Porcelain Tiles On Sun Deck - Project Showcase - DIY Chatroom Home Improvement Forum
Old 06-10-2013, 09:47 PM   #1
Porcelain Tiles on sun deck
First off, I am new to this forum. I just moved into a (new to me) 2 year old home. The back sun deck (10 feet above grade) is covered with 18 x 18 ceramic tiles. My building inspector said this is a poor choice for a deck surface and that there are some cracks in the grout. He told meI should remove all grout and regrout, and, worse yet, that this could become annual maintenance.
I am suspecting this cracking is due to some movement in the underlying structure, however, no tiles are cracked. Should I try using a sanded caulk instead of grout? Or regrout with sanded grout? Or?
I really don't want to remove all the tiles and switch to a vinyl, at least not now.
Thanks,
Tom
Firehoser75 is offline   Reply With Quote
Old 06-10-2013, 09:53 PM   #2
Rewards Points: 13,446
Post a picture and also go back and add your location to your profile.
Ok so what's under the tiles? A slab, wooden deck?
Old 06-11-2013, 09:27 AM   #3
Handyman
Yes, please post more info on your project.. Good luck, let us know how things are progressing soon!
nicktools561 is offline   Reply With Quote
Old 06-11-2013, 09:59 AM   #4
Thanks for replying so quickly. I live near Vancouver, BC, Canada. The deck is a wood frame deck cantilevered from the house and other than the eaves, it is not covered. It has a northwest exposure. The underside of the deck is completely enclosed by metal soffiting material so I cannot easily see the construction details, but I would expect 2x10, 16 inch on center covered with either plywood or OSB sheeting. From what I can see looking at the side profile, the sheeting looks to be about 1.5 inches thick.
I have only been in the house for 3 weeks, so still unpacking, getting settled, etc. and am looking to regrout this in September when I get back from summer trip. The grout cracking is not severe, but there are places where pieces are "missing" to a depth of about half way down (a few places) and a few others where there are small cracks visible. My building inspector, used during the purchasing process, said the grout needed replacing. No tiles are cracked that I can see. I am hoping not to have to cut out the grout and redo it too often. Not as young as I used to be More info, the longest span is 11 feet. The deck is approx. 11 x 33.
Hope this gives enough info for you to be able to give suggestions and advice.
Thanks,
Tom
Old 06-11-2013, 11:14 AM   #5
Amateuralex's Avatar
Rewards Points: 270
They must be porcelain tiles? Aren't ceramic tiles sure to crack in freeze/thaw because they absorb water? Won't grout do the same thing? When you said a tile deck I just assumed you lived in Florida or something.
Amateuralex is offline   Reply With Quote
Old 06-11-2013, 11:50 AM   #6
funfool's Avatar
Rewards Points: 534
Welcome aboard firehoser.
Not suggesting you did anything wrong, just for your own benefit you are posting in the wrong section.
If you scroll down to the bottom of the page you will see forum jump, click on the down arrow and scroll down and will see the tiling ceramics marble section.
There is where you will get the most benefit.
Project showcase where we are, is not really for questions so much as it is to show others what they did, show off a project they are working on.
You can see where it would be to your benefit to re-ask the question there, or maybe a forum moderator will come along and be kind enough to move your question there.
funfool is offline   Reply With Quote
Old 06-11-2013, 12:56 PM   #7
Oops
Thanks Fun for pointing out my mistake. I am not finding this site easy to navigate and have spent most of my time (prior to posting) just conducting searches, but unable to find specific answers for me.
I hope an administrator moves this, if appropriate, otherwise, I guess I will have to re-enter my question.
Tom
Old 06-11-2013, 01:03 PM   #8
Not A lot of Freezing Here
Amateur,
Here in Nanaimo, right on the ocean, we don't usually experience any significant freezing. Every few years we may get a week of freezing temps (daytime) and our average overnight low during the winter is about 35 degrees. Very similar weather to Seattle. I do think the tiles are porcelain.
Regards,
Tom
Old 06-11-2013, 01:36 PM   #9
Rewards Points: 270
Originally Posted by Firehoser75 View Post
Amateur,
Regards,
Tom
Interesting, OK. If this thread gets to the tile subforum, or you start another thread there, the guys there will immediately know if climate could be a cause, tho to me it sounds like deflection is probably your problem. The other guys will know better.
Old 06-11-2013, 02:02 PM   #10
Bill Kearney
Rewards Points: 1,174
Yeah, tile is heavy and it takes a very stiff structure under it to handle the weight of it. Then add the weight of a lot of people moving around and you're really asking for problems with cracking. Snow would add even more weight.
Grout is relatively cheap. If you want to make it look better 'for now' then Just fix it. But start figuring out what you would rather have there instead, and start budgeting for it.
wkearney99 is offline   Reply With Quote
Porcelain tile outside over wooden deck porch SEYON General DIY Discussions 38 10-22-2014 08:49 PM
Cedar deck help mickbiv Painting 11 08-08-2013 09:21 PM
Fasten deck board from under deck resonator Carpentry 14 09-20-2010 10:15 AM
Deck Staining thread but I am desperate- please help mickbiv Painting 3 09-08-2010 12:28 AM
calking backer board to tub glassman General DIY Discussions 13 06-19-2008 08:41 PM
