Stairs I Built 6 Years Ago - Project Showcase - DIY Chatroom Home Improvement Forum
Old 08-04-2010, 03:27 PM   #1
Wire Chewer
Red Squirrel's Avatar
Rewards Points: 72
Stairs I built 6 years ago
Kinda odd to go that far back, but I recently went back to camp and it's been that long since the last time I went and these stairs are still looking good. I figured they would not last long being down a large hill and having to deal with the spring water run off, but they still are there and look pretty much the same as they did 6 years ago.
To build them I cut down a tree with a bucksaw, then cut the logs to proper size. They are actually in the ground a foot or so on each end and the ground was packed using a sludge hammer, small sections at a time. It does not look like much, but to do this properly, it took a couple hours.
Before:
After:
Old 08-11-2010, 01:51 PM   #2
Rewards Points: 372
They look good! I like the way they blend in with what's around them.
gma2rjc is offline   Reply With Quote
Old 08-11-2010, 03:10 PM   #3
Custom User Title
Rewards Points: 252
I like it!
no1hustler is offline   Reply With Quote
Old 08-11-2010, 07:31 PM   #4
Rewards Points: 150
couple of hours? geez that looks like a day or two or labor lol
johnnyboy is offline   Reply With Quote
Old 08-11-2010, 07:47 PM   #5
Wire Chewer
Rewards Points: 72
Actually couple hours after cutting the logs, I had cut them a day before if I recall. Couple hours being, 3,4, maybe 5ish. I do remember I was badly sunburned when I was done. I sunburn if I spend more then 15 minutes in the sun and I was in it for hours. Was a bad one lol.
Next time I go I should get a pic of them currently to compare. The logs have turned a bit gray as they tend to do over time but other then that it looks good to consider the abuse it goes through in spring and the fact that I never treated the wood in any way. Hard to tell in that picture, but there is a much bigger hill ahead of those stairs.
Old 08-18-2010, 03:42 PM   #6
harleyman's Avatar
Nice!
harleyman is offline   Reply With Quote
Deck Stairs Support protools Building & Construction 7 05-05-2010 07:49 PM
Need Advice on how to complete basement stairs. Bakuto Building & Construction 11 04-05-2010 10:37 PM
Basement Stairs/ EZ Stairs mjkpainting Carpentry 8 02-24-2010 10:24 PM
closing in porch stairs - design question wombosi Carpentry 3 10-12-2008 11:18 PM
Foundation Work - Installing a walk up stairs handy man88 Building & Construction 2 10-01-2007 01:19 PM
