#91 |
Stone Veneer Firepit
Finished cutting all of the pieces that I had laid out around the edge. I leveled about 5 of them when I stopped because I realized I may need to make a couple more cuts later when I place the other stones next to them. It started getting late, so I called it a day. Here are the pics of the pieces that were cut:
Overall: ![]() Top views: ![]() ![]() ![]() Maybe I'll have more progress tomorrow! Oh BTW, I meant to ask what kind of gap I should leave between pieces for mortar? |
#92 | |
Concrete & Masonry
Stone Veneer FirepitQuote:
The gaps look great, maybe a bit tight for mortar, but pics can be decieving. We generally shoot for 1/2 - 3/4" for grouted joint. You will have areas that get a little bigger, but that's fine as well IMO. Just a few ideas. Sorry, I'm not trying to be critical by any means, but my mind is trained to piece stuff like this together when I see it......... ![]() Red lines are things I would cut, just to make the continuing stone placement easier. Yellow lines are merely a little direction on your next stones, but that can vary greatly depending on what you have to work with. Keep up the good work Michael! |
#93 |
Progress is slooooowww. I also ended up finding a small sand leak after a very hard rain that I had to fix. I assume that after I get all the stone down and mortared up, I wont have those kinds of problems due to the rain not directly hitting the sand and the water mostly staying out of that area.
I managed to snap this pic before the camera fogged completely up and became useless: ![]() Its hard to tell at this point, but I'm starting to wonder if I'm going to have enough stone to finish the patio and the cap! Last edited by eemichael83; 07-29-2010 at 11:01 PM. |
#94 |
Hats off to you eem, that looks great!
#95 |
The colors are beautiful and the pieces look great pieced together that way.
Now I'm really excited to see it finished! |
#96 | |
Thank you
![]() Quote:
![]() I'm really hoping to make quite a bit of progress this weekend but it is supposed to rain a bit. I figure after I get a pretty large section done, I'll level the pieces and try and pack the sand under them as qood as possible, then mix up some mortar and let that section set up. |
#97 |
It's a shame and all that you seem to be getting so much rain...but don't complain too loudly. We are desperate for some rain here. Latest is that we might get a shower or two in two weeks!
#98 |
Can I ask where you got the idea on how to build this? It looks awesome, I'd love to have one in the future.
#99 | |
http://cgi.ebay.com/ws/eBayISAPI.dll...#ht_2143wt_869 Here's a little update. I've been able to work on it a little bit on a couple of different days. Today, there was one piece that I was really struggling to find. I finally found one with a shape that would work well... I marked it, cut it about half way through, started tapping it lightly with the hammer and fractures started appearing everywhere... finally it just exploded into many many pieces. Thats when I quit for the day ![]() ![]() ![]() ![]() These pieces are wet in the pics btw, I took the pics after rinsing all the dust off of them from cutting. Also, I think it will look better and more uniform once they're all leveled and there is mortar between them. I'm still doubting whether or not I have enough stone to complete this never ending project lol Last edited by eemichael83; 08-05-2010 at 11:42 PM. |
#100 |
Pulled the plastic off on my lunch break and snapped a couple of pics. The stone is dry in these...
![]() ![]() ![]() I think I'll probably start working on the cap now so that I can quit fooling with the plastic cover everytime theres a chance of rain. Its going to be hard fitting pieces around the actual pit with that plastic bunched up around it anyway. Also, the pit is quite a bit shorter now that the ground around it is level lol Last edited by eemichael83; 08-06-2010 at 01:45 PM. |
#101 |
You know, for a young feller who was so impatient to get this done at the beginning you are doing one helluva great job!
I imagine by now, that you have a new found appreciation for stonemasons. Nothing is ever quite as easy as it seems. If you keep this quality of work up in all that you do, you will have a house that you can be truly proud of. I'm going to wait patiently as you work your way toward the end of this "Not-so-little" project. Lots of us are watching quietly in the wings, and we are all hoping for your success. So good luck from me! |
| The Following 2 Users Say Thank You to cocobolo For This Useful Post: | eemichael83 (08-07-2010), sbmfj (08-09-2010) |
#102 | |
"Nothing is ever quite as easy as it seems."- understatement of the year ![]() Hopefully you wont have to be much more patient... I got to work on the cap today and was able to cut up and lay down about 1/3 of it in only 2-2.5 hours. I think a full day (probably sunday) and I'll be able to have it done. I worked until it got dark out so I wasnt able to snap any pics. Last edited by eemichael83; 08-07-2010 at 12:48 AM. |
#103 |
You need to watch that working until dark stuff...I get caught doing that all the time.
At least you're smart enough to wait until tomorrow to take the pix! I'm usually too impatient and take them then and there. The flash pix never come out that well. Like I said...I'll be watching!!!
#104 |
A little update while I cool off from the crazy heat outside:
![]() ![]() I havn't had to cut any of the outside edges yet, only the inside edges... I've been lucky. |
| Display Modes | |
| Firepit made with cinderblock and stone veneer | Jfuente08 | Landscaping & Lawn Care | 1 | 05-08-2010 05:48 AM |
| What to do where cultured stone veneer meets grass | shleppy | Landscaping & Lawn Care | 1 | 11-09-2009 05:29 AM |
| J-Weep / Flashing for exterior cultured stone veneer wall. | Spud | Building & Construction | 18 | 08-31-2009 10:44 PM |
| stone veneer | dinodon | General Discussion | 7 | 07-01-2008 08:39 PM |
