My New Home Build - Project Showcase - Page 2 - DIY Chatroom Home Improvement Forum
Old 04-29-2013, 08:59 AM   #16
Amateuralex's Avatar
Rewards Points: 270
Gorgeous land. This will be awesome to watch, thanks for making this thread.
Amateuralex is offline   Reply With Quote
Old 04-29-2013, 08:19 PM   #17
Rewards Points: 27
Some morning time rain drops didn't hinder the guys from returning to pour the walls. At first glance, there wasn't going to be a "pour" today but the rain quickly subsided and allowed the guys to get to the site. By 3pm or so the walls were poured.
I am starting my DIY tasks once these panels are removed. My friends/coworkers are going to give me a hand waterproofing the walls. I am using an unusual but effective way to waterproof the walls. I estimate my buddies and I need about 3 nights and a Saturday morning to do everything we need to do. Stay tuned for that.
In the meantime...
My new home build-img_2362.jpg   My new home build-img_2363.jpg   My new home build-img_2359.jpg   My new home build-img_2351.jpg
bgibson11 is offline   Reply With Quote
The Following 2 Users Say Thank You to bgibson11 For This Useful Post:
Amateuralex (05-01-2013), shumakerscott (04-30-2013)
Old 05-10-2013, 10:14 AM   #18
Custom User Title
Rewards Points: 252
Update! Update! Update!
no1hustler is offline   Reply With Quote
The Following User Says Thank You to no1hustler For This Useful Post:
Amateuralex (05-10-2013)
Old 05-10-2013, 10:58 AM   #19
Rewards Points: 1,442
Started out strong and then....
Hope you keep updating.
mikegp is offline   Reply With Quote
Old 05-13-2013, 08:18 PM   #20
Rewards Points: 27
Waterproofing/Insulation
OK guys. My apologies - been quite busy between this house and work!
Either way..
Panels removed...
I am really pleased with the looks of my contractors walls. Definitely "as advertised".
We poured 8" walls at a 9'0" height. I was originally going to go with 8 ft. walls but for the minimal added cost of the concrete we decided it was wise to go with 9'0". I do some hobby woodworking and the 9 ft. height will be nice. Plus I plan to use the basement for a place to store my tractor/snowblower and snowmobile.
On to the waterproofing/insulation..
Old 05-13-2013, 08:19 PM   #21
Rewards Points: 27
More wall pics
Here are some more pics of the walls.
Old 05-13-2013, 08:28 PM   #22
Rewards Points: 27
When it came to the waterproofing and insulation I had dreaming this up for quite sometime. Although I live in the Northern climate I firmly believe in thermal mass and taking advantage of it wherever possible.
As you will see in the photos below I went with a semi-standard waterproofing (Henry Blueskin) self adhered membrane. I liked this option much better than the typical mop-on tar "Dampproofing". With these walls exposed there was no way I was going to do the minimal "dampproofing".
I work in Estimating/Project Management for the contracting company I work for and I was able to garner a sweet deal from our supplier on the membrane. We install air barriers of all types on commercial buildings so the product is something we are familiar with. I mapped out at what height the grade was going to run on the wall and proceeded with the waterproofing install.
First we install a water-based primer to the wall and allow it to "tack-up". Once it tacks up we install the Blueskin directly to it being careful to keep from ripples/bubbles. It took me and my helper 2 evenings to complete the Blueskin.
Pictures to follow.
Old 05-13-2013, 08:32 PM   #23
Rewards Points: 27
Ok - all of a sudden can't upload pics. But I'll get them on ASAP.
Old 05-13-2013, 08:35 PM   #24
Rewards Points: 27
Some Blueskin photos
Old 05-13-2013, 08:42 PM   #25
Rewards Points: 27
After the Blueskin was complete I went around to insulate the top portion of the wall that will eventually be "above grade". Because the below grade portion will be insulated by another method - I wanted to use DOW board above grade as I plan to parge/stucco over the foam board afterwards to bring back the concrete appearance.
I read mixed reviews about foam board adhesives and fasteners for concrete but ultimately went with fasteners because I knew it was going to work.
I purchased some push-pin fasteners for the board and grabbed some clamps from my wood working shop.
I'd clamp the boards to the wall and pre-drill my holes with the hammer drill. I marked the 3" (inch) depth mark on my drill bit so I didn't over drill or use up to much of my own energy (LOL).
Once the hole was pre-drilled I inserted the push pin and tapped her home with the hammer.
When DIYchatroom allows I will post some more pics but it seems to have limited me for now.
Old 05-31-2013, 11:28 AM   #26
How's it going?
Old 05-31-2013, 05:17 PM   #27
Rewards Points: 27
Here are some pics of the progress
My new home build-image-3371447251.jpg   My new home build-image-4025322262.jpg   My new home build-image-1570695713.jpg
Old 05-31-2013, 05:18 PM   #28
Rewards Points: 27
First floor walls begin
My new home build-image-258129200.jpg   My new home build-image-2715645871.jpg   My new home build-image-4150921336.jpg
Old 05-31-2013, 05:21 PM   #29
Rewards Points: 27
Second floor walls begin
My new home build-image-2922576970.jpg   My new home build-image-1871539578.jpg   My new home build-image-3791876575.jpg   My new home build-image-1785670220.jpg
Old 05-31-2013, 06:16 PM   #30
MEASURE ONCE, CUT TWICE
123pugsy's Avatar
Rewards Points: 736
Looking good.
Thanks for the update
Pugsy.....my project: Total House Rebuild Bungalow to Two Story
123pugsy is online now   Reply With Quote
1938 TN Home - My First Home, My First project, Tons of Pictures!!! Firefighter3244 Project Showcase 78 07-01-2014 11:55 PM
How much more expensive is to build home from brick/steel/concrete instead of wood? Nuieve Building & Construction 10 12-11-2011 10:09 PM
Cost to subcontract modest home catbird Building & Construction 25 05-25-2009 08:38 PM
new home build jamienow78 Plumbing 10 05-22-2009 08:16 AM
