Go Back   DIY Chatroom - DIY Home Improvement Forum > DIY Repair > Project Showcase
Old 09-24-2010, 11:33 PM   #151
Stone Veneer Firepit
I wouldn't think those stones will sink perfectly flush to the ground. I've laid stone paths out out of necessity to overcome a muddy path to my house and they do settle somewhat and stabilize. However, by spring you will have a better idea of what you do want to do with them between setting them on earth or settling them into some sort of paving substrate. The main consideration is that they are not hazardous to walk on. Elderly visitors to your place may want to walk alongside the stone path on the grass until you are sure they are stable and not a trip hazard.
Jim F is offline   Reply With Quote
Old 09-26-2010, 11:06 PM   #152
Today I was able to rearrange the stone walking path and split the wood
Now I just need to put together those adirondack chairs and put a fire in there!
eemichael83 is offline   Reply With Quote
Old 09-26-2010, 11:51 PM   #153
Thumbs up
Your firepit looks awesome! You have inspired me to re-do my firepit. I did mine about a year ago & it looked only OK. I have since busted off all of the stone & flagstone on top and am in the middle of re-doing it now.
I LOVE the look of your flagstone & was able to fine something somewhat similar here in California at Silverado Building Materials (Sacramento). I purchased it today (Sonora Gold, I believe), and was able to lay down the flagstone (top) today. It's been a long day, but it's going to be SO worth it when I'm done.
Thanks for the inspiration
agbrisco is offline   Reply With Quote
Old 09-27-2010, 01:18 AM   #154
cocobolo's Avatar
OK then...now you're talking! That path looks excellent.
You know, when the Japanese lay rocks for pathways in their gardens, you need to look down at the rocks as you walk. You may arrive at a junction in the pathway where you can stop for a few seconds to look up. It is usually at these locations that there is something special to view.
I know your path is wide open...but you never know what interesting landscaping you might introduce in future. Just a little tidbit to keep in mind.
cocobolo is offline   Reply With Quote
Old 09-27-2010, 05:23 AM   #155
Ivy
Great job!!! I love it!
Ivy is offline   Reply With Quote
Old 09-28-2010, 11:49 AM   #156
Thank you and you're welcome! You'll have to post up some pics of yours when you get done
Old 09-28-2010, 12:22 PM   #157
Graphics Specialist
kredman's Avatar
Awesome.
kredman is offline   Reply With Quote
Old 09-28-2010, 03:22 PM   #158
Dorf dude...
shumakerscott's Avatar
Are you ever going to light a fire in it.
Today is only yesterdays tomorrow, Now get to work!
shumakerscott is offline   Reply With Quote
Old 10-01-2010, 09:02 PM   #159
Just finished the fire pit today! I am so happy I found this thread as it gave me great ideas & finally pushed me over the edge to re-do my fire pit! The old fire pit had 3-rivers flagstone and river rock on the sides. Here's a couple of pix
(before and during demolition):
During demolition:
And now - the new and improved fire pit! With Eldorado Bluffstone (Bodega) on the sides, and Sonoran Gold flagstone on top:
Can't help it... the "wet-look" is awesome.. Love the colour of the stone!
And a side shot:
Old 10-03-2010, 06:11 PM   #160
One of these days. Literally the day I got it finished, the county went under fire ban and that wont be lifted until there is some rain. Theres is absolutely no rain in the 10 day forcast so...
And now - the new and improved fire pit! With Eldorado Bluffstone (Bodega) on the sides, and Sierra (or Sonoma) Gold flagstone on top
That looks really good I like that stone you used for the outside wall, it looks pretty sharp. Man you sure got that together in a hurry! As you can see, it took me quite a bit longer lol.
Old 10-04-2010, 09:37 AM   #161
Custom User Title
agbrisco, the new one looks far better. Good job!
no1hustler is offline   Reply With Quote
Old 10-04-2010, 10:07 AM   #162
Very nice fire pits
One day I may build one
I like the stone look
BGGRNTXS is offline   Reply With Quote
Old 10-04-2010, 04:36 PM   #163
Does a fire pit like that need draft ventilation? And what do you do for drainage?
Old 10-04-2010, 11:28 PM   #164
I dont *think* ventilation will be a problem, but I havnt had a friggin fire in it yet to tell
As far as drainage: Stone Veneer Firepit
I used a 12" masonry bit and drilled through the wall at the very bottom on the low side, then ran that tubing through another hole in my retaining wall. In hindsight, I would have probably put a drain and pipe in the center of the pit that would run under the footer, but before I had even thought about it, I had already poured the footer and let it set up.
The Following User Says Thank You to eemichael83 For This Useful Post:
Jim F (10-05-2010)
Old 10-05-2010, 02:55 PM   #165
I haven't noticed any issues with ventalation or drainage. My fire pit is about 44" wide, so as long as I don't have a couple of tree trunks in there, my bundle of wood has plenty of air. Not only that, but it's only about 12-14" tall.
As for drainage - hasn't been a problem for me - it's just dirt below. We don't get torrential rains here in CA. Each night I use the fire pit, I use a garden hose to put out the glowing embers. By the next night, it's dry enough to use...
The Following User Says Thank You to agbrisco For This Useful Post:
Jim F (10-05-2010)
Firepit made with cinderblock and stone veneer Jfuente08 Landscaping & Lawn Care 1 05-08-2010 05:48 AM
What to do where cultured stone veneer meets grass shleppy Landscaping & Lawn Care 1 11-09-2009 05:29 AM
J-Weep / Flashing for exterior cultured stone veneer wall. Spud Building & Construction 18 08-31-2009 10:44 PM
stone veneer dinodon General Discussion 7 07-01-2008 08:39 PM
