Please Give Me Some Budget Friendly Ideas Of How To Make This House More Stylish - Project Showcase - Page 2 - DIY Chatroom Home Improvement Forum
Old 06-07-2013, 06:52 PM   #16
r0ckstarr's Avatar
Rewards Points: 2,060
Originally Posted by Bennylava View Post
Hmm I hadn't given much thought to the "style".
Style is what is new and popular. Style changes every few months.
Find things YOU like, and go with that. Create your own "style". There's no set template that you have to follow. Spend plenty of time researching what can be done, what you can handle, and how to do it.
Remember. Home improvement goes in these steps.
1. Make it safe.
2. Make it reliable.
3. Make it pretty.
r0ckstarr is offline   Reply With Quote
Old 06-08-2013, 12:39 AM   #17
Rewards Points: 87
Thanks for all the help and replies everyone. I will be taking all advice. It all sounds like good advice to me. Most of what has been mentioned, I was already planning to do. I was not sure if I had thought of everything though.
Originally Posted by ddawg16 View Post
Question.....do you have gas? If so...start thinking about swapping out that stove and oven....gas will save you a boat load of money
Yes the house does have gas. As do I. But I was told that these days, gas really isn't all that different from electricity in price. Don't know if its true or not.
Originally Posted by wkearney99 View Post
Which will be the perfect time to get rid of that awful electric cooktop and hideous drop-in sink.
What other type of sink would you recommend? Are there better ones to go with besides drop-in?
Bennylava is offline   Reply With Quote
Old 06-08-2013, 05:42 AM   #18
Bill Kearney
Rewards Points: 1,174
Which sink is purely a matter of what your style prefers. I like undermount sinks as they don't provide that nasty lip for crud to collect under. But they do require a very precise cut-out of the opening. A drop-in doesn't require that, which often makes the install of them less expensive as the hole can be cut in the field and not have to look perfect. But if you're going to spend some money on the counter you'd just get them to cut the hole while fabricating the top.
I don't know anyone that has gas cooktops that ever wishes they had electric. I've known plenty that hate electric. Yes, electrical induction tops are versatile but they require very specific kinds of pots. So unless you're certain your existing pots will work then you've got to buy all new ones to work with induction. We went with a GE 48" gas unit for our new kitchen.
If you're faced with budgetary limits (and who isn't) then if you 'have to' keep something just make sure the opening it needs can be filled by something new. As in, if you have to keep the cooktop then just make sure what newer models would fit in the same (or larger) hole.
It's better to spend money on the overall design of the kitchen than on the appliances themselves. The appliances can always be replaced/upgraded but a bad design can really ruin how usable the kitchen might be.
wkearney99 is offline   Reply With Quote
Old 06-09-2013, 12:39 AM   #19
Rewards Points: 87
But aren't you going to have some kind of lip with an under mount sink as well? Not very familiar with them.
Old 06-09-2013, 07:17 AM   #20
Bill Kearney
Sure, there's a seam between the underside of the counter and the sink. But that's a lot different than the edge that sticks up on top of a counter when you use a drop-in. That lip tends to catch all kinds of filth. That and you don't have an easy way to sweep any liquids into the sink (either spills or while cleaning). Eventually anything you use to seal that drop-in to the sink will fail, potentially leading to leaks that damage the counter and cabinets below.
The only place we'll be using a drop-in will be for a utility sink. That provides a way to use the edge of the sink as part of the work process. We're going to use this one: Mustee Vector 25. The molded drain edge should come in handy for that sort of sink.
Old 06-14-2013, 08:32 AM   #21
Rewards Points: 274
If you like that attending again at atomic amend the colors. Whether or not you accumulate the abuse is up to you. And, of course, plan on replacing all the window treatments.
alexjoe is offline   Reply With Quote
Old 06-17-2013, 01:18 AM   #22
Great looking house you got there, though you’d need a couple of things to make it look better. How about adding window frosting on the windows and doors? You don’t need to completely frost them, and there are frosting designs you can apply on them too.
patrickbuzacott is offline   Reply With Quote
Old 06-17-2013, 02:39 AM   #23
mrs fix it's Avatar
I wonder what your obsession is with frosting windows!
mrs fix it is offline   Reply With Quote
The Following 2 Users Say Thank You to mrs fix it For This Useful Post:
creeper (06-17-2013), r0ckstarr (06-17-2013)
Old 06-17-2013, 05:40 AM   #24
r0ckstarr's Avatar
Spammer.
Cape Cod Style House Attic/Crawl Space Insulation Help Danielg Insulation 24 05-21-2012 08:20 AM
NEED HELP WITH IDEAS for remodeling a entire home 2100sq ft 2 stories *Many pictures* BleachCola Remodeling 26 08-23-2008 06:15 PM
Complete AC installation in Old Capitol Hill Row House jacko10 HVAC 0 09-18-2007 05:42 PM
How to make slope grade away from house? ans630 Landscaping & Lawn Care 7 04-06-2007 09:58 PM
Will my house make my kids sick??? jokrupinski General DIY Discussions 18 09-29-2006 04:05 AM
