Stamped Concrete - Project Showcase - DIY Chatroom Home Improvement Forum
Old 09-06-2009, 10:12 AM   #1
Question
stamped concrete
I just had my courtyard refinished with a stamped concrete. My contractor mixed the base color (lighter color) in the concrete - the darker color was a powder on top. I am so disappointed!! I expected the darker color to be very minimal and to just add contrast in some of the grooved areas. The overall look is MUCH darker then I wanted. Q. is there an acid (or other product/method) tht can be used to lighten the darkness? I would first have to strip the sealant.
Regards,
Sugar
sugar is offline   Reply With Quote
Old 09-06-2009, 12:10 PM   #2
Concrete & Masonry
Rewards Points: 636
Sugar, I would rule out acids, as they will probably only darken the surface.
Check out waterbourne concrete stains, as they may be an option. As you mentioned, the sealer WILL have to be stripped first to make it effective. This is not easily accomplished.
You may want to check out a few companies websites such as Schofield, Elitecrete, Soloman, Butterfield, etc.. to see if they have more options.
Colored sealers are also available, but will be opaque, showing the release color below, & generally only darken the concrete.
BTW, being this is in the project showcase heading, where's the pictures?!
jomama45 is offline   Reply With Quote
Old 09-07-2009, 10:00 AM   #3
Remodeling Contractor
why didn't you get a sample of the expected end result prior to the project? This would have at least put the burden on the contractor to get it the way you wanted. Only thing you can do now is use a pressure washer to remove the sealer and a lighter color stain. Still will be hard to get the effect you want, especially if you do not even know what this is.
Old 09-09-2009, 02:10 PM   #4
Cool
Hey Bob, a bit harsh...FYI, I have done some research on concrete stains. Am warming up to the results of my courtyard,
Old 09-09-2009, 07:23 PM   #5
Knucklez's Avatar
Rewards Points: 942
what u probably wanted was dark colour mixed in & light colour powder. then only the groves would be dark?
Knucklez
"if you can't be handsome, at least you can be handy" -Redgreen
Knucklez is offline   Reply With Quote
How To Keep Your Concrete Mixer Driver Happy Mort How To Guides 38 02-12-2014 06:25 PM
Stamped concrete kathy103 Landscaping & Lawn Care 10 10-27-2011 06:51 PM
stamped concrete dafonz Building & Construction 1 05-06-2009 07:15 PM
concrete washed on existing stamped concrete morta General DIY Discussions 2 10-10-2008 09:58 AM
"Haze" on stamped concrete PntrRookie Landscaping & Lawn Care 1 03-30-2006 07:48 PM
