Stone Veneer Firepit - Project Showcase - Page 15 - DIY Chatroom Home Improvement Forum
Old 12-10-2011, 07:19 AM   #211
Concrete & Masonry
Rewards Points: 548
Originally Posted by Headstill View Post
Here it is, any advice?
Yes, either line it with firebrick, or don't burn in it. Concrete block WILL NOT withstand the heat produced by wood fires for long, especially when the interior is so small and the fire is so close to the walls. You can use "split" firebrick, which are only 1.25" thick, on the inside so you don't lose too much room. Make sure you use the correct fireclay for exterior use as well.
One more thing, you may want to rethink the granite cap, as granite does even worse than concrete block with fire.
jomama45 is offline   Reply With Quote
Old 12-10-2011, 08:27 AM   #212
Thanks jomama45 for your reply, so about the granite? Seems like I see many fireplace surrounds and hearths made out of granite. What are you implying that the granite will do? Seems to me that there are many fireplaces that have granite surrounds and even marble. Can you please explain your comment?
Headstill is offline   Reply With Quote
Old 12-14-2011, 08:45 PM   #213
Rewards Points: 77
^ I would most certainly take any precautions possible in making sure that pit stays together. It will be one heck of a PITA to redo or replace now that the deck is built around it (which looks great btw).
eemichael83 is offline   Reply With Quote
Old 12-15-2011, 01:09 PM   #214
Rewards Points: 1,232
Granite will spall under direct flame. You see it used for surrounds which have no direct flame on them.
Advice is free, Lessons begin at 75 bucks an hour.
Tscarborough is offline   Reply With Quote
Old 12-17-2011, 08:38 PM   #215
Rewards Points: 276
I think I may actually build one of these next summer but maybe not as elaborate. I may skip the stone veneer. Do the egg rocks mak it difficult to clean?
Jim F is offline   Reply With Quote
Old 01-18-2012, 09:54 PM   #216
Rewards Points: 77
Well I've never cleaned it... so no BTW, applying the stone veneer was probably one of the easiest and least time consuming parts
Old 01-20-2012, 09:11 PM   #217
Rewards Points: 27
eemichael83 -- I really liked your saga! Here is mine...
moved to new thread:
Old outdoor fireplace rehab'd to a firepit...
wrooster is offline   Reply With Quote
Old 01-20-2012, 09:12 PM   #218
Rewards Points: 27
Old 01-20-2012, 09:12 PM   #219
Rewards Points: 27
Old 03-22-2012, 02:10 PM   #220
It's always something
Rewards Points: 150
Just finished reading all the posts in this thread and I'm pumped up now to go build mine! Thanks for the inspiration. I searched all morning on ideas/tips/tricks/etc and your work is the final stop. I tip my hat to you sir...
If it's ok to ask; what, roughly, was the final bill for this project?
SingleGuy is offline   Reply With Quote
Old 03-24-2012, 05:33 PM   #221
Rewards Points: 77
^ I believe the total was somewhere around $1600 which included the flagstone walkway too. I could have saved some on materials if I knew more about what I was doing beforehand but that was part of the learning process.
The Following User Says Thank You to eemichael83 For This Useful Post:
SingleGuy (03-24-2012)
Old 09-10-2012, 07:32 PM   #222
Rewards Points: 77
I finally got around to making a log rack to replace the unsightly wood pallet for the logs. Total cost was ~$15 and it looks so much better than the logs sitting on a big wide pallet with weeds growing around it. I also killed off my yard a few weeks ago, de-thatched it over the past few days, and will be core aerating it tomorrow and putting down seed and fertilizer.
Old 09-11-2012, 08:07 AM   #223
Custom User Title
Rewards Points: 252
Looks great. I have those same chairs. I got them for $25 on sale. Not bad for the price.
no1hustler is offline   Reply With Quote
Old 09-11-2012, 12:03 PM   #224
Rewards Points: 150
That really adds a nice touch!
It's always something...
Old 10-01-2012, 09:45 PM   #225
Hope I'm not too late but in my new blog site I was able to come up with some blogs and images that could help. Check it out: -------------
Last edited by Gary in WA; 10-01-2012 at 10:03 PM. Reason: Web link belongs under your signature line.
reachout is offline   Reply With Quote
What to do where cultured stone veneer meets grass shleppy Landscaping & Lawn Care 5 09-03-2014 06:39 PM
Firepit made with cinderblock and stone veneer Jfuente08 Landscaping & Lawn Care 1 05-08-2010 04:48 AM
J-Weep / Flashing for exterior cultured stone veneer wall. Spud Building & Construction 18 08-31-2009 09:44 PM
stone veneer dinodon General DIY Discussions 7 07-01-2008 07:39 PM
