-   Project Showcase (http://www.diychatroom.com/f49/)
-   -   Picture Molding angles question (http://www.diychatroom.com/f49/picture-molding-angles-question-187307/)
TommyDIY 09-20-2013 08:50 AM
1 Attachment(s)
Hello,
I started working on my picture molding on the foyer (as seen on the picture below). As you can see I got stuck on one picture molding right next to the stairs. My question is how do I get the angles to cuts correct using a miter saw so they butt up correctly?
BigJim 09-20-2013 09:58 AM
If you don't do this type work every day I would suggest making a template to place on your miter saw to be able to cut the sharp angles safely.
dengle 09-20-2013 12:06 PM
you can also try an angle finder. They're anywhere from 5 to hundreds, but the cheap ones are just as good.
When doing something new or tricky, always practice on scrap wood first as well.
joecaption 09-20-2013 05:47 PM
This is what I use.
http://www.amazon.com/Starrett-505P-.../dp/B003CJSQ4S
