Our Dream House - Project Showcase - Page 7 - DIY Chatroom Home Improvement Forum
Like Tree25Likes
Old 10-13-2011, 03:15 PM   #91
Rewards Points: 390
Finished staining the house today.
It was worth buying that airless painst sprayer. Took less then a day to get it done.
Hope the pics come up having trouble.
Northside
Southside
Eastside
Finishing the westside
Got a lead on a bucket truck. I got a roll of Tyvek house wrap. So that is the next project. Got the tape too and we are going to put up wood slats to hold it down until we get the gable ends covered.
Hope to finish out the electrical and get the plumbing started and hopefully done.
logluvr is offline   Reply With Quote
The Following User Says Thank You to logluvr For This Useful Post:
shumakerscott (10-14-2011)
Old 11-05-2011, 10:25 AM   #92
Rewards Points: 390
Hubby finished the lights yesterday and drilled the holes for the wall outlets. The only store that carries the outlet boxes we use in the logs only had 7 boxes and we needed 10. They are getting more on Tuesday.
We bought a large wood stove and it turns out that it was used to heat a 4000sqft house. Has an air intake pipe at the back and an outflow pipe right out of the bottom. It came with a blower.
Even funnier we got a call from a guy hubby knows telling us that we could have this other wood stove for free. We took both.
I started chinking between the logs inside. It is looking pretty neat.
Free stove
Old 11-05-2011, 11:39 AM   #93
Dorf dude...
shumakerscott's Avatar
Rewards Points: 1,190
Are you going to hook the stove up so it draws fresh outside air? I would highly recommend it dorf dude...
Today is only yesterdays tomorrow, Now get to work!
shumakerscott is offline   Reply With Quote
The Following User Says Thank You to shumakerscott For This Useful Post:
cocobolo (12-25-2011)
Old 11-05-2011, 12:57 PM   #94
Rewards Points: 390
Yes we are. Going to run the inflow vent through the pony wall. With the outflow we are going to run a vent into the basement.
Stove also has a couple vents on the front for the air to flow out too.
Ran out of chinking so my part of the house is stalled. Hubby wants to get the plumbing supplies first then I can get more chinking to finish out the house.
Old 11-05-2011, 02:07 PM   #95
Did you have a professional engineer design the foundation that is supporting the weight of the logs.
You mentioned house wrap over the osb, here is a fluid applied air and water barrier that I have used and it is great, much better than house wrap. It is good for 6 months exposed to the weather without compromising the warenty and it is water tight.
woodmeistro is offline   Reply With Quote
Old 11-05-2011, 05:42 PM   #96
DIY staff
Rewards Points: 7,174
I've been watching this---and really enjoy the progress----Keep us posted as things move along.---Mike---
Old 11-05-2011, 09:07 PM   #97
Rewards Points: 390
woodmeistro yes we did. Going to house wrap and put up some wood slats over it to keep the wind from ripping it off like the tar paper. Going to get the gable end vents and then the gable siding.
Thanks Mike.
Got a surprise this fall. One of our hunters is a carpenter and has offered us the use of his sheet rock lift and has offered to come out and help us mud and tape the walls.
Might have to talk to him about doing some bartering.
oh'mike (11-08-2011)
Old 11-08-2011, 03:28 PM   #98
Rewards Points: 390
Here is the framing for the breakfast bar. Going to have 4 outlets on it so this is just the start.
Son's bed collapsed on him last month. found a guy near us who makes log furniture.
Son's new bed.
The Following 4 Users Say Thank You to logluvr For This Useful Post:
BigJim (11-08-2011), oh'mike (11-08-2011), shumakerscott (11-08-2011), Thadius856 (11-12-2011)
Old 11-28-2011, 07:46 PM   #99
Rewards Points: 390
Got the chinking finished inside.
Outlet boxes drilled in the logs
Started running eletrical for the stove and wall ovens
Old 11-28-2011, 08:13 PM   #100
I'm Your Huckleberry
Rewards Points: 2,270
How are you feeding the electrical boxes tapped in the log wall? How is the wire getting to them?
I mean I've done plenty of residental and commerical electrical work (four years electrical apprentice) and I'm sure you know this already but we go in the wall, through the studs and come in the back or top or bottom of the boxes.
I don't see that happening with those.
Other than that inquiry, nice!
Doc Holliday is offline   Reply With Quote
Old 11-28-2011, 08:16 PM   #101
Thadius856's Avatar
Rewards Points: 504
Beautiful!
Check out my on-going Project Thread!
Current Project: Whole House Data Wiring
Back Burner: Drywall Patching
Planning: Kitchen Reno
Thadius856 is offline   Reply With Quote
Old 11-28-2011, 08:20 PM   #102
Disabled wood vet
titanoman's Avatar
Rewards Points: 1,004
I feel like I built the thing myself just reading this. Was there a question there somewhere?
titanoman is offline   Reply With Quote
Old 11-28-2011, 10:11 PM   #103
Rewards Points: 390
Doc the holes for the electrical wires for the boxes were drilled through the logs and into the floor when they were being stacked.
BigJim (11-29-2011)
Old 12-23-2011, 07:48 PM   #104
Rewards Points: 390
Hubby is seeing the light at the end of the tunnel, no pun intended.
Outlets are done. Breakfast bar and kitchen outlets are done along with the pot lights in the kitchen ceiling.
Got the vents for the bathrooms upstairs done too.
just need to wire in the vent for the kids bathroom.
Have 6 smoke alarms to get wired in too.
Last thing is to wire in the exterior outlets.
Then we call the inspector!
Had a couple of delays that were not needed or he would have had it done today.
He put the pot lights on a dimmer switch which looks great whjen we turn them on.
BigJim (12-23-2011)
Old 12-25-2011, 03:37 PM   #105
cocobolo's Avatar
Rewards Points: 6,114
That looks like a most excellent job on that chinking! Well done!
Merry Christmas!
Just an old guy messin' with bits of wood...and old cars!
...the friendliest thread on the site! Come on by.
cocobolo is offline   Reply With Quote
My house's previous owner - DIY horror stories Leah Frances General DIY Discussions 153 01-21-2016 07:18 PM
Connecting main house to guest house... hlavine Building & Construction 31 03-28-2012 09:04 AM
replumbing an old house simonfrog Plumbing 7 01-30-2012 04:45 AM
Fixing weekend house staining that went awry jb888s Painting 10 08-17-2009 10:01 PM
I have Central Heating & Air, but house won't cool down..HELP!! exiledone1 HVAC 13 07-10-2009 10:09 PM
