Go Back   DIY Chatroom - DIY Home Improvement Forum > DIY Repair > Project Showcase
Old 07-12-2009, 06:55 PM   #1
Learning by Doing
Leah Frances's Avatar
Scrape and Paint Sunporch - Pics of new project
I guess this was a long time coming...
Man, I HATE the former homeowner. Rather than paint they just stapled plastic up over the side of this porch. So I had to pull around 8000 of those MFers, before I could even start. Not to mention, that it probably hasn't been painted since the 1970s.
The railings were completely rotted. So, they're coming off, and I'll have to make some more. At least that will be an excuse to spend a few days working in the A/C to match the old pattern. Better than scraping paint in the 90 degree heat....
Yes, I know, lead paint. Save the lecture, I'm being reasonably prudent about it.
I'll post more pics are the project comes along.
Cheers.
If I could only remember to THINK about what I was doing before I did it.
Leah Frances is offline   Reply With Quote
Old 07-12-2009, 08:22 PM   #2
Extreme DIY Homeowner
Scuba_Dave's Avatar
I just finally screwed down my last step going down off the deck
I had cement blocks piled up one one side of the step to de-warp it
Then I installed the balusters to block off the small open area on one side
Now I just need a railing on the other side
I hate scraping paint - left the deck natural
Scuba_Dave is online now   Reply With Quote
Old 07-12-2009, 10:09 PM   #3
Are you going to build the new railings to look identical to the originals?
Please say yes - they look SO cool!
gma2rjc is offline   Reply With Quote
Old 07-12-2009, 10:32 PM   #4
Probably not if an Inspector will be anywhere near that place in the future. They are neat, but climbable, outlawed years ago. And he'd have to build a landing outside the door and new steps, per code.
The hole in the siding on the side- that when you forgot your key? A little higher, I'd say it was from the knob.
Your house has a LOT of character.
Look at the good side---- I see grey primer, and only one coat of white! And new windows! Be safe, G
GBR in WA is offline   Reply With Quote
Old 07-12-2009, 10:43 PM   #5
Learning by Doing
DH and my contractor were lobbying to tear out the railings and replace it with 'real wall and siding'. I put my foot down on that one.
I will be replicating the railings. I'm committed to keeping the closed-in-porch look. Well, 'cause it's a closed in porch. Energy efficiency be-damned.
I will have to figure out the proper way to attach the newel post to the bottom step - something other than the angle iron the former homeowner used.
Wow! I hate the former homeowner.
GBAR - it's about eight coats of white paint on top of weathered wood (the grey). It's probably a mil thick in places!
I'll have to check with the inspector - I wouldn't mind a larger landing. But, I run into some problems changing certain things because it's a historic registry house. Funny, because I can't change some things only repair or replace as original. Like it was ok to replace the windows with ones that were the same style as the old ones, but I need approval from the historic board to make alterations.
Last edited by Leah Frances; 07-12-2009 at 10:49 PM. Reason: I'm not as smart as I used to be
Old 07-14-2009, 11:58 PM   #6
diy mike's Avatar
Nothing's classier than a peeling, rotting porch covered in plastic...
I'd be furious too.
Bet it's well worth the effort when all is said and done.
diy mike is offline   Reply With Quote
Old 07-15-2009, 06:13 PM   #7
Good for you.
We use heavy aluminum brackets on the inside of the post. I usually have them welded up out of 2" angle.
We do this kind of work every day. Historical precedence as it were, in keeping to the original design. The railing assembly can be easily made and I highly recommend a jig for cutting all the pieces. Once you get the angle the rest is easy. Honest!
Is your inspector working with/for the Historical Board or the city/county? Makes a difference.
Speaking from the side of the Historical Board. Whatever you do make nice with them. They can be your best resource for what is allowed/preferred Vs what they will accept.
We've been successful using designs, although not specific to the home, they are considered period style and if we provide photos of similar homes with what we want to use they often agree it would be an enhancement fitting the specific project. Having said that we do work with a local architect and that has always given us a positive in.
Just my 2¢
Shamus
Shamus is offline   Reply With Quote
Old 07-15-2009, 07:51 PM   #8
Learning by Doing
Just my 2¢
I bake brownies for the local historic boys. That, and I don't try and put jalosie windows in my 1805 colonial or paint the exterior hot pink.
Also, the former homeowner took such crappy care of the house that the neighborhood is DELIGHTED that I am mowing the lawn and raking the leaves. Heck, I might just be able to paint it hot pink, so long as I don't let the trash pile up for months at a time... One of my neighbors built a stockade fence so they wouldn't have to look at the house...
