New Garage Flooring - Project Showcase - DIY Chatroom Home Improvement Forum
Like Tree2Likes
  • 1 Post By Windows on Wash
  • 1 Post By Tony_G
Old 01-19-2017, 10:51 PM   #1
Tony_G's Avatar
Rewards Points: 48
New garage flooring
We went with porcelain tile.
Tony_G is offline   Reply With Quote
Old 01-20-2017, 06:57 AM   #2
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 5,274
Re: New garage flooring
Looks great. I am guessing you aren't doing much work with a floor jack or anything else that is even remotely impact sensitive?
78Vette likes this.
Old 01-20-2017, 11:45 AM   #3
Tony_G's Avatar
Rewards Points: 48
Thanks WoW,
From my research, some people have had porcelain tile in their garage for years. They do mechanic work, welding, there's even a video from a guy sledgehammering his CERAMIC tile garage floor, without issues. As long as they're properly installed, porcelain tiles should last forever. And even if some break, they can be replaced
Old 01-20-2017, 09:15 PM   #4
Rewards Points: 960
Looks great. I think these will become more and more popular. Please post a photo of how you handled the edge where it meets the driveway.
cleveman is offline   Reply With Quote
Old 01-20-2017, 11:24 PM   #5
Remodel and New Build GC
MTN REMODEL LLC's Avatar
Rewards Points: 3,392
I'm not sure how you use your garage... I too would be worried about impack type cracking....
What did you use for grout.... epoxy?
But, sure looks nice... (Hope my wife does not see a pic of your garage.)
Did you have any leveling issues....garage floors are often are wavy.
Good going
MTN REMODEL LLC is offline   Reply With Quote
Old 01-21-2017, 11:45 AM   #6
Tony_G's Avatar
Rewards Points: 48
We used a Schluter ramp
Old 01-21-2017, 11:56 AM   #7
Tony_G's Avatar
Rewards Points: 48
Good going
Thanks MTN, I did a ton of research. What I learned was that those who have used porcelain tile in their garage are very glad they did. Many of them do a lot of mechanic, welding and other types of jobs. As long as you back butter and get complete thinset coverage under the tile, you should be OK.
Check out this video:
We used regular grout, but sealed it twice. I'm not too worried about having to fix it at some point later on. We've used epoxy grout before and I didn't want to deal with the extra cleaning it requires.
This floor was pretty flat, not perfectly flat, but flat enough for me to decide not to fill up or grind down any spots.
MTN REMODEL LLC likes this.
Old 02-28-2017, 04:32 PM   #8
Rewards Points: 136
Thumbs up
Wow that looks fantastic!
donste2010 is offline   Reply With Quote
Old 02-28-2017, 05:27 PM   #9
Rewards Points: 960
Is the purpose of the ramp to prevent tiles from breaking as you drive up over the edge if there was no ramp?
I find it hard to believe that a car or truck tire would break the tile, but maybe I'm wrong.
Would a bullnose or a chamfer on the edge take care of it, or is a ramp absolutely necessary?
Old 02-28-2017, 05:56 PM   #10
Rewards Points: 3,740
Originally Posted by Tony_G View Post
Thanks WoW,
" video from a guy sledgehammering his CERAMIC tile garage floor, without issues. As long as they're properly installed, "
I'd like to see that video, can you post it?
Canarywood1 is online now   Reply With Quote
Old 02-28-2017, 06:02 PM   #11
ZTMAN's Avatar
Rewards Points: 480
I think that is what post 7 is
I don't mind spending money, I mind wasting money.
ZTMAN is online now   Reply With Quote
Old 02-28-2017, 06:07 PM   #12
Rewards Points: 140
You can see a chip flying on second 4!
Ceramic tiles on garages (it's common where I'm from) works very well and will not crack or break at all is the subfloor is good.
It will absolutely chip though if you hit with a hammer like the video or use a floor jack without some plywood for protection.
Other than that minimal care, it is easy to clean and looks spotless for a long time.
GASCo is offline   Reply With Quote
Old 04-13-2017, 10:17 AM   #13
Tony_G's Avatar
Rewards Points: 48
It is not absolutely necessary, I'm sure there are other options.
The ramp does make it easier if you are rolling heavy tool boxes or any other stuff in and out of the garage.
Old 04-13-2017, 10:43 AM   #14
Mike Milam's Avatar
Rewards Points: 234
Absolutely love the look and looks very well done. My worry (with mine at least) about cracks that occur from settling. I can envision needing to grind the floor along the crack lines too make it flat enough so as to keep the tiles level. After that, will slight movement then cause the tile to crack along the lines.
Mike Milam is offline   Reply With Quote
Installing 220 in garage for future welder - questions! wguttrid Electrical 7 01-31-2013 07:30 AM
Repr garage floor crks prior to epoxy/quartz flooring stadry Concrete, Stone & Masonry 0 11-26-2012 05:58 AM
Epoxy garage flooring BlueBSH Flooring 41 06-14-2011 09:11 AM
Allure flooring Dmadson Flooring 3 12-14-2009 01:00 PM
Garage ---> Rec-room flooring issues... jlatulippe Flooring 0 11-27-2009 09:30 AM
