Picture Molding Wainscot In Foyer And Stairway - Project Showcase - Page 3 - DIY Chatroom Home Improvement Forum
Old 02-12-2012, 08:18 PM   #31
Rewards Points: 97
Looks Great!
I have some in one hallway from when i bought the home, But I want to extend it into the dining room, ( Do they go well in living rooms ? )
and the other hallway. atleast....
Firefighter3244 is offline   Reply With Quote
Old 02-12-2012, 08:28 PM   #32
Rewards Points: 13,732
To figure the angles I use one of these laying on a 2 X 4 on the treads.
http://www.starrett.com/industries/p...ter-cut-errors
It tells you the exact angle to cut a single or double bevel.
Old 02-17-2013, 12:19 PM   #33
Miter Angles
Those frames look great. I am nearly ready to throw myself down the stairs because I cannot get my miter angles for the stair slope to meet up. Any tips?
cedaly1968 is offline   Reply With Quote
Old 02-17-2013, 01:44 PM   #34
Ole Wood Worker
BigJim's Avatar
Rewards Points: 398
Use a scrap piece of the mold and trace the top and bottom lines on the wall let the end run wild then trace the other piece to cross the other one you drew, see where they intersect, now just transfer the points to the scrap and cut, look at the angle on the saw and cut the good molding the same.
New members: Please consider adding your location to your profile.
If you do what you've always done, you'll get what you've always got.
http://www.woodworkingtalk.com/forum.php
Jim
BigJim is online now   Reply With Quote
The Following User Says Thank You to BigJim For This Useful Post:
cedaly1968 (02-20-2013)
Old 04-29-2013, 05:25 PM   #35
What moulding?
So you just painted the wall and attached the picture frames to that? No plywood or paneling first? What type of moulding do you use for the picture frames. Everything I have found is notched on one edge to hold glass for a picture... This will leave a gap on the wall. Any help is appreciated!
adam.johnson25 is offline   Reply With Quote
Old 05-02-2013, 03:55 PM   #36
kimberland30's Avatar
I love the look of this and might see if the hubs is willing to tackle another project. He's going to ban me from these boards one of these days.
You stated that you put the frames 3" from the bottom of the chair rail and 3" from the top of the baseboard, and 3" apart. Did you measure down the length of the wall to get your frame size, or did you come up with a standard size and cut it to fit? I'm curious because in your photos it looks like it goes wall-to-wall in perfect symmetery. Of is there a frame closer to the end of the wall that isn't the same size as the others? Do I make any sense?
kimberland30 is offline   Reply With Quote
Old 05-02-2013, 05:49 PM   #37
Ole Wood Worker
BigJim's Avatar
Rewards Points: 398
I didn't paint the walls first on my jobs, I always laid it out on the walls so there wouldn't be mistakes, pencil marks don't look good over fresh paint. You can glue and pin the molding to the sheet rock wall, the trick is to angle the nails, don't shoot straight in. You will probably want to prep the molding by caulking and filing the sprig holes before you paint also.
Kinberland30, measure your wall and divide the number of boxes you want, then just do the math and lay out the wall and see how you like it, if you feel the boxes are too small or too large just take one or two off or add a couple then do the layout again.
Jim
Old 05-02-2013, 06:55 PM   #38
Thanks! Another question...I have plaster walls (aka uneven surface) so maybe I'll have to caulk around all the trim for it to be nice and flush against the wall? A job like that might convince me to keep the walls as they are.
Old 05-02-2013, 10:33 PM   #39
Ole Wood Worker
BigJim's Avatar
Rewards Points: 398
On plaster walls you could have some problems as you said, and the plaster could chip and crack also. If you ever decided to remove the trim you could really have a mess to repair, unlike drywall, the plaster is much less forgiving.
Jim
Old 05-03-2013, 09:03 AM   #40
Did the molding you used have the lip on one side because it is actually for picture frames? Did you just caulk that gap after it was on the wall?
Old 05-03-2013, 12:01 PM   #41
Ole Wood Worker
BigJim's Avatar
Rewards Points: 398
These aren't my pictures posted earlier in the thread. When I was in business the mold did not have a lip, it was flat on back. In the lower part of this link there are several moldings which have a clover leaf look, these are basically what I used, you can also use a base cap.
http://www.interiortrimandsupply.com/trimmiscmold.htm
Jim
Old 05-03-2013, 02:50 PM   #42
Yeah, we have to repair patches anytime we remove a nail. Joy.
Old 05-03-2013, 09:25 PM   #43
Jack of all - master none
hyunelan2's Avatar
Rewards Points: 692
I was the one who created this thread, and that's my foyer/hallway in the pictures. "Panel molding" is what I used, straight off the shelf from home depot. It is in the store by their prefinished moldings.
This might have been what I used, hard to tell without looking at it.
http://www.homedepot.com/p/Ornamenta...8#.UYRxVJwo5Co
hyunelan2 is offline   Reply With Quote
The Following 2 Users Say Thank You to hyunelan2 For This Useful Post:
BigJim (05-03-2013), oh'mike (05-04-2013)
