Picture Molding Angles Question - Project Showcase - DIY Chatroom Home Improvement Forum
Old 09-20-2013, 08:50 AM   #1
Picture Molding angles question
Hello,
I started working on my picture molding on the foyer (as seen on the picture below). As you can see I got stuck on one picture molding right next to the stairs. My question is how do I get the angles to cuts correct using a miter saw so they butt up correctly?
TommyDIY is offline   Reply With Quote
Old 09-20-2013, 09:58 AM   #2
Ole Wood Worker
BigJim's Avatar
Rewards Points: 768
If you don't do this type work every day I would suggest making a template to place on your miter saw to be able to cut the sharp angles safely.
New members: Please consider adding your location to your profile.
If you do what you've always done, you'll get what you've always got.
http://www.woodworkingtalk.com/forum.php
Jim
BigJim is online now   Reply With Quote
Old 09-20-2013, 12:06 PM   #3
Rewards Points: 77
you can also try an angle finder. They're anywhere from 5 to hundreds, but the cheap ones are just as good.
When doing something new or tricky, always practice on scrap wood first as well.
dengle is offline   Reply With Quote
Old 09-20-2013, 05:47 PM   #4
Rewards Points: 14,290
This is what I use.
http://www.amazon.com/Starrett-505P-.../dp/B003CJSQ4S
Picture molding wainscot in foyer and stairway hyunelan2 Project Showcase 42 05-03-2013 09:25 PM
Plumbing Rough-in Question 325_man Plumbing 4 12-30-2012 07:31 PM
yet another attic kneewall question with picture brianxmurray Insulation 4 12-29-2012 01:28 AM
yet another attic kneewall question with picture brianxmurray Insulation 0 12-28-2012 10:51 PM
Crown molding angle question Lavid2002 Carpentry 35 08-24-2012 06:05 AM
