-   Project Showcase (http://www.diychatroom.com/f49/)
-   -   Privacy Screen for Backyard Pool (http://www.diychatroom.com/f49/privacy-screen-backyard-pool-146469/)
Jim F 06-08-2012 10:00 PM
I am putting a basic privacy screen between my pool and some very problematic neighbors. I would like to eventually get privacy in my entire back yard. For now though, if we can at least swim in peace I'll consider that a gift.
This is really just a minor project. I felt it was worth contributing to the site mostly because I could not find any ideas online to help me go about what a I have planned. Pictures will follow soon.
I started with an idea to set three 4x4x10 posts 2ft down with concrete to give me 8 ft above ground. I figure the concrete will give me adaquate stability. I also purchased 2 PVC diagonal mesh screens. My plan was to fasten these directly to my three posts.
I have already set the posts today, 8 ft apart. Something didn't seem quite right about my plan. I decided that I need to add back rails to the top and bottom of these mesh screens so I am planning to buy more lumber tomorrow.
I have one question at this point.
It seems that PT 2X2's would be adaquate for back rails. I think 2x4's might be too heavy for my application. 1X3 or 1X4 rails would be ideal, but I don't think I can find them pressure treated, at least not locally. I am looking for suggestions on the rails.
Jim F 06-09-2012 09:00 AM
3 Attachment(s)
Pictures as promised. It wasn't supposed to rain today but the concrete is set and the holes got filled in after the pictures.
I found these instructions online Vinyl Lattice Fence Building Instructions I guess It's a matter of asking the right question. This site recommends 2x6 rails. I think 2x4 will be adequate.
Jim F 06-11-2012 08:14 AM
6 Attachment(s)
Privacy accomplished! This was the original but now my wife wants me to continue the lattice to the ground which means two more pieces and one more bottom rail. I did not take progress pictures as I worked yesterday. We went from cold, rainy weather Saturday to brutally hot and humid yesterday. I just wanted to get it done so I could take a swim. My plan is to take down the lattice and lower rails in the off season.
I may or may not post more pictures if and when I add the bottom lattice. I sort of like the idea of being able to see that part of the pool from the porch. I would appreciate comments good or bad.
no1hustler 06-11-2012 10:35 AM
Creepo neighbors spying on you or something?
hyunelan2 06-11-2012 11:00 AM
I'm imagining a creepy old guy in the window with binoculars, as his wife is in the pool. That screen definitely gets the point across of "this is meant for you not to see us."
pwgsx 06-11-2012 11:40 AM
Looks good but yea, tell us what your neighbor is doing.......
CoconutPete 06-11-2012 12:02 PM
Looks like it will do the job, but have you started looking at trees yet? I remember this problem being around for a while, that's all time they could have been growing.
Jim F 06-11-2012 10:34 PM
Yes that's the back story. These people are A-holes. See http://www.diychatroom.com/f16/priva...ns-pics-71137/
Still weighing my options for better privacy solutions. Currently consider ing more trees like the one I have. I thing the Green Giants will get too big.
shumakerscott 06-11-2012 10:59 PM
Use Bamboo or Elephant grass. dorf dude...
Jim F 05-29-2013 10:34 PM
2 Attachment(s)
I was going through old posts and realized I never posted a picture of the completed fence. My wife had me add two panels to the bottom because it looked unfinished. Now planning to add some sort of vine plant to make it blend in. The good news is the problem tennants got kicked out and I've worked things out with the homeowner next door. Still, I like my privacy while swimming.
I had mounted these panels with all wheather screws into the mesh. These don't allow any movement so they are now starting to pop free. So now I'm looking for some sort of materials or fasteners I can us that will allow movement.
Any ideas.
ddawg16 05-29-2013 10:39 PM
I was going to suggest you invite a bunch of fat ugly friends over...give them the keys to the house and leave....tell them that skinny dipping is ok....
Blondesense 05-30-2013 08:33 AM
I like the idea of a vine, I think it would look good, but I'd talk to a local plant nursery or ag office regarding the choice. You want something fast growing enough to look good in one season if you plan on taking the lattice down in the winter.
And don't forget the blooms and pollination. While a flowering vine would look awesome, you probably don't want something that will attract bees from all over the state while you're out there splashing around.
wkearney99 05-30-2013 10:04 AM
Be aware that many areas have zoning restrictions on how high you can make a fence.
Another idea would be to install a pergola over there and encourage something like a grape vine to grow on it. That would have it's end as high as the existing fence and the leaf cover over it would provide the same degree of privacy to the pool. All without being a 'fence' per-se, and you'd get another shaded area in the yard.
handyman_20772 05-30-2013 10:49 AM
Any ideas.
There is a fastener (screw w/a built-in washer) made for plastic lattice that allows for expansion and contraction of the material, it should be in the same location as the lattice at the big box store.
wkearney99 05-30-2013 11:59 AM
A lot of the time that lattice is installed in a frame and the frame is anchored. You leave enough gap around the lattice in the frame channel to allow for expansion/contraction.
For your setup it might be easily solved by boring out the holes in the lattice a bit. Then reinstall the screws but with a washer under the head. This would keep them tighter to the surface but still allow some sideways expansion. Some nylon or plastic washers might be best, but you'd want to get ones that has some degree of UV resistance. Otherwise exposure to the sunlight would degrade them over time.
