08-13-2011, 04:24 PM
#31
Moderator
New porch/landing with balusters & rails.
With closed risers it’s not required if the tread is at least 11” under, 11” it is.
A Picture Is Worth A Thousand Words Especially In The DIY Chatroom -NEW MEMBERS-
Please include your basic location in your profile. Some of the answers given are specific to a Region or State.
08-14-2011, 09:26 AM
#32
Super Moderator
Kwickfish or Jiju---(or any one with stair code knowledge)--His bottom step is short---will the inspection fail because of that?
08-14-2011, 09:31 AM
#33
the Musigician
No, the bottom step is fine, all steps are 7". I was just wondering if I could move the TOP step (all 3 stringers) up an inch, making the last step to the landing a 6" rise instead of 7". ...or do they ALL have to be 7", period?
Thanks again everyone!
DM
[SIGPIC][/SIGPIC]Click To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. to see some of my original magic tricks and trick boxes!
08-14-2011, 09:32 AM
#34
they all should be 7''
08-14-2011, 09:33 AM
#35
STAFF
If he lived here in Tennessee it would fail, the difference here is a max of 1/4 or 5/16 inch, 3/8 inch difference and you tear the stairs out. I don't know why I didn't think about that when he moved his stringer down.
New members: Please consider adding your location to your profile, it helps other members to give more accurate answers to your questions.
Jim
08-14-2011, 09:36 AM
#36
the Musigician
nononono, like I said, right now they're ALL exactly 7", but there's a one or two degree tilt.
No biggie, right?
DM
The Following User Says Thank You to DangerMouse For This Useful Post:
08-14-2011, 09:38 AM
#37
Super Moderator
Your inspector has a bug about you already---make the stairs the same----double check the tread width also.
08-14-2011, 09:39 AM
#38
the Musigician
To make it perfectly level, can I remove one more inch from the bottoms of the stringers, making the bottom step a 6" rise?
DM
#39
Super Moderator
The small 'tilt' should be acceptable.
08-14-2011, 09:40 AM
#40
the Musigician
The treads measure a perfect 36" X 11" all
DM
08-14-2011, 09:42 AM
#41
Moderator
Look at this DM
08-14-2011, 09:43 AM
#42
the Musigician
oops, except the top step, there's a 12" space from the landing header to the front of that step. Is that not good?
How would I fix THAT?
DM
08-14-2011, 09:46 AM
#43
Moderator
There is an exception to the nosing requirements. You don’t need the nosing it the tread is at least 11” deep.
It sure does look better with it though.
08-14-2011, 09:50 AM
#44
Moderator
This is exactly why pre-cut stringers rarely work.
08-14-2011, 09:56 AM
#45
the Musigician
Then why the heck do they make the stupid things???
If I added 2x2's at the notches, that would give me noses on all the steps.
DM
| Thread Tools |
Search this Thread |
| Display Modes |
Linear Mode
