Go Back   DIY Chatroom - DIY Home Improvement Forum > DIY Repair > Project Showcase
Old 08-13-2011, 07:31 AM   #16
Super Moderator
New porch/landing with balusters & rails.
Danger--I found a useful link for your bottom handrail post attachment.
Solid Newel Post For Floating Deck Stairs - Decks & Fencing - Contractor Talk
Old 08-13-2011, 10:02 AM   #17
Civil Engineer
You probably figured this out long ago, but the table for the LSU26 hanger on page 74 of the Simpson 2009 manual shows six (6) 10d nails and five (5) 10d 1-1/2 inch nails per hanger, not the 12 10d nails you listed in your post.
And I too had to add a 4x4 to the bottom of my framing to get the spacing correct for the stairs on my deck. I used the same hanger you did, by the way.
Old 08-13-2011, 10:16 AM   #18
the Musigician
DangerMouse's Avatar
Daniel, do you have the graphic you can show here? The pdf I downloaded from them has something totally different on page 74...?
The video showed 6 nails on each side of the stringer.
DM
[SIGPIC][/SIGPIC]Click
to see some of my original magic tricks and trick boxes!
Old 08-13-2011, 10:24 AM   #19
the Musigician
Landing cut to size today so far. 5 2x8s spaced at about 1/2" apart and the same from the house. Not screwed down yet.
DM
Old 08-13-2011, 12:25 PM   #20
the Musigician
Does anyone know what the max space allowed between deck planks is?
...or at least what the max recommended distance might be?
Thanks!
DM
Old 08-13-2011, 12:40 PM   #21
Super Moderator
Minimum for 2x stock is 1/8"-----The maximum???
Old 08-13-2011, 01:04 PM   #22
STAFF
BigJim's Avatar
DM, that 1/2 inch between the decking will open even wider as the boards dry, I always used a 12d nail as a spacer and the margin opened up wider later. You have a good strong deck that you won't have to worry about, that is for sure.
New members: Please consider adding your location to your profile, it helps other members to give more accurate answers to your questions.
Jim
BigJim is offline   Reply With Quote
Old 08-13-2011, 01:31 PM   #23
the Musigician
I imagine if it opens up to 1" even, it still wouldn't matter much, huh?
A baby couldn't fall in between the planks or anything, right?
DM
The Following User Says Thank You to DangerMouse For This Useful Post:
BigJim (08-13-2011)
Old 08-13-2011, 02:42 PM   #24
DM
No but wife can twist an ankle if she got her high heels caught in the gap.
epson is offline   Reply With Quote
Old 08-13-2011, 03:28 PM   #25
STAFF
BigJim's Avatar
Then she would put something on you Ajax wouldn't take off, called a bruise.
Jim
Old 08-13-2011, 03:29 PM   #26
the Musigician
Gee.... I'm glad no-one here wears them.
DM
Old 08-13-2011, 03:39 PM   #27
Moderator
kwikfishron's Avatar
If that’s pond dried treated yellow pine I wouldn’t space it at all. By the time it dries out you’ll end up with plenty of gap.
Overhang your first deck board an inch for a nosing same with the stair treads.
-NEW MEMBERS-
Please include your basic location in your profile. Some of the answers given are specific to a Region or State.
kwikfishron is online now   Reply With Quote
Old 08-13-2011, 03:57 PM   #28
the Musigician
Hmm... I don't have room for nosings, it just barely flushes out, even after ripping the 2x12s for a gap in the middles... this is odd. Picture in a minute then.
DM
Old 08-13-2011, 04:07 PM   #29
the Musigician
Okay, here's how I thought it should be. I did not want nosings to snag my toes on. It's not required to have them, is it?
DM
Old 08-13-2011, 04:16 PM   #30
DM
Not really required.
building codes & Deck Rails with 3/4" aluminum spindles mroyten Building & Construction 8 09-20-2010 09:13 AM
Carpet before balusters? tompatrick Remodeling 3 06-19-2010 11:31 PM
Horizontal cable rails for decks ovahimba General Discussion 4 07-29-2009 12:52 PM
Color opinion for front porch rails and pillars? Beth777 Painting 6 07-14-2008 12:14 PM
Wood Finish to Stair Rails propilot5000 Painting 1 01-09-2007 07:22 PM
