Our Dream House - Project Showcase - Page 8 - DIY Chatroom Home Improvement Forum
Like Tree23Likes
Old 12-26-2011, 08:05 PM   #106
Rewards Points: 384
Somebody please shoot me!
I have no idea what my husband has been drinking but I think it pickled his brain.
He told me that there is no reason to mud and tape the drywall because we are going to have it textured. No idea where he thought up that idea.
Then tonight we got into an arguement.
He wants to hang the fiberglass insulation, then hang the drywall and says he will cut a hole big enough around the light fixtures so we can fit the tube for the Great Stuff up there to seal that off.
Told him that was not a good idea.
Hang drywall first, seal with Great Stuff and then insulation.
Got pretty heated and he stomped off.
logluvr is offline   Reply With Quote
Old 12-26-2011, 08:48 PM   #107
Old School
Willie T's Avatar
And you are in this venture "together"? Scary.
Willie T
Old 12-26-2011, 09:59 PM   #108
cocobolo's Avatar
Rewards Points: 5,624
Will there be a vapor barrier fitting in there somewhere?
Just an old guy messin' with bits of wood...and old cars!
...the friendliest thread on the site! Come on by.
cocobolo is offline   Reply With Quote
Old 12-26-2011, 11:11 PM   #109
Rewards Points: 384
No willie I don't think we are "together" in this.
cocobolo so far nothing yet. I was thinking of plastic between the drywall and the trusses.
Well he got the electrical finished tonight.
Old 12-26-2011, 11:16 PM   #110
cocobolo's Avatar
Your vapor barrier should be 6 mil poly on the warm side of all of your insulated areas, walls and ceilings.
Any T & G plywood you have is considered to qualify as a vapor barrier as well.
Old 12-26-2011, 11:49 PM   #111
Rewards Points: 384
Would the blue insulation board we used in the basement be considered a vapor barrier or should we go ahead and hang the poly?
Old 12-27-2011, 01:12 AM   #112
cocobolo's Avatar
Now that's a very good question.
If it is closed cell foam, and if you are able to seal between all the joints, then perhaps so. If it is open cell foam, then I would have my doubts.
I would take the word of the manufacturer over mine in this case and see what they say. If it were me, I would be putting the poly up in any event. It is easy, inexpensive and well proven.
Old 12-27-2011, 11:40 AM   #113
Rewards Points: 384
It is closed cell and is lined on both sides with a plastic film. We put it up in the basement before the fir out was done. Taped all the edges too.
Yes we were talking about hanging the poly before dry walling the upstairs ceiling. That ceiling is what caused the argument.
Trying to decide what to do with the basement ceiling. we need to access the space above because of the electrical junction boxes up there.
I do not want a suspended or dropped ceiling with the metal griders. I remember a neighbor kid hiding the whiskey and cans of chew up in there and decided I did not want to offer my kids the same thing.
found some 12" tiles by Armstrong on the internet. It showed that you hang these wooden slats across the ceiling trusses. Then you mark out the tiles and they can be stapled up there.
Any thoughts or ideas on a ceiling that can be removed for access?
Hubby wanted to take some gypsum board and cut it into 2'x2' and then use wooden slats to hold them to the ceiling. They wouldn't be screwed down.
I suggested drywalling the whole ceiling and cut out access panels where the boxes were and make it look like it was planned.
No agreement there yet.
Old 12-27-2011, 12:03 PM   #114
cocobolo's Avatar
If you want that ceiling accessible, why not use T-bar?
Old 12-27-2011, 01:13 PM   #115
Rewards Points: 384
I looked at it and it is still suspended. Our ceiling in the basement is 8'. I really don't want to lose and head space.
Old 12-31-2011, 07:51 PM   #116
Rewards Points: 384
Priced out some insulation yesterday. To do our attic in R-38 batted fiberglass would cost us around $4000.
To do the basement walls alone would be around $500.
Still waiting for the inspector. Once he gives us the ok I'm going to get the insulation for the basement and the hubby is going to start the plumbing.
Let's see if this works. The pot lights in the kitchen.
Old 12-31-2011, 08:21 PM   #117
cocobolo's Avatar
If you can get Roxul Insulation instead of fiberglass you will be far happier.
Old 12-31-2011, 09:47 PM   #118
Ironlight's Avatar
Why? Inquiring minds want to know.
Ironlight is offline   Reply With Quote
The Following User Says Thank You to Ironlight For This Useful Post:
logluvr (12-31-2011)
Old 01-01-2012, 12:06 AM   #119
Rewards Points: 384
Here is the link Ironlight.
http://www.roxul.com/home
Going to check out the cost of it because it needs to be special ordered at HD. Closest dealer is about 4 hours or more away from us.
I was in a different lumber yard yesterday just looking around and they had several mantle pieces around. I fell in love with this maple mantle that was actually the whole tree cut flat on each side. Talked with hubby and I would love to have that as the top piece on the breakfast bar in the kitchen.
Old 01-01-2012, 12:51 AM   #120
cocobolo's Avatar
As soon as you either see or handle Roxul you will know.
It has a higher R-value for the same thickness, about 10% higher.
It doesn't itch. It fills up your spaces properly. You can cut it with a bread knife to fit exactly around things like electrical boxes.
It is fireproof. Have you ever seen fiberglass after a fire?
There's simply nothing about f/g that is even remotely as good as Roxul.
My house's previous owner - DIY horror stories Leah Frances General DIY Discussions 153 01-21-2016 08:18 PM
Connecting main house to guest house... hlavine Building & Construction 31 03-28-2012 10:04 AM
replumbing an old house simonfrog Plumbing 7 01-30-2012 05:45 AM
Fixing weekend house staining that went awry jb888s Painting 10 08-17-2009 11:01 PM
I have Central Heating & Air, but house won't cool down..HELP!! exiledone1 HVAC 13 07-10-2009 11:09 PM
