Simple Solar Hot Water Box (for Domestic Hot Water) - Project Showcase - DIY Chatroom Home Improvement Forum
Old 11-24-2012, 05:27 PM   #1
Simple Solar Hot Water Box (for domestic hot water)
http://rimstar.org/renewnrg/diy_pex_...thermal_dn.htm
The total cost to build and install myself was about $400 total. I got my money back on it in approx. 1.6 years . In the link, it shows pictures of the construction of the box / a piping diagram / and test results. Its been in operation for about 2 years now and it puts out some good quality hot water that i have to mix in some cold water at the shower faucet . Plenty hot enough for the auto dishwasher too. Last year, i ran my electric water heater about 8 times total under heavily-cloudy skies ... otherwise , I get all the hot water i need from free solar energy. Its not a draindown system and i dont use anti-freeze liquid in it -- havent had any incidents even with the overnight temperature reaching 22 f a couple times.
Just a headsup in case youre considering it. My chief aim was to make it as simple and low cost as possible and to meet my hot water needs as a single occupant .
TheyCallMeDave is offline   Reply With Quote
Old 11-25-2012, 03:19 PM   #2
That's great! Its always nice to get your money back
jakeubu is offline   Reply With Quote
Old 11-25-2012, 03:33 PM   #3
DIY staff
Rewards Points: 7,174
I built a swimming pool heater some years back using an old sliding patio door section--and 3 rolls of black garden hose--tie strapped to a shallow wood box----
It got so hot I had to add tempering valves to keep the pool from overheating.
Thanks for the how-to----yours sure does look simple to construct---
Old 11-26-2012, 09:33 AM   #4
Yes, theres YouTube videos on guys that have done what you did to heat your swimming pool. Very low cost approach.
One might think that my 6 gallon capacity Solar Water Heating Box wouldnt be enough capacity for a 10 min. shower...but when you have to temper it down alot with cold water, the hot water flow is very small -- especially in the summer when that water is pushing 160 f .
I wanted to build a very low cost and simple System that didnt use a pump or elaborate costly collector .
Just for grins, i thought about fabricating some reflectors to intensify the solar light on the Pex Tubing just to see how hot i could get the water . This is commonly done for a Solar Oven application for cooking food.
Old 11-26-2012, 09:41 AM   #5
Rewards Points: 940
Has there ever been a better reason to add a location to a profile?
cleveman is offline   Reply With Quote
Old 11-26-2012, 10:30 AM   #6
Im located in Northern Florida .... very close to Tallahassee, Fl.
Regards, David Norman.
Warm Water out of Cold Water Outlet mb0709 Plumbing 9 08-26-2012 01:59 PM
water borehole question joeuser General DIY Discussions 2 04-18-2010 11:33 PM
No water draining into sump pit aci4369 Plumbing 2 08-18-2009 01:17 PM
Low Hot Water Pressure btennant Plumbing 4 12-09-2008 10:31 PM
