-2004 07:43 PM
