Small Shed - Project Showcase - DIY Chatroom Home Improvement Forum
Old 05-16-2013, 11:09 AM   #1
Rewards Points: 89
Small Shed
I was in need of a shed, I did not like the ones that were sold in kits so I decided to build my own. I kept an eye out on CL and found some windows for free, some left over shingles for cheap. We are limited in our town to 10x10 sheds or we get taxed on them....
I built a frame for the concrete and put bolts in it so I could bolt the floor plate down.
tjfslaughter is offline   Reply With Quote
Old 05-16-2013, 11:12 AM   #2
Rewards Points: 89
rafters
A friend of mine helped me make the first rafter (I then copied all of them after that). I installed huricane ties between the rafters and walls. This made installing by myself a lot easier.
Old 05-16-2013, 11:15 AM   #3
Rewards Points: 89
windows and wrap
I found a pair of windows for free on Craigs' they are anderson casement. A little older but did the trick.
Old 05-16-2013, 11:18 AM   #4
Rewards Points: 89
trim, door, siding, stucco
I also found left over cedar from a job ($100) and a door that had a dent in it from a mill house ($80).... I put cement board along the bottom and attempted to stucco. I was not very happy with the stucco coat but it was my first attempt...
Old 05-16-2013, 01:05 PM   #5
Amateuralex's Avatar
Rewards Points: 270
Wow that's awesome. Did you do the trim/fascia yourself? Is it aluminum? How about the outside vertical corner pieces, vinyl?
And this is probably a pretty stupid question, but no worry about gutters? Tempted to plant something under the overhang to prevent a mud pit?
Amateuralex is offline   Reply With Quote
Old 05-16-2013, 01:15 PM   #6
Rewards Points: 89
I actually built this 2 years ago. I used pine for all the trim. Primed and finished on both sides. I put gravel all around it for the rain issue, since pic was taken I put bluestone for the front area.
The Following User Says Thank You to tjfslaughter For This Useful Post:
Amateuralex (05-16-2013)
Old 05-16-2013, 07:05 PM   #7
kwikfishron's Avatar
Rewards Points: 92
Looks GREAT... Excellent choice of siding material.
kwikfishron is online now   Reply With Quote
Old 05-17-2013, 08:58 AM   #8
Coconut Pete's paella!
CoconutPete's Avatar
Rewards Points: 504
That looks fantastic!
CoconutPete is offline   Reply With Quote
Old 05-28-2013, 07:23 PM   #9
Rewards Points: 194
Nice job! It looks really nice. Good job on saving money on the materials too!
gma2rjc is online now   Reply With Quote
diycoder's shed project diycoder Project Showcase 51 05-30-2014 11:26 PM
Footings for small pole shed sparty019 Building & Construction 4 04-02-2012 07:24 PM
Arrow shed on angle concrete foundation - how to fix? norcalty Building & Construction 4 06-18-2009 07:28 AM
Building rafters for small shed simonb Roofing/Siding 4 07-15-2008 01:32 PM
Shed Wiring bcdal Electrical 12 03-26-2008 05:51 PM
