Tool Organizer - Project Showcase - DIY Chatroom Home Improvement Forum
Old 01-25-2014, 11:42 PM   #1
Rewards Points: 170
tool organizer
What do you think of this tool organizer i built? It was super easy to build. The top is slanted to store other items but you cant see it because it is behind a light fixture at the moment
diyer111 is offline   Reply With Quote
The Following 5 Users Say Thank You to diyer111 For This Useful Post:
bbo (01-26-2014), BigJim (02-18-2014), dezandseth (02-07-2014), gma2rjc (01-26-2014), Gymschu (01-26-2014)
Old 01-26-2014, 07:46 AM   #2
Very nice!!!
Whenever i see stuff like this I get inspired to do it... but then never seem to get around to it.
nice job!!!
quantumkev is offline   Reply With Quote
Old 01-26-2014, 09:21 AM   #3
Rewards Points: 170
Originally Posted by quantumkev View Post
Very nice!!!
nice job!!!
Haha thats very true
Old 01-26-2014, 12:11 PM   #4
Rewards Points: 2,072
I like orderly garages.
That's a lot of drills.
Startingover is offline   Reply With Quote
Old 01-26-2014, 12:14 PM   #5
Rewards Points: 6,652
So how much for you to make and sale one for those of us, that would like one? I would have Dado'd where the shelves are, so that they are not just being held in by screws or nails.
Old 01-26-2014, 01:04 PM   #6
Rewards Points: 170
I would have liked to dado it as well but i did not have the proper tools for it. It is 30" wide and the shelves are very sturdy actually, since the center of the shelf landed on a stud so i was able to fasten it securly, but it was sturdy even without fastening it. The cost was about $35.00 for the select grade pine since i also do not have a planner so i couldn use cheaper boards. I countersunk the screws and dowled them in the shelves so it looks alittle nicer. I also drilled a hole out the side for the cords from the chargers to go through. The top is also at an angle so when i rearange my shop it can be used as additional storage since now it rests behind a shop light.
The Following User Says Thank You to diyer111 For This Useful Post:
oh'mike (02-19-2014)
Old 01-26-2014, 01:15 PM   #7
Rewards Points: 170
The nice thing about this organizer is that it fits more than just drills. For example I would like to get the Dewalt 20 volt LED work light and I checked the measurements in the big orange store and it will fit as well. For some tools, such as my portable circular saw, I could hang them upside down by the part where the battery would plug into, but to me that just looks and a little ugly it also fits a brad nailer. However if I was going to use it for tools like these I probably would have built it out of 1x10's and not 1x8's
gregzoll (01-26-2014)
Old 01-26-2014, 02:02 PM   #8
You can probably make a PVC sleeve, to place in those holes, so that it cuts down on the burring.
Old 01-26-2014, 02:26 PM   #9
Rewards Points: 170
Are you talking about the hole that the cords go through? If so the burring is not so bad. But i could do a roundover with the router as well. It would look better than pvc
Old 01-26-2014, 02:37 PM   #10
That too would work. I was thinking just using one of those inserts that are PVC, that are used in desks, for where cables pass through.
Or even just installing a power strip along the underneath of the shelf above, vs. having all of those cords passing through the hole. It would look a lot cleaner.
Old 01-26-2014, 02:41 PM   #11
As for the Dado's, if you have a router, you can use that for Dadoing the slots for the shelves.
Old 02-07-2014, 04:15 AM   #12
Very cool. Great idea and great job!
dezandseth is offline   Reply With Quote
Old 02-18-2014, 10:51 AM   #13
Rewards Points: 87
I did this exact same thing about a week and a half ago. I adapted plans I found here http://funwithwoodworkingtoo.blogspo...ess-drill.html and used 3/4" plywood to build it.
I intended on doing rabbet joints for the shelves but found out after I purchased a new Dado blade set for my table saw that the arbor bolt on my saw will not allow for dados larger than 1/2". Because I already had the plywood and I wanted to use it, I decided against the rabbets and just used mechanical fasteners to hold everything in place.
I am missing the drawer at the bottom but have plans to dig into that another time. For now I'm going to start work on a miter saw stand which I'm hoping to have done this weekend.
ssgtjoenunez is offline   Reply With Quote
convert cordless tool to corded? jason41987 Tools 14 12-03-2012 10:49 PM
Clamping tool or Oscilating tool for a DIY'r-you can only pick one which would it be? whataboutj Tools 12 11-29-2010 08:12 AM
Review: Harbor Freight Oscillating Tool Tedstor Tools 0 07-13-2010 03:24 AM
Need Help with re-design ttwiss Remodeling 21 05-08-2010 11:27 PM
Fein's Multimaster Tool...don't let the price scare you! CrossWorks Tools 13 04-18-2009 07:39 PM
