New Lattice Job - Project Showcase - DIY Chatroom Home Improvement Forum
Old 05-18-2009, 09:09 PM   #1
new lattice job
finally getting around to doing the lattice on the porch i rebuilt nearly a year ago now.
bought some 5/4X6 western red cedar, ripped each board into three 1 3/4" strips, then ripped those strips into two 7/16" thick strips.
all the sections required 2' of vertical strips, and varying horizontals.
since i don't own a staple gun, i decided to simply bang one screw at each end of each strip. i got half the porch done, with a bit of trim, in one full day. one section took a long time because of a severely bowed 2X4 framing member, and i had to shim every vertical piece.
i recessed the whole lattice unit to be in the same plane as the rough framing. the reason i did this is because when i rebuilt the porch, i shifted the 6X6 PT posts in 3/4" from the porch posts, so that when the trim was applied, the corners would line up nicely. i think it was worth it. this side bit obvioulsy awaits trim. it will be 1X8 on the top, 1X6 on the bottm, and 1X8 over the 6X6s.
painstaking... i wound up back oiling each piece as i went (penofin chestut). later i wound up back oiling a bunch before. i think just after this picture was taken, i wound up running a taught string from post to post, along the bottom, to get a reference line for keeping everything plumb and in the same plane.
i was delighted the way this trim slid tightly into my 30 scarf joint, which i left as the topmost stair kick about a year ago in anticipation of this exact moment.
the rest... and dang, my stairs are filthy after a heavy winter!
i was planning on hand turning a custom balustrade on my lathe, but now that the lattice is going in, i actually like my existing railing.
what do you guys think? here's a picture of the baluster i've been turning. so far i've only made 4:
thanks for reading.
wombosi is offline   Reply With Quote
Need tips on installing 4x8 vinyl lattice panels jaes Building & Construction 4 09-05-2011 12:21 PM
help finding nice oil or stain for western red cedar lattice wombosi Painting 1 05-02-2009 10:31 PM
diy lattice? wombosi Carpentry 4 10-10-2008 04:55 PM
Lattice on a slope mschmid Landscaping & Lawn Care 1 06-09-2008 11:03 AM
How do you paint PVC pipe or lattice? AndrewC Painting 4 05-10-2008 05:00 PM
