New House DIY - Project Showcase - Page 8 - DIY Chatroom Home Improvement Forum
Old 03-28-2009, 04:11 PM   #106
Mechanical Engineer
comp1911's Avatar
Rewards Points: 150
Got the landing done.
comp1911 is offline   Reply With Quote
Old 04-13-2009, 08:40 AM   #107
Mechanical Engineer
comp1911's Avatar
Rewards Points: 150
Stairway is done! Carpet is ordered and should be a go this week.
A gate to keep the dog down and the 18 mo kid up.
Old 05-26-2009, 01:35 PM   #108
Mechanical Engineer
comp1911's Avatar
Rewards Points: 150
I need to get some pics but just a quick update.
Basement bedrooms are now carpeted (not diy ) and I have got the basement familyroom cleanedout and ready for drywall. Again not diy, I've had enough drywall work for a while. The drywall guy wasn't busy and showed up right away this morning to start work.
Landscape work continues, I borrowed a skidsteer and am getting ready for the 540 yards of sod coming Saturday. We also prepped a playground area. I also started clearing off an area for another garage.
Old 05-26-2009, 04:30 PM   #109
Registered User
Rewards Points: 526
You have done a lot of work! Very inventive to install the spindles upside down, to attach the top of the handrail there. Question, did the Inspector pass the handrails like that? Very colorful walls. Be safe, G
Old 05-27-2009, 06:26 AM   #110
Mechanical Engineer
comp1911's Avatar
Rewards Points: 150
Rural area, no inspectors other then state electrical.
Old 06-01-2009, 08:21 PM   #111
Mechanical Engineer
comp1911's Avatar
Rewards Points: 150
540 yards of sod on Saturday. Helps to have some help, a semi to haul it and a big skidsteer to move it.
Old 06-01-2009, 08:24 PM   #112
Mechanical Engineer
comp1911's Avatar
Rewards Points: 150
Playground base
Finally, now
and 1 year ago
Old 06-01-2009, 08:29 PM   #113
Mechanical Engineer
comp1911's Avatar
Rewards Points: 150
Now the basement updates.
Kids toys moved into playroom, oldest is moved into his new room and guest room has been put to use for the sod crew.
Old 06-01-2009, 08:34 PM   #114
Mechanical Engineer
comp1911's Avatar
Rewards Points: 150
I had enough and subbed the drywall out in the big basement family room. That and I want it done so i can refi before the rates get any higher....
Old 06-01-2009, 11:25 PM   #115
Registered User
Rewards Points: 526
Looks like work. I was asking about inspections because your handrails need returns for safety, page 9, and your pickets' spacing may catch a child's head when your not looking, page 15.
http://www.stairways.org/pdf/2006%20...C%20SCREEN.pdf
This pertains to exterior decks and stairs, as well. This is minimum national code for safety. I have four boys of my own, 21-37 years old.
Be safe, G
Old 06-02-2009, 06:53 AM   #116
Mechanical Engineer
comp1911's Avatar
Rewards Points: 150
Be safe, G
Thanks for the link. Looks like I have some good winter projects.
Old 07-17-2009, 06:52 AM   #117
Mechanical Engineer
comp1911's Avatar
Rewards Points: 150
On the home stretch now. Basement family room is painted, floor is stained and installed the wetbar'ish counter. Just have to hang 2 doors and finish the trim!
Cape Cod Style House Attic/Crawl Space Insulation Help Danielg Insulation 24 05-21-2012 08:20 AM
replumbing an old house simonfrog Plumbing 7 01-30-2012 04:45 AM
200 Amp service really needed for a 830 sq ft house? overkill? alexz Electrical 7 11-16-2009 05:54 PM
Will my house make my kids sick??? jokrupinski General DIY Discussions 18 09-29-2006 04:05 AM
Brick and block house footer question. ourzoo Building & Construction 2 07-01-2006 02:57 PM
