Go Back   DIY Chatroom - DIY Home Improvement Forum > DIY Repair > Project Showcase
Old 05-13-2009, 10:50 AM   #1
the Musigician
DangerMouse's Avatar
One Piece, Removable Casements (Solid Oak)
i needed to have my window casements easily removable for painting.
i believe this fits the bill!
only two screws show over the entire unit.
triple screw mounted on all four corners.
i've always hated seeing paint on casements/baseboards, so all of mine will be moveable. the pics show the unit in tight, and pulled out a couple of inches and rescrewed to keep it secure while painting. the screw can be seen in the picture about an inch from the window in the middle.
One Piece, Removable Casements (Solid Oak)-casement-.jpg   One Piece, Removable Casements (Solid Oak)-casement-out.jpg
[SIGPIC][/SIGPIC]Click
to see some of my original magic tricks and trick boxes!
Old 05-13-2009, 11:07 AM   #2
the Musigician
oops, i guess it'd be nice if i showed the whole thing, huh?
also, i guess i should mention these started as roughcut 14' 1"x12"s and i cut, sized and planed, etc. the whole mess from scratch.
DM
Old 05-13-2009, 11:22 AM   #3
Very cool idea. Nice execution of said idea. I like it.
It takes less time to do a thing right than it does to explain why you did it wrong.
-Henry Wadsworth Longfellow
beer_geek is offline   Reply With Quote
Old 05-13-2009, 07:38 PM   #4
Dorf dude...
shumakerscott's Avatar
Are you going to fly over and make mine? I have 2 that will kick your butt. They are arched, all the rest are square. I will deal with that when I get to them. Looks great! Dorf Dude...
Today is only yesterdays tomorrow, Now get to work!
shumakerscott is offline   Reply With Quote
Old 05-14-2009, 12:37 AM   #5
NICE! good idea. What kind of joinery did you use? Glue/finish nails, biscuits?
I have an entry door to finsish out. I think I am gonna give this a go.
What have I done is offline   Reply With Quote
Old 05-14-2009, 05:58 AM   #6
the Musigician
What Have I Done: i used wood glue along the side pieces and clamped. if i had a biscuit joiner though, i'd use it there.
the top and bottom trim is PL'd (construction adhesive) to the sill and top plates.
these are then screwed to the sides, (predrilled, countersunk, 3 screws on each corner)
....post pics of your door when you're finished!
defg673: this is not a thread to find out about material safety data sheets, please post in appropriate forum area.
DM
Old 05-14-2009, 12:38 PM   #7
jackie treehorn's Avatar
Very nice!!
jackie treehorn is offline   Reply With Quote
Old 05-14-2009, 08:00 PM   #8
[quote=DangerMouse;273515]What Have I Done:
Dang it! Now I got to get off my butt, trim out the door, and Post pics? I think I can I think I can! Maybe tomrrow!
Old 10-01-2010, 12:12 AM   #9
Great idea!
Barb
gma2rjc is offline   Reply With Quote
what solid stain is best? mpgumm Painting 28 03-19-2012 01:51 PM
Caulk underneath sink drain/plate? doogie88 Plumbing 14 04-16-2009 08:18 AM
Installing solid bamboo over concrete slab Hetuck Flooring 3 12-21-2008 03:01 PM
Building a Cabin on Solid Rock thatstaken2 Building & Construction 1 08-11-2008 09:28 PM
Removing single piece of siding shortagain Remodeling 4 01-02-2006 11:12 AM
