My New Home Build - Project Showcase - Page 4 - DIY Chatroom Home Improvement Forum
Old 10-20-2013, 08:43 PM   #46
Rewards Points: 27
Movila 7" x 20" wood plank tile - bought them at the local bargain outlet. Each bundle had about 2-3 tiles that the ink machine must have been running out it appears. I think that is why the ended up in the outlet store.
bgibson11 is offline   Reply With Quote
The Following User Says Thank You to bgibson11 For This Useful Post:
123pugsy (10-21-2013)
Old 10-22-2013, 06:02 PM   #47
Rewards Points: 27
Ok guys.. Hardwood set to begin shortly.
Actually softwood and hardwood!
Putting wide plank pine flooring on the second floor and pioneer oak on the first floor.
What is everyone's thoughts? The wood has acclimated for the past 10 days and I'm putting down rosin paper on the second floor. Pine will start first. Wondering if I should run all boards perpendicular to floor joists or should I not be afraid to turn them parallel with the joists.
Also should I treat each room individually thus installing thresholds or shall I run the flooring clear through the interior door openings?
Old 10-24-2013, 02:34 PM   #48
Amateuralex's Avatar
Rewards Points: 270
I can't answer any of your questions except the threshholds, and only to say that every job i've seen installs them, including my house. It reduces the expansion/contraction.
I love how far you've come, the exterior is beautiful, can't wait to see your floors installed.
Amateuralex is offline   Reply With Quote
1938 TN Home - My First Home, My First project, Tons of Pictures!!! Firefighter3244 Project Showcase 78 07-01-2014 10:55 PM
How much more expensive is to build home from brick/steel/concrete instead of wood? Nuieve Building & Construction 10 12-11-2011 09:09 PM
Cost to subcontract modest home catbird Building & Construction 25 05-25-2009 07:38 PM
new home build jamienow78 Plumbing 10 05-22-2009 07:16 AM
