The Psychedelic Fishtank! - Project Showcase - DIY Chatroom Home Improvement Forum
Old 08-26-2009, 09:01 AM   #1
the Musigician
DangerMouse's Avatar
OK, so it's not a 60's rock band, but I thought I'd share a pic of it anyways.
I got these panes of glass off craigslist, and....
I razored off the frost and design on one side, leaving the mirror patterns.
Then I used the same design pane for the back wall.
Then it got framed in cherry somehow...
The wife loves it, the fish have had no comments at this time.
It needs a lid, but opinions seem varied as to whether or not it should have a light in it.
Some sources say light feeds algae, others say the fish like/need the light!
DM
The Psychedelic Fishtank!-1fishtank.jpg   The Psychedelic Fishtank!-1fishtankdone.jpg
Old 08-26-2009, 03:35 PM   #2
the Musigician
happy fish
DM
The Following User Says Thank You to DangerMouse For This Useful Post:
BigJim (10-13-2010)
Old 08-26-2009, 05:26 PM   #3
Household Handyman
Rewards Points: 1,408
And who says fish don't love art?
Old 08-27-2009, 12:57 AM   #4
Theres more then one way.
iMisspell's Avatar
Rewards Points: 150
That's pretty cool
~ What was once an opinion, became a fact, to be later proven wrong ~
My current learning experience - 22x22 addition - Work shop, music-room, master bedroom above..
iMisspell is offline   Reply With Quote
Old 10-12-2010, 10:07 PM   #5
Rewards Points: 266
Very unique. Seriously though, how did you seal those joints?
Jim F is offline   Reply With Quote
Old 10-13-2010, 07:41 AM   #6
the Musigician
SEAL them???!!!!??? I KNEW there was SOME reason the water kept coming out......
You mean the masking tape isn't good enough??? I thought the fish just drank too much.......
DM
Old 10-13-2010, 12:24 PM   #7
the Musigician
About 12 gallons.
DM
Old 10-13-2010, 07:18 PM   #8
Rewards Points: 147
My hobby is breeding tropical fish and I am an admin on Tropical Fish Hobbyist magazines online forum. If you have any questions let me know.
Here are some ideas. I paint the back glass on all my tanks..I have 5 running and two in the setup phase. It makes viewing the fish much better and hides cables and some equipment. What I would do with this is by a thin sheet of white arcrylic and fasten it tightly to the back glass (outside) of the tank. Then get a small low powered colored light and mount it somewhere behind the tank. It will look pretty cool. As far as the top light goes, most fresh water fish do not really need light but it is much easier to view a lit tank. I only use my lights when viewing. Although if you have plants you will need light.
What did you seal it with? Also what filtration are you using?
Hurriken is offline   Reply With Quote
The Following User Says Thank You to Hurriken For This Useful Post:
tpolk (10-14-2010)
Old 10-13-2010, 07:29 PM   #9
the Musigician
I used 100% silicone aquarium sealer, (of course,) and the cherry frame reinforces it more than enough.
It's just 2 old goldfish, but we just clean it out every few months and clean the marbles and gravel.
We have crystal clear well water, so there's no waiting for them to get back home. Po)
The back pane is clear glass with a frosted piece of the same pattern as the mirrored front behind it, so it darkens it a bit.
DM
Old 10-13-2010, 10:41 PM   #10
Rewards Points: 147
Sounds really cool. Thanks for posting it...I love fish!
Old 10-13-2010, 11:16 PM   #11
Wire Chewer
Red Squirrel's Avatar
Rewards Points: 72
That looks pretty cool!
One thing I've always thought would be awesome is an in-wall fish tank. I think my biggest issue is I would forget to feed the fish and they would die. *gets childhood memory of flushing goldfish down the toilet*
Old 10-14-2010, 10:48 AM   #12
nice tank dm
The older I get the better I was
Old 10-14-2010, 02:52 PM   #13
jules4's Avatar
That is awesome!
Light does feed algae, but the fish do like it and the tank will look waaaay better with a light on.
If you use a small, low power light you can limit the algae while still getting to enjoy your tank in its full glory. (Plus algae are not entirely without benefit since they consume nitrates, the end product of your tank's biological filtration.)
jules4 is offline   Reply With Quote
The Following User Says Thank You to jules4 For This Useful Post:
Polywanna (10-23-2010)
Old 10-23-2010, 04:49 PM   #14
That looks like a genuine arts and crafts thing, simply gorgeous!
Polywanna is offline   Reply With Quote
Old 10-31-2010, 09:08 PM   #15
Ole Wood Worker
BigJim's Avatar
Rewards Points: 202
That is sharp DM, maybe you could sell some of those.
New members: Please consider adding your location to your profile.
If you do what you've always done, you'll get what you've always got.
http://www.woodworkingtalk.com/forum.php
Jim
BigJim is online now   Reply With Quote
How to properly support joists for a large fishtank michaelbarron Building & Construction 8 12-07-2008 12:21 AM
