Old Outdoor Fireplace Rehab'd To A Firepit... - Project Showcase - Page 3 - DIY Chatroom Home Improvement Forum
Old 02-15-2012, 08:46 AM   #31
Rewards Points: 77
Looking very nice...on a side not, I love the doors to the workshop, they are nearly identical to my front door.
What does the bluestone sell for by the pallet?
Double is offline   Reply With Quote
Old 02-15-2012, 10:03 AM   #32
Rewards Points: 27
You may want to be more specific. PA bluestone can be specified many ways -- cut, stand-up, variegated, true blue, lilac, 1", 1.5", 2" thick, etc.
See, for example, this page:
http://paquarriedbluestone.com/productFlagstone.php
The upside down pallet shown in my picture earlier in this thread is a load of random size 1.5" thick stand-up bluestone. Cut stone pricing is higher. I live quite near the NE PA area, so bulk transportation of the stone from the quarry to the distribution point is less costly than say if you lived in TX.
But a rough cost for such as pallet FOB is about $200 -- note though that some stone places sell by the pallet, and other by weight. The pallet you see in my driveway was $250 "dropped off". If you have a truck and a way to offload the load at home, you can pick up pallets of bluestone at the distribution point for around $150-$175 pallet. Some companies also charge a pallet fee, which can be recovered by returning the empty pallets.
I will point out here that the installation effort (and therefore the final cost) of any random size flagstone installation (including PA bluestone) is entirely dependent on how tight you want the joints. You can go broke (by paying someone) and/or dead (from stone dust inhalation) trying to get 1/4" gaps on large areas of irregular flagstone. For this reason, if you want tight gaps and you are on a budget, you may want to use cut bluestone (square or ractangular shapes).
Otherwise I would suggest that you pick your battles. In my case I specified tight joints for the driveway apron, where aesthetically it looks more refined. But the rest of the bluestone on the property is "lay down" style -- you puzzle it until it "mostly fits" and don't worry about cutting lots of stone to make consistent joints. By the way, cutting the apron took 3 days and a bunch of diamond blades. I DO NOT SUGGEST DOING THIS YOURSELF as the stone dust is really, really bad for your lungs.
Wrooster
compare the above with...
wrooster is offline   Reply With Quote
The Following User Says Thank You to wrooster For This Useful Post:
<*(((>< (02-15-2012)
Old 02-15-2012, 11:03 AM   #33
Love for Construction
<*(((><'s Avatar
Wrooster, you held out on the first batch of pics regarding the apron!
Nice job on the apron, man that all looks schweet!
When's the BBQ, I'm there?
-luke-
<*(((>< is offline   Reply With Quote
Old 02-15-2012, 11:44 AM   #34
Rewards Points: 27
The title of this forum is "DIY" -- and the apron shown above is not "DIY" in the sense that i understand the term "DIY".
A good friend of mine is a mason, and he "has people". And if "those people" constructed the apron (including the ungodly task of cutting the stone to fit), and all I did was stand there, specify what the end result should be, say "looks good to me", and then write a check to cover the stone, labor and beer, well that is not DIY in my book. I have that full time job thing on the side, so I have to go to work every day -- although I would rather do DIY projects...
I will tell the mason.
I have met some folks with really nice classic cars, and they say proudly "I just finished this restoration, she's a beauty, ain't she!" -- and later you find out what they really meant is that they just wrote the last check to the shop that restored the vehicle from the axles up. Not to say that there is anything wrong with that particular approach, but at least tell it like it is.
Wrooster
Old 02-15-2012, 07:56 PM   #35
Rewards Points: 266
Are you still going to burn fires in the fireplace and put chairs in the pit area? Or are you going to have fires in that pit area and sit around the perimeter? In other words is that a firepit or a patio in front of the old fireplace?
Jim F is offline   Reply With Quote
Old 02-15-2012, 08:53 PM   #36
Rewards Points: 27
LoL, I never imagined building a fire the size of the firepit itself. The county and local fire departments would be here in minutes... they would probably call in an air drop unit to help out.
The fire goes in the fireplace, and people go in //and// on the firepit. The drystack walls for the firepit were sized (height-wise) to sit on.
Wrooster
Old 02-15-2012, 09:16 PM   #37
Rewards Points: 266
So then it's a patio, not a firepit or I guess you could even call it a really big hearth. That answers my question thanks.
Old 02-16-2012, 09:28 AM   #38
Rewards Points: 27
Yes, correct, it is a patio area suitable for chairs, a small table, or simply folks sitting on the stone wall. There *may* be alcohol involved at times.
n.b.
In no case, however, is any Real Wood burned in the fireplace. I made the "action picture" I posted above using Photoshop.
Wrooster
Old 02-16-2012, 10:01 AM   #39
Custom User Title
Rewards Points: 252
Lol, so life like! You should work in Hollywood doing special effects!
no1hustler is offline   Reply With Quote
Old 02-17-2012, 07:53 PM   #40
Rewards Points: 266
n.b.
Wrooster
So it's not functional then? It looks almost like a throne. You could sit there and hold court.
Old 02-17-2012, 09:10 PM   #41
Rewards Points: 27
Correct. I was warned earlier in this thread that burning wood in an open firepit creates pollution. As I subsequently pointed out, I have not been burning wood, but instead have been burning old tires, plastic bottles, and used motor oil. I hope everyone is happy now.
So everyone, please, just continue thinking that I am not responsible for screwing up the Earth's environment by burning actual wood in my firepit. Any pictures demonstrating otherwise are simply high tech simulations.
By the way, does anyone have any ideas on how to get rid of the stuff pictured below? It's everywhere...
Wrooster
Old 02-17-2012, 09:24 PM   #42
I guess you're going to have to haul it off to the dump. Don't forget that leaner. It looks dangerously close to smashing all that hard work.
I love your property
creeper is offline   Reply With Quote
Old 02-18-2012, 12:26 AM   #43
Rewards Points: 266
I missed all that I guess. It didn't seem to make much sense to build a fireplace and not burn wood. I am so not worried about the environmental impact of burning firewood in a backyard pit.
Old 02-18-2012, 05:58 AM   #44
Rewards Points: 27
Neither am I.
Wrooster
Old 03-22-2012, 04:54 PM   #45
Originally Posted by jasin View Post
I hope you use green (i.e. environmentally friendly) fire logs because burning regular wood straight up will create pollution.
see: http://www.apartmenttherapy.com/gree...roundup-135950
Does anyone have a spare fist to thrust straight up into my face?
Great job on your new space bro. It looks beast. The bomb.com . It's sweeter than Christmas morning. It's sweeter than Santa's chimney chow. It rocks not only my face, but every other part of my body off. Right off. It rocks more than a Quikrete factory.
Bk
btyking is offline   Reply With Quote
Firepit btu and gas line question wujohn HVAC 1 10-25-2011 12:42 PM
Using the right bricks for firepit? abbyqueue Landscaping & Lawn Care 2 08-16-2011 07:11 PM
Covering an inground firepit Kimb Landscaping & Lawn Care 1 05-14-2011 11:02 PM
how do I make a form for cement gas firepit cverdi2 Landscaping & Lawn Care 8 02-16-2011 09:01 PM
NG Firepit Problem jonzey General DIY Discussions 2 06-16-2009 12:17 PM
