New Porch/landing With Balusters & Rails. - Project Showcase - Page 4 - DIY Chatroom Home Improvement Forum
Old 08-14-2011, 09:23 AM   #46
DIY staff
Rewards Points: 7,174
Originally Posted by DangerMouse View Post
Then why the heck do they make the stupid things???
If I added 2x2's at the notches, that would give me noses on all the steps.
DM
In all my years of wood working I never had a stair case that worked with a store bought stringer.
I have no idea why they make them either.
As to the top step being to wide----add more nose to the deck???
Remove stairs and cut the inch off the back of the stringer???
To see if the stairs are good lay a straight edge onto the steps from the bottom to the deck---the straight edge should contact every nose including the deck nose.
Old 08-14-2011, 09:51 AM   #47
the Musigician
DangerMouse's Avatar
Here's how I decided to do it. Now they all have the "proper" 1" noses.
....and 1/4" gaps max I think too, keeping in mind the whole high heels thing.
DM
New porch/landing with balusters & rails.-steps2b.jpg
Old 08-14-2011, 09:58 AM   #48
kwikfishron's Avatar
Rewards Points: 832
That looks much better.
kwikfishron is online now   Reply With Quote
Old 08-14-2011, 10:00 AM   #49
the Musigician
I AM okay locking the newel post(s) to the second step edge like shown, right?
How far does the handrail have to extend past the top of the post?
DM
Old 08-14-2011, 10:04 AM   #50
DIY staff
Hand rail should extend past the post until it is above the first step nose.
Old 08-14-2011, 10:06 AM   #51
the Musigician
Thought so, thanks.
DM
Old 08-14-2011, 10:07 AM   #52
Rewards Points: 832
Your grab rail has to extend past the nosing of the first step and return back into the post. The front of the post should be out to the first riser and should be solid as a rock.
Old 08-14-2011, 10:11 AM   #53
Rewards Points: 558
DM
much better.
epson is offline   Reply With Quote
Old 08-14-2011, 10:11 AM   #54
the Musigician
So you're saying I need to move the 4x4 to the front edge of the stringer, and then still extend the 2x4 handrail further?
"return back to the post"?
DM
Old 08-14-2011, 10:13 AM   #55
Rewards Points: 558
DM
just move the post over...
Old 08-14-2011, 10:23 AM   #56
Rewards Points: 832
The handrail has to come past the nosing of the first step and then return into and be attached to the post.
How are you going to secure the post?
Old 08-14-2011, 10:33 AM   #57
the Musigician
Can you show me a picture of an example of this?
I intended to bolt the 4x4s to the stringer bottom with 6" carriage bolts.
I may need to go with the 'threaded rod the whole length' for 'rock solid' strength, we'll see.
So, I drill and set the 4x4 at this edge now?
Thanks for all the help guys!
DM
New porch/landing with balusters & rails.-steps2c.jpg
Old 08-14-2011, 10:36 AM   #58
Rewards Points: 558
should look like this
Old 08-14-2011, 10:41 AM   #59
Rewards Points: 832
That doesn’t cut it anymore down here epson, you must also have a grab rail.
Old 08-14-2011, 10:43 AM   #60
Rewards Points: 558
grab rail like this
Carpet before balusters? tompatrick Remodeling 9 04-26-2017 10:16 PM
building codes & Deck Rails with 3/4" aluminum spindles mroyten Building & Construction 8 09-20-2010 08:13 AM
Horizontal cable rails for decks ovahimba General DIY Discussions 4 07-29-2009 11:52 AM
Color opinion for front porch rails and pillars? Beth777 Painting 6 07-14-2008 11:14 AM
Wood Finish to Stair Rails propilot5000 Painting 1 01-09-2007 06:22 PM
