Portland, OR, Accessory Dwelling Unit - Project Showcase - DIY Chatroom Home Improvement Forum
Old 02-08-2010, 10:45 PM   #1
General Contractor
We are in the middle of a 1,700 sq. ft. build here in Portland. I will throw a few pictures up here, but the owner is a partner at marketing firm, so his blog on the build has a little more polish than I can manage. It's at portlandbuilt.com.
  • 1700+ sq ft on two levels
  • advanced framing practices
  • slab on grade construction incorporating uncommon slab insulation details
  • utilities under and through stem walls to minimize wall penetrations
  • radiant heat in the slab and in a 1 1/2 ” poured gypsum underlayment on the second story
  • distance from the street and lack of dedicated driveway requires a residential fire sprinkler system
  • robust sheathing system comprised of 1/2″ plywood, tyvek house wrap, vertical tongue and groove and horizontally shiplapped 1″ xps foam insulating sheathing, fiber cement siding and “to the plywood” flashing above all penetrations
Cheers,
Rory
RDG Read Development LLC
Portland, OR
Portland, OR, Accessory Dwelling Unit-img_1766.jpg   Portland, OR, Accessory Dwelling Unit-img_2548.jpg   Portland, OR, Accessory Dwelling Unit-img_2593.jpg   Portland, OR, Accessory Dwelling Unit-img_2686.jpg   Portland, OR, Accessory Dwelling Unit-busse-adu-wrapped-xps.jpg
Rory Read is offline   Reply With Quote
Can't get unit to turn on need electrical help please-wiring diagram included igotshocked Electrical 33 01-30-2014 06:13 AM
Ruud Pack unit "KABOOMS" upon First Light Up of the Day! Wirenut2tite HVAC 18 12-15-2012 11:11 AM
AC condensing unit failure? Hotinsummer HVAC 3 08-09-2009 03:08 PM
central unit will not come on ....please help guyasc HVAC 5 08-24-2008 06:10 PM
Wall unit AC drips water inside fw2007 HVAC 4 08-15-2008 11:07 AM