Old 07-15-2009, 08:37 PM   #9
Scuba_Dave's Avatar
The interesting thing with a lot of Historic districts is that they want the houses & area to look like what THEY want it to look like
In the next Town over - Hingham - they turned down a request a homeowner made to repaint his house - it wasn't "authentic" (?) to the time period
He came in with paint chips & pictures
It was the original color of the house
They didn't like it, but they could not refuse without a court battle
One house they would not let the owner do what he wants with the house
As a result he has let it fall part
Once it collapses (may have already) he can then rebuild the way he wants due to some law. IE if the house is standing you have to restore it, if not (collapsed) you can rebuild it with windows/design that are comparable to the period
Old 07-15-2009, 08:48 PM   #10
Learning by Doing
Yeah, Historic Boards can be worse than Homeowner's Associations. You definitely can't piss them off or they can and will make your life miserable. I am perfectly ok with keeping the house looking original. After all, I bought a 200 year old farm house, what am I going to do? Stucco it?
I am keeping a strict policy of getting my permits and keeping my nose down. Plus, I have the advantage of being a historic registry home, but my house is NOT in the historic district.
Also, I have an open door policy for the historic board guys - I've invited them to come see the things I am doing. So far, no one has taken me up on it, but the ego-maniacs that they are, I think they liked being asked.
Old 07-17-2009, 05:52 PM   #11
Sounds like your doing just fine.
A side note, you might want to look into joining the local Historical Society. I've found if it appears that you are not an advocate of all stuff "old" they can be a real pain. However, attend a few "outings" which are usually old house tours, and you will be surprised how down to earth, as well as informative they can be. I've been steered to many a deal for materials and furniture through those contacts.
Now it goes without saying, it is important to size up who your talking to. Some can be a real pain.
Shamus
Old 07-17-2009, 07:19 PM   #12
Learning by Doing
I got a FREE membership to the Talbot County Historical Society when we bought the house! They are an amazing resource and have an interesting library as well as tours etc. They even have the Historical Survey of the house that was done in 1976! The year I was born - so I know it was damn historic!
I should take some more pics about half the paint is off.
Old 07-18-2009, 08:09 PM   #13
motivator
Speedball's Avatar
That stair rail is beautiful, anxious to see pics in the future.
............Enjoy...Pat
Speedball is offline   Reply With Quote
Old 09-04-2009, 01:38 PM   #14
Learning by Doing
Here's the before:
Note the excessively scabby paint, the fiberboard surrounding the door, and the windows on the left that barely kept the rain, leaves, and critters out.
Here's the middle:
http://www.diychatroom.com/members/l...ior-middle.jpg
Note the new windows on the left (), the demolition around the door (WOW! that fiberboard was MILDEWED!), paint scraped down to the wood.
Here's the wow-we-might-actually-be-getting-somewhere-on-this-project:
Everything is primed, including the basement window sills, and today puttying commences. I still have a little bit of trim work to do, and to build the railings. I'm so glad this is finally coming together!
Old 09-04-2009, 01:55 PM   #15
Scuba_Dave's Avatar
Lookin' good !!
Is that hubby in the pic getting his hands dirty?
DIY Chatroom Moderator
Not a Pro or for hire, I have enough to do on my own house, Just Look !!
http://www.diychatroom.com/-ongoing-37438/
Please fill out Location in your profile (User CP), then we can answer your question
If a code reference is needed for one of my posts please access NEC 2008 & read
http://nfpaweb3.gvpi.net/rrserver/browser?title=/NFPASTD/7008SB
More On This Topic
If you’ve mastered the 180 and are comfortable in switch stance, then you should try tying lines together into 50-50s and boardslides. Once you’ve got those down, try the 180 to nose press. This quick inventory will get you started. Read More »
Grinds are a type of skateboarding trick. To do one on a rail involves sliding your board along it in a certain way. Grinding a rail on a skateboard takes practice. This skateboarding trick is all about the way you approach, the balancing of your weight... Read More »
One of the reasons why skiers, snowboarders and outdoors enthusiasts use skiboards is to do rail grinds. Rail grinds have been part of the skateboarding domain for years and involve the use of a specialized ramp to help skiboarders gain momentum. There... Read More »
History; now there's some historical events that are obviously more valuable than others, and you can remember what those events are. Think back to High School or Elementary School; when you talked about history. What were the events that marked your... Read More »
It's important that students realize the Civil Rights Movement was a combination of acts of protest, inspiring leaders and important legislation. The use of primary sources, audiovisual materials and photographs as well as dynamic activities can maintain... Read More »
Small Paint Project turning HUGE Freebmama Painting 1 02-24-2009 03:50 PM
Oil, Latex, Acrylic... How to Choose? Turkmenbashy Painting 4 01-18-2009 12:30 PM
Flashing NoExperience Painting 13 09-04-2008 06:56 AM
Semi gloss on Semi gloss mattpricemn Painting 6 08-25-2008 08:18 PM
Paint will not stick in Bathroom! SGTHetland Painting 9 08-18-2008 12:04 AM
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
