Our Renovation Reality 2012 - Project Showcase - Page 4 - DIY Chatroom Home Improvement Forum
Old 03-03-2014, 02:18 AM   #46
Chewbacka's Avatar
Rewards Points: 77
Get combined smoke and CO units and they will have blinking lights to show status. BRK is what is most used in residences, wired, with battery backup. Good for 5 years, then replace. Add heat of rise in garage, near furnace and in attic, not std smoke/CO; to cut false triggering. CO at top of cellar stairs.
Wire in Cat5e and cable rough in to anywhere you might use it now or later, wireless is varied success based on distance, obstructions, etc.
The cement board in the bath is NOT waterproof. You need to add a sealer or Ditra orange waterproof membrane over the cement-board BEFORE setting any tile, and possibly a bonding agent too. Check with a tile store who know what they are talking about..
Get or rent a spray paint machine, and spray from 5 gallon pails for primer, ceilings, etc. Use mold resistant paperless sheetrock in baths, wet areas.
Try a textured ceiling application, best applied by a 'rocker' who does finish ceiling work, it will cut way down on imperfections of the rock install.
It's coming along!
What's going to run your sump when the power is out?
Chewbacka is offline   Reply With Quote
Old 03-03-2014, 04:59 PM   #47
garlicbreath's Avatar
Rewards Points: 150
All great tips. Thank you.
I stopped with the bath, waiting for the drywall to finish. I got special tape and the thin set mud for cement board. Then I'll red gaurd it. I'll then start with tiling and I got questions for that project, save them for another day. I did make sure the cbu extended below the lip of the tub. I decided against green board or blue board. Can't remember why but when I was researching the general concensus plain is fine.
My power quality is good here, I'll drop a back up dc motor into the unit when we finish the basement.
Thanks again.
Sent from my Motorola MicroTAC 9800X
garlicbreath is offline   Reply With Quote
Old 03-03-2014, 05:38 PM   #48
Chewbacka's Avatar
Rewards Points: 77
Thanks again.
No problem. I'd get a Panasonic bath fan. H/L/V (heat,light, vent) models are the best; and if you can go through the wall instead of the roof with insulated flexible metal or rigid metal ducting if you have space to fit it. There are also auto shut type exterior closures with a drop down cap inside the vent to prevent air leakage WAY better than alum flapper type. The link below also has further down the page other units that can go through eaves or roof if necessary.
http://www.truevalue.com//catalog/pr...7Bplacement%7D
You won't regret the heat feature and wife and kids will love it too. Put the fan and light on one timed switch and heat on another with timer, (rated to amp load).
Or put timed floor heat pad in under tile near bath/shower.
Old 03-03-2014, 09:11 PM   #49
Rewards Points: 150
I installed a quiet fan vented through the roof. The flapper is built into the roof part. We're installing floor heat. Never had that before! Excited for that feature.
Old 03-04-2014, 02:25 PM   #50
Rewards Points: 150
Progress!!!!
Old 03-16-2014, 03:12 PM   #51
Rewards Points: 150
Primer, 2 finish coats on the ceiling. Smooth as a baby's bum bum.
PPG flat. Looks a like it has gloss with the lighting. It as flat as can be
Old 03-16-2014, 03:19 PM   #52
Rewards Points: 150
Progress in the bath. Tape and mud with the mortar. First time I ever mixed and used that stuff. Turned out good. Ill slap the red gaurd in this week.
I built a protection device for the tub. I have padding underneath.
Old 03-17-2014, 02:27 PM   #53
Rewards Points: 150
1st coat of Red Gard. I'm loopy now, stinks to high heaven.
Old 03-18-2014, 03:25 PM   #54
Rewards Points: 150
2nd coat of red gard applied and loopy once again.
Old 03-22-2014, 04:21 PM   #55
Rewards Points: 150
Walls primed.
I used aboit 10 feet of tape for a weird transition and to protect the wood on the stairs.
Cut everything by hand it looks awesome.
COLOR TOMORROW!
Old 03-23-2014, 07:14 PM   #56
Rewards Points: 150
Color!
Old 03-30-2014, 03:13 PM   #57
Rewards Points: 150
Our Renovation Reality 2012-uploadfromtaptalk1396210335980.jpgOur Renovation Reality 2012-uploadfromtaptalk1396210350369.jpgOur Renovation Reality 2012-uploadfromtaptalk1396210364406.jpgOur Renovation Reality 2012-uploadfromtaptalk1396210375591.jpgOur Renovation Reality 2012-uploadfromtaptalk1396210387391.jpgOur Renovation Reality 2012-uploadfromtaptalk1396210399550.jpg
Old 03-30-2014, 03:16 PM   #58
Rewards Points: 150
Our Renovation Reality 2012-uploadfromtaptalk1396210484343.jpgOur Renovation Reality 2012-uploadfromtaptalk1396210499071.jpgOur Renovation Reality 2012-uploadfromtaptalk1396210513072.jpgOur Renovation Reality 2012-uploadfromtaptalk1396210526040.jpgOur Renovation Reality 2012-uploadfromtaptalk1396210549090.jpgOur Renovation Reality 2012-uploadfromtaptalk1396210561495.jpg
Old 03-30-2014, 03:17 PM   #59
Rewards Points: 150
Finish coats done on the walls and ceilings.
She said she wanted to feel like she was walking through the Crayola factory.
Old 03-30-2014, 03:45 PM   #60
MEASURE ONCE, CUT TWICE
123pugsy's Avatar
Rewards Points: 982
I think you've achieved that look.
Pugsy.....my project: Total House Rebuild Bungalow to Two Story
123pugsy is online now   Reply With Quote
The Following User Says Thank You to 123pugsy For This Useful Post:
garlicbreath (04-27-2014)
2012 Workshop to Apartment Renovation Contractormedic Project Showcase 14 08-19-2012 12:20 AM
My First Bathroom Renovation...Help Needed! JadRutherford Building & Construction 29 07-27-2012 06:49 AM
Complete renovation Curb Feeler Remodeling 18 08-24-2010 05:46 PM
Basement Renovation Planning: Help! navi_jen Plumbing 0 06-16-2010 09:41 AM
