Screenhouse In The Woods - Project Showcase - Page 6 - DIY Chatroom Home Improvement Forum
Old 09-19-2010, 02:50 PM   #76
cocobolo's Avatar
Rewards Points: 6,098
Oh no! Now we're going to have row's of บบบบบบบบบบบบบบบบบบบบบบบบบบบบบบ's!:thumbup :
cocobolo is offline   Reply With Quote
Old 09-19-2010, 08:12 PM   #77
Ole Wood Worker
BigJim's Avatar
Rewards Points: 540
I tried it and it worked for me also. I was trying all kind of codes, I have a new toy now.
New members: Please consider adding your location to your profile.
If you do what you've always done, you'll get what you've always got.
http://www.woodworkingtalk.com/forum.php
Jim
BigJim is offline   Reply With Quote
Old 09-20-2010, 10:04 AM   #78
jules4's Avatar
I just realized I have no real idea how I should construct the door sill or attach the stairs.
I've attached a picture of what I came up with this morning - what do you think?
Is the flashing a good idea, or will that just trap water against the floor (considering water on the floor could wick under the flashing from the back)?
Edit: To clarify the drawing, the threshold will be ripped to 3" wide.
Edit 2: I've added a second image showing the sill with a bevelled nosing - I think this is a better design than the 1st image.
Screenhouse in the woods-door-sill-detail.jpg   Screenhouse in the woods-door-sill-detail-2.jpg
jules4 is offline   Reply With Quote
Old 09-20-2010, 10:13 AM   #79
the Musigician
DangerMouse's Avatar
Of course, you COULD just use 'character map' to get the degree sign ฐ, ฝ sign, ฃ sign, etc.
It should be in Start/programs/accessories/system tools. If not, search C: for charmap.exe
DM
The Following User Says Thank You to DangerMouse For This Useful Post:
BigJim (09-20-2010)
Old 09-20-2010, 10:16 AM   #80
jules4's Avatar
Hmm - I should probably cap the floor boards with a nosing that bevels down to the outer edge of the skirt board to get rid of that horizontal surface.
Last edited by jules4; 09-20-2010 at 10:28 AM. Reason: Have updated previous post to add bevelled nosing.
Old 09-20-2010, 10:19 AM   #81
jules4's Avatar
DM
I dunno , that seems so pedestrian compared to typing in secret code
Old 09-20-2010, 10:33 AM   #82
cocobolo's Avatar
....aaaaahhh you guys run rings (บบบบบบ) around me with all this magic computer stuff.
OK, on the question at hand, Jules it looks like in your drawing (something else I can't do) is that the bottom of your door butts up against the inside taper of the sill. OK, I know you will remove that anyway.
You could cut yourself a sill from the 2 x 6 like so.
First, have the door come over the top of the sill. Where the outside face of the door reaches - likely about 1 1/2" +- from the inside edge of the sill - mark a line.
From there, add your 15บ (there it is again) taper to the sill which you can have run beyond the outside of any floor member.
If you add the "thing of beauty" drip edge on the bottom side, you should be OK.
But I have to wonder with all the water which may blow inside if it will make that much difference. It will certainly look nice.
I think I might be inclined to use yellow cedar for that as it would last a lot longer than any spruce. I expect you will treat the spruce anyway, but spruce isn't the strongest wood on the planet and might wear somewhat.
Your other option might be to buy some sort of woman made product (forget this man made stuff, it never seems to last) which is resistant to the elements.
The Following 2 Users Say Thank You to cocobolo For This Useful Post:
BigJim (09-20-2010), jules4 (09-20-2010)
Old 09-20-2010, 10:58 AM   #83
jules4's Avatar
I'd never done it myself before this summer, but SketchUp has proved an invaluable aid in designing the screenhouse - it's a fabulous tool for discovering problems with a design (and much easier to edit than a scale model).
If you use the tutorials it's actually really easy to learn to use too, and it's available for free!
I hadn't though of exending the threshold beyond the floor - that's a good idea, I could rabbit it so that functioned as the nosing too.
Unfortunately there isn't room for it with the stair treads.
Spoken like someone who can't step out the door without tripping over old growth ceder logs.
The only ceder I can get locally is Eastern Ceder, and even that I'd have to special order (and would probably be all sapwood anyway). So crappy black spruce it is! I'll just make sure the threshold isn't to hard to remove for replacement when it gets worn.
lol
Old 09-20-2010, 01:19 PM   #84
jules4's Avatar
Okay - employing Cocobolo's suggestions I've put together Sill Variation 3 (in G major). I think this looks pretty good.
Old 09-20-2010, 01:36 PM   #85
the Musigician
Are you sure? It sounds like F# to me!
DM
Old 09-20-2010, 01:43 PM   #86
Ole Wood Worker
BigJim's Avatar
Rewards Points: 540
I am a little thick so please bear with me, what are the 1/4 inch strips for where you nail the stringers to the band?
Jim
Old 09-20-2010, 02:01 PM   #87
Old School
Willie T's Avatar
DM
She's cheatin' with a capo. You can never tell where she is.
Fran็ois Duc de La Rochefoucauld
Willie T
Old 09-20-2010, 02:44 PM   #88
cocobolo's Avatar
I dunno you guys, if she says it's G major....
That looks OK Jules.
Are you anywhere near any boatbuilding outfits...not the fiberglass kind, the real wood kind.
Someone there might well have some yellow or red cedar you could get. It's not like you need a huge piece.
And FWIW you can always glue up (epoxy preferred for outside) more than one piece if you can't find something big enough.
Old 09-20-2010, 10:32 PM   #89
jules4's Avatar
DM
My model may require a little tunning . . .
The 1/4 inch strips are there because I’m a little thick.
I put them in to make a gap between the skirt board and the top stair tread (to shed water) - until you asked about them it hadn’t occurred to me that I could just offset the tread on the stringers by 1/4" and achieve exactly the same effect.
Old 09-20-2010, 10:53 PM   #90
jules4's Avatar
I'm sure there must be people doing stuff with yellow ceder in Halifax (where I live) - but sadly I don't know any of them. The only boat builders I know are on the South Shore and build nothing but Cape Islanders (fibreglass).
I do have access to some old chunks of unfinished red oak that have been sitting in the attic for 70+ years - that would certainly wear a lot harder than spruce. I'm just not sure that it would be worth the effort involved in converting an oak 4x10 into a 1x6. The stuff is ridiculously hard - much, much harder than the red oak you can get at the lumber yard nowadays (not sure why that is - is it just because it's so old and dry? Or would it's being old growth make that much of a difference in hardness?).
Tags
flat roof , install screen , large window screens , screen house , shed roof
New Hardwood Floors = Strange Natural Gas Odor Vlade Divac Flooring 25 12-04-2014 05:05 PM
Mismatched baseboard woods HGraham Interior Decorating 3 01-13-2009 04:34 AM
Washing Machine Drains to outside in woods? Options? twilightcall Plumbing 13 01-14-2008 01:48 PM
AHHH! Just dented my hard woods! Help please keyser soze Flooring 7 07-18-2007 10:29 PM
