-   Project Showcase (http://www.diychatroom.com/f49/)
-   -   Some quick before/after pics of the bedroom I remodelled (http://www.diychatroom.com/f49/some-quick-before-after-pics-bedroom-i-remodelled-8815/)
J187 05-30-2007 10:47 AM
Nothing crazy just nice and clean. The before was really bad. I still have to clean up above the TV, its the second one we installed there and the first was a little higher mounted. The closet had to be demoed and raised a full 8 inches to accomodate the glass doors.
http://i5.photobucket.com/albums/y153/J187/Before3.jpg
http://i5.photobucket.com/albums/y153/J187/Before2.jpg
http://i5.photobucket.com/albums/y153/J187/Before1.jpg
J187 05-30-2007 10:48 AM
http://i5.photobucket.com/albums/y153/J187/After1.jpg
http://i5.photobucket.com/albums/y153/J187/After2.jpg
http://i5.photobucket.com/albums/y153/J187/After4.jpg
ron schenker 05-30-2007 12:23 PM
Wow, what a difference...but I would have kept the beautiful pink carpet:laughing:
KUIPORNG 05-30-2007 12:59 PM
The most impressive item I would think is the LCD TV liked embedded onto the wall without any wiring exposed.... Those requires good planning and most difficult: wife not change her mind where the TV located, yesterday, today and tomorrow... or after looking more closely,... is it a TV?
J187 05-30-2007 01:29 PM
Yes it is a TV - a 32" LCD. The tricky part of the wiring was that the wall the TV is on is the outside wall of my split level house. So, in the attic, it is the point at which the roof and floor joists meet. I had to crawl out on the joists to the very edge where roofing nails were digging into my head and spiders were taunting me and drill holes w/ an angle driver to fish wires. The end result is excellent though. Thanks.
ktkelly 05-30-2007 02:12 PM
Nice clean job....:thumbsup:
I personally would have mounted the TV up a bit higher in a bedroom (nothing you can't change...:laughing: ), but to each his/her own.
I know exactly what you mean about the attic issue. Been there many, many times. What a real PIA that is...
KUIPORNG 05-30-2007 02:17 PM
the other issue is : how do you play DVD in the TV? or you just watch cable..... if unable to play DVD... that really take away a large % of everyday usage....
or you so.... well plan that the DVD player is wire to the otherside of the room
J187 05-30-2007 02:25 PM
Thanks.
We actually both commented afterwards how the TV looks so much lower when you are standing then it does when you are on the bed watching. Its not much too low, but it is a bit too low, but as I mentioned, its a new TV mounted to the same mount I had the old. On the old TV the mount plate went to the way bottom, on the new one it is at the very top, the difference is like 5".
J187 05-30-2007 02:28 PM
Kui - We have HDMI cables run to behind that chest and we had a DVD that sat directly on the chest. It recently died and we haven't replaced it yet. DVDs actually do not make up a large percent of our daily usage in the bedroom, I also have a family room/TV room in the basement featuring a 65" DLP TV with a full home theater sound system which is where we usually head for DVDs.
KUIPORNG 05-30-2007 02:49 PM
Wow.... that is very nice.... I am also thinking about the DLP Projector... thinking whethere I should or shouldn't do it....
we don't watch that much DVD in our family.... wonder if that will change if we have a DLP Projector.... Is 12' or a little bit less than 12' enough distance to setup such....
J187 05-30-2007 02:56 PM
12' Viewing distance is ideal for a TV 55" -65"
ktkelly 05-30-2007 02:58 PM
I agree, a picture can be deceiving. I pictured you watching TV through your toes....:laughing:
What's important is that YOU (the wife) like it where it's at....
That said, I have a new project for you with regards this TV set up.
1. Shift the TV slightly to the right, so it lines up with the AC unit and slightly up.
2. Construct a "surround" of MDF extending out from the wall that would give a "shadow box" affect around both the TV and the AC unit.
3. Construct a cloth panel that covers just the AC unit for use in the winter months.
I know it would be a lot of work for something that is just for the looks, but I think you'd like it....:yes:
ktkelly 05-30-2007 03:07 PM
FWIW:
AS a professional in the industry I recommend the JCV HD'ila, or the Sony equivalent over any DLP/LCD rear projection set.
The reasons being that LCOS based RPTV's don't have the moving parts like a DLP (color wheel), or less brightness like a LCD.
And you must bear in mind that either of these will require a bulb replacement which averages $300.00 every now and then.
How often depends on how heavily used. I've seen the need for a bulb in a year, and I've seen others last for several years.
And as mentioned above 12' is fine for large displays. Even up to the 70" stuff....:)
keyser soze 05-30-2007 03:14 PM
Nice work J187! I can't figure out why you changed the color of the carpet but it's your bedroom not mine. :whistling2:
TV's at the foot of the bed are hard to place well. I always joke with my coworkers that I'll just mount mine on the ceiling and lay flat to watch it. Otherwise there's always a compromise between height, angle, and how many pillows you can handle on the bed. My mom could have a lower height than you since she has like 4 pillows on each side of the bed, not counting the little ones that go in the middle. :no:
You have a decent height for the flat mount which looks very nice. Too much higher would beg for a tilt mount that just doesn't look as cool.
J187 05-30-2007 03:48 PM
Yeah, the color of the carpet was good. Wall stains were nice too, but I needed change. When I take a few minutes to adjust the TV height it will be perfect, the old one was.
BTW, did I tell you I was in a barber shop quartet in Skokie Illinois?
