Range Hood (DIY) - Project Showcase - DIY Chatroom Home Improvement Forum
Old 10-18-2014, 10:01 AM   #1
MEASURE ONCE, CUT TWICE
123pugsy's Avatar
Rewards Points: 694
Range Hood (DIY)
I thought I should get a start on my range hood before I start construction. Hold ups during construction won't be good as I'll need to rent a house for a year only.
The outside will be black zinc with copper vertical bars and rivets.
The hood liner will be stainless with an 8" inline fan.
A friend cut out a couple of 1" thick MDF hammer forms for me on his CNC router.
I sanded of some of the patina so I could draw some layout lines for notching the corners.
I used a 1" round bar as a Sharpie guide to draw the line. I left an 1/8 - 1/4" extra for cutting an accurate line with the snips.
I did a practice piece and one edge ripped at the corner so I did another piece and drilled a small hole at the intersection of the bend lines and that seemed to work.
Will post pics of that later.
Pugsy.....my project: Total House Rebuild Bungalow to Two Story
123pugsy is online now   Reply With Quote
Old 10-18-2014, 05:41 PM   #2
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 1,770
Looks sharp.
Looking forward to more progress pics.
Old 10-18-2014, 06:41 PM   #3
123pugsy's Avatar
Rewards Points: 694
Thanks.
Here's the piece I did after the first test piece tore.
Leaving a thin strip for final cutting makes it easy with the hand snips.
When the piece was to size and corners drilled and notched, it was sandwiched between the hammer forms and knocked with a rubber mallet first and then a plastic mallet to get the bend nice and crisp.
Old 10-18-2014, 06:50 PM   #4
123pugsy's Avatar
Rewards Points: 694
I took a 2" strip of satin coat sheet metal and bent it into a curve by hand. The tight bend was made giving a little skim cut with the zip cut blade and then bending it by hand.
Holes were drilled every inch for rivets.
Then taken apart to countersink the holes.
After a bunch of "popping" and the side was done. I did a little hammer and dolly work on some of the rivets that stood proud.
I clamped a side piece onto my mock up front panel that I formed at work earlier this week.
I need to get another sheet of zinc for the front panel on Monday.
The Following 2 Users Say Thank You to 123pugsy For This Useful Post:
kwikfishron (10-18-2014), Windows on Wash (10-18-2014)
Old 10-24-2014, 09:01 PM   #5
123pugsy's Avatar
Rewards Points: 694
I got the front panel and the copper bars bent and rolled at the shop.
A sheet of aluminum on the back to keep the weight down.
And then a bunch more rivets.
I stopped to check out some patina on the bars.
I installed some poplar strips around the lower edge so the hood liner will have some where to screw.
Old 10-24-2014, 09:04 PM   #6
123pugsy's Avatar
Rewards Points: 694
The bars took a beating when I bent them. I used an undersized bottom die in the press to get a tight corner so it gouged quite deep.
A bit of grinding and buffing and all is well.
Old 10-24-2014, 09:09 PM   #7
123pugsy's Avatar
Rewards Points: 694
Then I had to stop and consider.
The top section of the hood is about the same depth as the cabinets. I was thinking of using crown molding at the top of the cabinets at the ceiling as they will go right up along with the hood. I thought I could run the crown across the hood and the cabinets so I set a piece of crown molding at the top of the hood and didn't think it looked right. I also mocked up a piece of crown molding that turned 90* into the face of the cabinet. That doesn't seem right either.
Don't know what I'm going to do now. I guess I'll have to move along and consider my options later.
Old 10-24-2014, 09:13 PM   #8
123pugsy's Avatar
Rewards Points: 694
A sneak preview shot.
I took a piece of scrap copper and hammered it and hit it with some patina and then Scotchbrite. Not sure what I think about this look.
Old 10-25-2014, 08:43 AM   #9
Really cool.
I dig metal work. Looking great so far.
Old 10-25-2014, 09:52 AM   #10
123pugsy's Avatar
Rewards Points: 694
Thanks.
I was just out in the garage threading rivets. At this point, I'm too afraid to start setting rivets with an air chisel.
Old 10-26-2014, 05:48 PM   #11
123pugsy's Avatar
Rewards Points: 694
Wow. Tough crowd around here.
I guess I'll have to show some better content, ha.
I drilled all the holes and got the bars set in place with all the rivets.
I then tore it apart to patinate and clear coat the bars.
I did the rivets also.
Old 10-26-2014, 05:50 PM   #12
123pugsy's Avatar
Rewards Points: 694
And now for the finished shots. Well, the outside shell anyways. I will get into the stainless liner later this week.
oh'mike (11-02-2014), r0ckstarr (10-28-2014)
Old 10-26-2014, 06:12 PM   #13
Renovating My Land Yacht
Rewards Points: 616
Pugsy, Wow - that is amazing work. Cannot wait to see it installed.
forcedreno2012 is offline   Reply With Quote
Old 10-26-2014, 06:52 PM   #14
123pugsy's Avatar
Rewards Points: 694
Thanks.
I can't wait either. That would mean that my new house was up.
Old 10-26-2014, 10:25 PM   #15
Rewards Points: 216
that looks really nice
you fab for a living ?
Fix'n it is offline   Reply With Quote
Range hood clearance to top of gas range less than minimum joemc3 Appliances 9 02-28-2013 02:42 AM
range hood opening is bigger than range hood jacks16 HVAC 2 06-23-2011 07:19 AM
Backdraft, Cold Air and Ice from Range Hood and Bath Fan Passion4Heels HVAC 13 08-19-2010 08:00 PM
Alternative to range hood fan Richo HVAC 2 04-11-2010 03:43 PM
Island Range Hood? fromwithin Appliances 0 11-25-2009 11:45 PM
