12-05-2010, 01:58 AM
#181
Stone Veneer Firepit
Originally Posted by oatlord
I feel like I won't have closure in my life until I see pictures of a fire in this pit.
 I really cracked up at this. I've had a few fires in there... problem is, we're only allowed to have open fires between 6pm and 6am right now. Since the only times I'm able to have a fire it is dark out, I dont think pics would turn out too well. I'll give it a try the next time I get a good fire going.
Btw, its been raining quite a bit and I havn't been able to build a covered log rack yet, so the fires I've been able to start have been somewhat puny with the wet wood and all. It's still nice listening to the crackling and hissing (hissing comes with the steaming water in the wood)
12-06-2010, 10:58 PM
#182
Looking forward to it. I just got the last of the lawn furniture in as the first real snowfall of the season was getting underway. Five inches on the ground and cold now. I refuse to put up the outdoor lights until it warms up a little. You are luck to have a more moderate climate there.
12-07-2010, 10:38 AM
#183
Home owner
Yea I heard you got slammed by the lake effect snows early this year  Hope your weathering well there Jim... Got any projects on the way ? Sorry there eemicheal dont mean to hijack your thread
12-07-2010, 08:10 PM
#184
Always something to do. Hope to get these lights up. Just need it to warm up a little. We usually have a day of mild weather on the Thanksgiving weekend but not this year.
12-17-2010, 12:20 PM
#185
Any luck getting some pictures of a fire in action, yet? I just chewed through this entire thread, and I have to say, I'm mighty curious.
Beautiful job, by the way, eem. Hats off, sir!
12-26-2010, 02:40 PM
#186
Great job on the fire fit. I also got 2 of those chairs from Ace last year and have been looking for more ever since. They are actually pretty good quality and definitely worth the price.
04-02-2011, 03:19 PM
#187
seriously, no pictures with a fire? i mean, i can't complain because i leave all my projects 95% completed too lol .. but geez.. this is an amazing thread, you gotta finish it off iwth a fire photo!
thanks for the share, you will be an inspiration for many.
Knucklez
"if you can't be handsome, at least you can be handy" -Redgreen
04-09-2011, 05:19 PM
#188
Drumroll please......
Just took these last night. This was toward the beginning of the fire so it was a little on the smaller side. After about 30 min or so I had some pretty good sized logs in there and the fire was bigger but at that point it started to get too dark for any decent pics.
The Following 4 Users Say Thank You to eemichael83 For This Useful Post:
04-10-2011, 05:21 PM
#189
So nice, so nice...
What stone did you use in the middle of the pit? Just bags of stone from Lowe's or Home Depot?
04-10-2011, 05:37 PM
#190
So nice, so nice...
Yep, just some 2-3" Egg Rock from Lowes.
04-10-2011, 05:40 PM
#191
awesome!!! very inspiring. Job well done!!
04-13-2011, 07:40 PM
#192
I googled this and there are a lot of people out there giving half-assed advice on how to go about this. Congrats on doing a good job. Any reflections, regrets, things you might have done differently? That might a good way to conclude this project thread.
I plan on doing the same but mine are still ongoing, even the downstairs bathroom is not completed, just on hold.
The Following User Says Thank You to Jim F For This Useful Post:
04-14-2011, 11:06 AM
#193
Concrete & Masonry
Michael
I had forgotten about this project, glad to look at the pictures again.
As a mason who's done a fair amount of flagstone work myself, I have to say you did a PHENOMENAL JOB on the joints and fitting! I'd give you an A+, and offer you a job if we did more of this work, and you were closer of course..........
The Following 2 Users Say Thank You to jomama45 For This Useful Post:
04-26-2011, 09:11 PM
#194
Well having had the experience now, it would probably be easier to more accurately predict the amount of materials that I would need for this or a similar job. Because of how much slope the land had to it, a significant portion of the low side of the pit (chimney part) was actually covered with sand and then flagstone. I probably could have gotten away with a box or two less of the stone veneer. Since I also ended up filling the inside of the pit with a large amount of egg rock, I probably could have also gotten away with maybe half the fire brick and refractory cement and just used some half cinder block in the bottom half and then the fire brick on top for the top half. That would have cut the cost by $100+. I would have also 'liked' to have had about another foot radius on the patio. It is comfortably big enough now, but it would be nice to have that extra 1' all the way around the pit to pull the chair away further if you wanted or to have plenty of room to walk through with someone sitting there too, but that would have added back into the cost and the amount of time and work I would have had to put into it.
Also, as others had mentioned about half way through the thread, putting a drain in first may have been easier than drilling one after the fact. The drilled drain works great though, I've never had any standing water and we've had crazy amounts of rain here lately so no problems there. Since I've raised the fire up by filling the pit with egg rock, there is also no ventilation problems whatsoever. This isn't the reason I raised the fire though... I did that so that the heat could radiate outward. When I tried a couple of fires in the winter, the heat was mainly just above the pit. The fire was just a bit too deep in the pit for the heat to radiate outward.
One other thing worth noting is that the pit portion held up very well through the winter. No cracks at all in the mortar or veneer. The concrete base must have been sufficient. Not surprisingly, the patio portion did have some cracking in the joints. It still looks great, but the crack is there even though in most places its not noticeable. I expected this since the foundation is sand and it will swell when the ground or any moisture under there freezes and then settle.
BTW, I'm not actually 'finished'. I'm currently working on the walking path
I'm about 1/3 done with it. Like the pit, it is also a bit of a pain to dig for the rock and then get the rock to not wobble by shifting the dirt underneath. I've been putting down that weed blocking fabric and filling the voids with pea gravel.
04-26-2011, 09:48 PM
#195
Here is a midway pic:
I've been piling up the shoveled dirt around the pavers of the patio and I'm going to end up planting some flowers or something in it to attract the batterflies and rabbits
The Following User Says Thank You to eemichael83 For This Useful Post:
| Thread Tools |
Search this Thread |
| Display Modes |
Linear Mode
