Reflashing Chimney - Project Showcase - DIY Chatroom Home Improvement Forum
Old 01-02-2010, 08:17 PM   #1
Reflashing Chimney
The week after I bought my home I had a new roof put on, new shingles that is. Anyway about a year and a half later, I noticed some water spots on the ceiling drywall near the chimney. I researched the topic and decided to tackle the job myself. Here's the before and the progress.
Reflashing Chimney-dsc00609.jpg   Reflashing Chimney-dsc00610.jpg   Reflashing Chimney-dsc00594.jpg   Reflashing Chimney-dsc00598.jpg   Reflashing Chimney-dsc00597.jpg
knighton is offline   Reply With Quote
Old 01-02-2010, 08:20 PM   #2
A look from inside the attic. The sheathing was extremely water logged.
Old 01-02-2010, 08:31 PM   #3
Today, I began the task. I have read about, watched videos on and still wasn't exactly sure what I was getting myself into. Anyway, here's the photos of what I began.
Reflashing Chimney-dsc00620.jpg   Reflashing Chimney-dsc00619.jpg   Reflashing Chimney-dsc00617.jpg   Reflashing Chimney-dsc00621.jpg   Reflashing Chimney-dsc00622.jpg
Old 01-02-2010, 08:35 PM   #4
Once I got the sheathing off, I decided that I needed to strenghten the trusses that had been exposed to water. I also needed some additional backing for the new plywood sheathing.
Reflashing Chimney-dsc00629.jpg   Reflashing Chimney-dsc00632.jpg   Reflashing Chimney-dsc00635.jpg   Reflashing Chimney-dsc00636.jpg   Reflashing Chimney-dsc00639.jpg
Old 01-02-2010, 08:40 PM   #5
I had some sheet metal cut a couple of weeks ago in anticipation for this job.
It got dark on me and I wasn't able to finish the counter flashing, but I will tomorrow. And I'll post photos of the completed chimney.
Reflashing Chimney-dsc00640.jpg   Reflashing Chimney-dsc00641.jpg   Reflashing Chimney-dsc00642.jpg   Reflashing Chimney-dsc00643.jpg   Reflashing Chimney-dsc00649.jpg
Old 01-02-2010, 08:55 PM   #6
Tom Struble's Avatar
Rewards Points: 2,002
looking good
i like the cleats holding down the front apron
Tom Struble is offline   Reply With Quote
Old 01-04-2010, 12:42 PM   #7
Dorf dude...
shumakerscott's Avatar
Rewards Points: 1,190
Ugly Mess
That was one ugly mess you just fixed. Good job and your repair seems to be by my eye "Good to go." Keep it up, dorf dude...
Today is only yesterdays tomorrow, Now get to work!
shumakerscott is offline   Reply With Quote
Old 01-04-2010, 01:33 PM   #8
Chicago, IL
Michael Thomas's Avatar
That junction of the roof's rake and the uphill side of that style of chimney/roof junction is a difficult location to deal with as water will spill out over the roof edge and tend to back up against the chimney and run back up under the shingles. Also, concentrated water runoff running down the chimney at this location may damage the masonry. It would be nice see WSU along the rake. At a minimum make sure that there is drip edge along that section of rake, and if possible a flashing detail to prevent water backup. In my opinion, and based on my experience, a cricket directing that water over the edge uphill of the chimney and/or toward the inboard side of the chimney is a desirable detail at this location.
Home Inspections, Infrared (Thermal Imaging) Leak Identification and Inspection Services, Roof, Attic, Building, Basement and Foundation Moisture Intrusion and Water Leak Inspections, Troubled Building Consultations - Serving Chicago and Suburbs http://paragoninspects.com/
Michael Thomas is offline   Reply With Quote
Old 01-04-2010, 05:05 PM   #9
cricket not really needed on that small of a chimney,nice maybe
Old 01-04-2010, 07:21 PM   #10
Finished Photos
The only thing I have left to do is paint the exposed brick to match the house color (the black part above the counterflashing) The caulk hasn't fully dried yet. It's supposed to dry clear.
Reflashing Chimney-dsc01779.jpg   Reflashing Chimney-dsc01778.jpg   Reflashing Chimney-dsc01777.jpg
Old 01-04-2010, 09:42 PM   #11
Chicago, IL
Not required by code, but from a performance standpoint it's not the width of the chimney that creates a potential problem here, it's the design, which has the chimney extending past the rake and water running against the rake edge at the junction and then down the chimney.
And yes, that's a nice looking job - many "professionals" don't do as well.
Old 01-05-2010, 08:12 AM   #12
I don't know if I understand you correctly, but I think you're saying that you're not concerned with the "roof" side, but rather the area near the part of the chimney that protrudes from the house? You feel that water will run under that flashing?
If that's the case, and a cricket were placed there, I would think water could still run under the edge of the it unless it were protruding over the roof more?
There was no indication that water had done this before with its present design and it's been there since 1964. What I might do though, is seal the top of the facia where it abuts the bottom of the shingles to prevent water from entering. Maybe also seal the top of the shingle where it joins the flashing. I think I'll test it, then decide.
Thanks for your compliment and suggestions.
Old 01-05-2010, 02:38 PM   #13
Chicago, IL
Yes, my concern is with the "outside junction".
Fig. 1 What can happen when runoff is directed down the exterior of a masonry chimney.
Fig. 2 Close-up of same chimney, there was extensive water damage at the interior below this junction. This example is at an eave, but runoff at a rake can cause the same problem.
I have seen many instances of such problems at home and moisture intrusion inspections here in Chicago.
Old 01-05-2010, 04:07 PM   #14
that requires a kick out,that has nothing to do with a cricket
Old 01-05-2010, 04:29 PM   #15
Registered User
Rewards Points: 5,498
Very nice metal work! I would have concerns with the black paper and it's application. In the last picture of post 3, you cut the old paper in a stair-step fashion around the existing shingles. In the new paper you cut around the shingles like that again, but installed it over- not under the above paper. You can see the new plywood edge joint near the bottom after you papered and the new paper should go over the lower existing shingles.
The head flashing may direct water collecting there to the house side without a bead of roof tar to stop it's wicking/spilling when full. Look at the old head flashing piece, it's lost it's galvanized coating in the bend and extending towards the house. The head should have been cut before bending, not after, so the groove bend would have been flat or crimped to direct water down side of chimney. With the exist paper application, any water will wet the whole area where there is new paper.
A cricket, as Michael said, would solve this. Kick-out flashing is always on the rake, not the head.
Be safe, Gary
Chimney Confusion (Long) wehcyar Building & Construction 10 02-12-2017 06:16 AM
Is this a good method for repairing chimney crown/liner crack? meltdowndave Roofing/Siding 4 03-04-2010 07:56 AM
Roof leak around my chimney - update GlennAble Roofing/Siding 3 11-05-2009 06:24 PM
Roof Leak Around Chimney robertr4836 Roofing/Siding 3 03-11-2008 11:23 AM
Looks like leaking around the chimney - roofer says it is the chimney itself Salvatorparadise Roofing/Siding 6 03-07-2008 03:12 PM
