-   Project Showcase (http://www.diychatroom.com/f49/)
-   -   Our new fireplace - Easier said than done. (http://www.diychatroom.com/f49/our-new-fireplace-easier-said-than-done-46671/)
Kiwi. 06-15-2009 11:03 AM
We decided that we wanted to put stone (veneer) up around our fireplace, and the fourteen foot wall that surrounds it. I did a lot of research on the internet about products and application techniques. There are a few people out there that had just gone the 'construction adhesive' route and essentially glued the stone to plywood. To do that I'd have to replace drywall with plywood, which I didn't want to do, and wasn't sold on the adhesive approach.
So we followed the instructions which appeared pretty simple.
1. Tar paper onto wall.
2. Metal lath.
3. Scratch coat (of mortar)
4. Apply stone
5. Profit.
Thats how it should have gone. Of course being a DIY job we ran into all sorts of problems. I waited till my dad was visiting from NZ and put him to work. I really couldn't have done it without his help, or at least support.
Step 1:
Remove old tile and wood trim. Easyish, just lots of banging.
http://i53.photobucket.com/albums/g5...6/DSC01662.jpg
Step 2:
Need to drop the harth by two inches because the new harth stone is way thicker than the old ceramic tile. This required lots of power tools and curse words.
Reinforced the harth and put the ply back on.
http://i53.photobucket.com/albums/g5...6/DSC01669.jpg
http://i53.photobucket.com/albums/g5...6/DSC01674.jpg
Found that there was nothing supporting the drywall behind the top of the fireplace so had to 'attach' some 2x4 in there and redo the drywall.
http://i53.photobucket.com/albums/g5...6/DSC01678.jpg
http://i53.photobucket.com/albums/g5...6/DSC01679.jpg
Step 3:
Tar paper up the wall. This didn't take too long. But was not fun being 14 feet up on the ladder with a roll of paper in one hand and a staple gun in the other. Thats when we went and bought a ladder stabilizer, so worth the money.
http://i53.photobucket.com/albums/g5...6/DSC01684.jpg
Step 4:
Lath. First we had to use a stud finder to find the studs and makr them up with chalk so we knew where to attach the lath. The lath would support the scratch coat so needed to be into the studs.
http://i53.photobucket.com/albums/g5...6/DSC01691.jpg
Step 5:
Scratch coat. This was my first time using mortar. Took longer than expected but wasn't too bad. A bit messy and again tough being up the ladder with a bucket and trying to apply the stuff.
Step 6:
Apply the stone. Started at the bottom and worked up as this technique had no grout. Was surprised how quickly the mortar on the stone attached to the scratch coat. We definitely learnt quickly. I wish though I could go back and re-do the bottom as my technique is much better now.
http://i53.photobucket.com/albums/g5...6/DSC01706.jpg
Step 7:
Harth stones. Pain in the ass. My tile saw blade wasn't thick enough to cut through the two inch think harth stones. So I had to go buy an angle grinder. Stones were heavy and hard to place and get even. They're not as even'level as I would like and one drives my wife crazy but I'm not pulling it off!
http://i53.photobucket.com/albums/g5...6/DSC01710.jpg
Step 8:
Continue stone up the wall.
http://i53.photobucket.com/albums/g5...6/DSC01717.jpg
Took way longer than anticipated. Ran into a number of problems along the way (to be expected?). Looks sweet! I now has skills!
Scuba_Dave 06-15-2009 01:30 PM
Very nice
Is that just a hidden storage area behind the painting?
specialguest 06-15-2009 01:35 PM
WTLW
http://forums.nasioc.com/forums/show...ight=fireplace
I'm SenorFartman over on the Subaru forums
Kiwi. 06-15-2009 02:44 PM
Originally Posted by Scuba_Dave (Post 287812)
Very nice
TV storage space. House was built in the 'old days' when TV's would actually fit in that space.
Kiwi. 06-15-2009 02:45 PM
Originally Posted by specialguest (Post 287814)
WTLW
Small world!
It doesn't count as cross-posting if its on a different website does it?
Ibarnes 06-15-2009 04:33 PM
The 'reason' there wasn't anything there, is you are supposed to have that much clearance above your unit.
Gary in WA 06-15-2009 07:09 PM
When you ripped the 2x6's to 2x4's, you should have added more blocking to support the 3/4" ply holding up the left corner by itself. Hint- don't let two people sit on the hearth side by side. Heatilator stove 250#, stone face front 200#, people 300#.
Ibarnes hit the nail on the head- that 2x was left out per manufacturer's instructions. Those stoves get hot! That's why the mantle- is so high above the outlet, and the shape of the mantle, and the distance it juts into room. The rough opening is the closest you can put combustibles. Which is above those holdup angle A's. They are there so you don't put any wood where you put it. Not sure which model you have- page 18, clearances:
http://www.heatilator.com/downloads/...s/4040-262.pdf Be safe, G
Leah Frances 06-15-2009 10:16 PM
Nice project. Nasioc? I'm a 2002 FXT - DH is WADEJG.
