Go Back   DIY Chatroom - DIY Home Improvement Forum > DIY Repair > Project Showcase
Old 02-05-2009, 12:58 PM   #16
some DM creations and projects
very nice
tybeeanna is offline   Reply With Quote
Old 02-06-2009, 08:56 AM   #17
DIY Rookie
Send a message via AIM to jpfreak33
I like this one a lot, very simple, almost craftsman style. if only I had the time....
jpfreak33 is offline   Reply With Quote
Old 02-06-2009, 09:05 AM   #18
the Musigician
DangerMouse's Avatar
i want to make another and sell the set. maybe even more after this house gets finished!
if you saw the inside of the 'shade', you see it's a bit more complicated than it looks.....
i was wondering what you guys would think if i did the same white-off/green-on effect when i replace the cloth on the floor lamp with plexi?
too green? leave the light white? whatcha think?
DM
RU Crafty? Come join us at www.CraftForum.com !!!
For some Magical Fun, go to:
http://www.youtube.com/user/MickeySoume
Now Featuring: My Canine Assistant Picks the Magic Rising Card!
Old 02-25-2009, 02:32 PM   #19
the Musigician
here's the coffee table i made for the living room. the center holds family photos and odds and ends from the grandkids on and off. i was cleaning and realised i hadn't posted this project yet. the tempered glass was free, and i have 3 or 4 spares stored too.... just in case....
DM
Old 02-25-2009, 02:36 PM   #20
the Musigician
i was concerned with the shelf sagging over time, so under the shelf is a 4' piece of angle iron glued and screwed. still straight as an arrow...
DM
Old 02-25-2009, 02:38 PM   #21
That's sharp! Nice work. Do pictures go under the glass in the center? Good idea keeping the spare glass around .
gma2rjc is offline   Reply With Quote
Old 02-25-2009, 02:41 PM   #22
the Musigician
i know the pictures are pretty... but ya gotta read the posts too.... lol
DM
Old 02-25-2009, 02:48 PM   #23
I read it. I just didn't read it right. LOL.
Old 02-25-2009, 02:49 PM   #24
tomstruble's Avatar
nice work as usual DM
tomstruble is offline   Reply With Quote
Old 02-26-2009, 09:42 AM   #25
the Musigician
tnkx guys... this is how i spent yesterday. this is an old oak table from my childhood my father gave me. it has particle board as a base under 1/4" blocks of oak, with solid edges. the underside rails were mounted to the particle board and had obviously been broken 3 times judging from the relocated holes and craters. i took a split 2x4 and PL'd it and screwed it over all the holes. then i removed all the corners which were loose and PL'd them too and reset the screws. then i used the clutch on the drill and tightened all the triangular braces all around. MUCH stronger now!!! (lots of cheerios and banana pancakes consumed at this table...lol)
DM
some-dm-creations-projects-tablebracing.jpg   some-dm-creations-projects-tablecorner.jpg   some-dm-creations-projects-tabletop.jpg
Old 02-26-2009, 11:36 AM   #26
Good job! It looks nice.
Old 02-26-2009, 02:15 PM   #27
the Musigician
forgot to mention, when i did the coffee table, i made the first top 2" instead of 3" and didn't like it, too thin...sooooo.... i now have a matching oak-framed mirror over the woodstove.... oh well....
DM
Old 02-26-2009, 02:27 PM   #28
I like Wiley's sign. Can you post a picture of the mirror and frame?
Old 08-07-2009, 05:44 PM   #29
the Musigician
not right away, no... i need to clean first. lol
here's the shotgun case i just finished.
DM
More On This Topic
Burr Oaks and other Oak trees are easily propagated from their acorn. Burr Oak has a very large acorn that falls in the Fall and can be gathered quite easily. They are quite large and easy to find and they will grow from these sprouts. One thing that we... Read More »
Hi! This is Jon on behalf of Expert Village. In this video clip, we will be staining our project. The first step in staining our project is to take a tack cloth and rub that over our project. Now this is going to pick up any loose particles and it is... Read More »
Now our next step is going to be repairing the hinge so the gate doesn't sag. Over time bolts might rust. Your wood might get a little rotten. Whatever your gate would start to sag and so just a little bit of lift is all we need to bring it back to the... Read More »
These are Live Oak acorns. If you notice there are quite a few on the ground and a lot of them have this hole. That's from a weevil which drills a hole and feeds on the kernel from the inside. This one here is pretty obviously part of it eaten, it is... Read More »
A Spanish Oak acorn is what most people would consider more traditional type of shape because of the Burr Oak covers more of the acorn. This one has a small husk and the acorn sticks out of it quite pronounced and makes for a more traditional but most... Read More »
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
