Replacing Doors In Masonry Wall - Project Showcase - Page 2 - DIY Chatroom Home Improvement Forum
Old 02-13-2011, 09:47 PM   #16
Originally Posted by Jim F View Post
They make wireless door bells. That would be much easier.
Didn't think of that, I 'll go check some out.
Dinggus is offline   Reply With Quote
Old 02-17-2011, 07:56 AM   #17
Rewards Points: 123
But I suspect that anything except the basic brickmolded door unit would cost more. When I was investigating just buying the door slab, the store guy said it would be cheaper to buy the unit and remove the slab from it than to order just a slab.
mwpiper is offline   Reply With Quote
The Following User Says Thank You to mwpiper For This Useful Post:
1982shawn (02-17-2011)
Old 05-12-2011, 08:00 AM   #18
Rewards Points: 123
Epilog
It's curious how two essentially identical installations can be so completely different. The front door continues to work perfectly. The side door has begun to jam right at the very edge. I'm assuming it is just the wood frame swelling as it warms up and gets humid. We've had lots of rain. Let me rephrase that. We've had LOTS of rain. and more coming today. So I'm having to sand the frame down.
The other option is that the urethane foam I bedded the door unit in is applying pressure against the frame causing to bow in ever so slightly. The frame is nailed to a 4" inside molding which I would have thought would have kept the frame from moving. But something moved. Hopefully we still have some of that paint left over in the paint stash.
anyone ever swap out interior doors without replacing the frames? diy'er on LI Building & Construction 11 01-08-2017 08:07 PM
knee wall attic access doors WillK Building & Construction 4 12-01-2010 07:32 AM
Raising Doorway Height (load bearing?) treefrog Building & Construction 6 02-25-2008 10:11 PM
Replacing hollow doors with 6 panel eehammar Remodeling 2 02-16-2008 02:27 PM
