Screenhouse In The Woods - Project Showcase - Page 5 - DIY Chatroom Home Improvement Forum
Old 09-18-2010, 10:56 AM   #61
jules4's Avatar
Q
Originally Posted by jiju1943 View Post
Wow, I am totally impressed to say the least. That is a tough job but by yourself and no electricity is just amazing. Way way back when I was much younger I built a free standing carport by myself and it was a trick.
Your mom must be awfully proud of you and just knowing she will treasure her time there is just wonderful. We can't wait to see what you do next. Fantastic job!!!
My stars is all of Canada as beautiful as what we have had the privilege to see in this forum?
Just a quick question and maybe a suggestion. Would your mom use the porch in cool weather when the wind is blowing a little? If so maybe you could make lexan windows that would block the colder wind and could be removed when the weather got warmer. Just a thought.
Thank you for allowing us to share your project.
Thanks!
Why, yes, all of Canada is that beautiful - expect for that boring middle area from Quebec to Alberta.
I love the idea of adding lexan windows, but for now that's way out of budget - a possible future upgrade though.
jules4 is offline   Reply With Quote
The Following User Says Thank You to jules4 For This Useful Post:
BigJim (09-18-2010)
Old 09-18-2010, 10:56 AM   #62
cocobolo's Avatar
Rewards Points: 5,832
Sorry, I guess you must have a PC then.
There must be some way you can get the º sign, I'm pretty sure.
cocobolo is offline   Reply With Quote
Old 09-18-2010, 11:53 AM   #63
jules4's Avatar
Yup, PC. I'm pretty sure I could get just by entering its asci code though (assuming I ever bothered to look that up, which I probably won't lol).
Old 09-18-2010, 12:42 PM   #64
Old School
Willie T's Avatar
The ascii codes for degree (ALT+ 0176, 0237, or 248) often won't work with xml authors of most forums.
If it is important to you, and you are on a newer operating system composing with MS Word 2007, you can go to the toolbar, select the <INSERT> tab, SYMBOLS / MORE SYMBOLS / SUPERSCRIPTS & SUBSCRIPTS, and you should find the DEGREE Symbol about 6 or 8 rows down on that chart. (should be in the center of the 7th row from the top)
Once you have done that, you should find any symbols you've selected right there in the first dropdown box from now on..... thus eliminating a couple of the steps listed above.
Of course, on this particular forum, we are fortunate..............................
All you have to do here is, while holding down the ALT key, (using only the number pad on the right of your keyboard) type in 0176. Then release the ALT key.
Yes, I know many of you know how to enter ascii codes, but this explanation was for those experiencing it for the first time.
Willie T
The Following User Says Thank You to Willie T For This Useful Post:
jules4 (09-19-2010)
Old 09-18-2010, 01:09 PM   #65
Ole Wood Worker
BigJim's Avatar
Rewards Points: 302
Originally Posted by Willie T View Post
The asci codes for degree (ALT+ 0176, 0237, or 248) often won't work with xml authors of most forums.
If it is important to you, and you are on a newer operating system composing with MS Word 2007, you can go to the toolbar, select <INSERT> tab, SYMBOLS / MORE SYMBOLS / SUPERSCRIPTS & SUBSCRIPTS, and you should find the DEGREE Symbol about 6 or 8 rows down on that chart. (should be in the center of the 7th row from the top)
My stars, where in the world do you learn all of that stuff? I haven't even scratched the surface with computers yet.
New members: Please consider adding your location to your profile.
If you do what you've always done, you'll get what you've always got.
http://www.woodworkingtalk.com/forum.php
Jim
BigJim is offline   Reply With Quote
Old 09-18-2010, 01:14 PM   #66
Old School
Willie T's Avatar
Got my first computer in '83, so I've had some time for a few things to soak in.
The ascii codes are fun.... thousands of neat symbols you can just drop into your text anytime. Actually, the letters you are seeing appearing on your screen are each a separate asci code number sequence........ the keyboard just makes it easier for us nowdays.
Google ascii codes, and it will open up a whole new world of fun things to type in your posts.
To tell you the truth, I have to go to the MS Word <INSERT> menu all the time. It is next to impossible for any normal human to remember all those code numbers................. although in my younger days, I had about 50 of them memorized.
Willie T
BigJim (09-18-2010)
Old 09-18-2010, 01:21 PM   #67
Ole Wood Worker
BigJim's Avatar
Rewards Points: 302
Originally Posted by jules4 View Post
Thanks!
The more I see and learn about Canada the better I like it. It is just beautiful up ya'lls way.
Jim
The Following 2 Users Say Thank You to BigJim For This Useful Post:
jules4 (09-19-2010), sbmfj (09-16-2011)
Old 09-18-2010, 01:25 PM   #68
Old School
Willie T's Avatar
Sad to say, I've never been there.
Willie T
Old 09-18-2010, 01:34 PM   #69
Ole Wood Worker
BigJim's Avatar
Rewards Points: 302
The asci codes are fun.... thousands of neat symbols you can just drop into your text anytime. Actually, the letters you are seeing appearing on your screen are each a separate asci code number sequence........ the keyboard just makes it easier for us nowdays.
Google asci codes, and it will open up a whole new world of fun things to type in your posts.
Willie, I did a google on the code and I will be studying that for a while. I am just now smart enough to grasp all of that, Thanks for the heads up.
Jim
Old 09-18-2010, 01:40 PM   #70
Old School
Willie T's Avatar
When you get the hang of it, try checking out how to COMBINE ASCII characters. Some will stack right on top of others. That's cool.
Willie T
Old 09-18-2010, 01:57 PM   #71
cocobolo's Avatar
Good heavens Willie...you are an absolute goldmine of information!
Old 09-18-2010, 02:26 PM   #72
Old School
Willie T's Avatar
Perhaps one of the few advantages of being old. That, and the free senior soda at Taco Bell.
Willie T
Old 09-18-2010, 03:34 PM   #73
cocobolo's Avatar
Hmmmm...I wonder if they have the same deal up here in Canada, I'll have to check it out!
Old 09-18-2010, 07:54 PM   #74
Ole Wood Worker
BigJim's Avatar
Rewards Points: 302
Well for crying out loud, now we find out the soda is free for us ole folks.
In this quote
I meant to say NOT instead of now.
Jim
Old 09-19-2010, 01:40 PM   #75
jules4's Avatar
Sweet.
Tags
flat roof , install screen , large window screens , screen house , shed roof
New Hardwood Floors = Strange Natural Gas Odor Vlade Divac Flooring 25 12-04-2014 05:05 PM
Mismatched baseboard woods HGraham Interior Decorating 3 01-13-2009 04:34 AM
Washing Machine Drains to outside in woods? Options? twilightcall Plumbing 13 01-14-2008 01:48 PM
AHHH! Just dented my hard woods! Help please keyser soze Flooring 7 07-18-2007 10:29 PM
