My Kitchen Reno - Complete Remodel (with Concrete Countertop) - Project Showcase - Page 19 - DIY Chatroom Home Improvement Forum
Old 10-04-2010, 09:36 AM   #271
Concrete counter-top
Something I have thought of doing
But not sure I wanted to tackle it
Plus the weight
I wonder the weight VS granite ?
BGGRNTXS is offline   Reply With Quote
Old 10-04-2010, 10:42 AM   #272
Prince George, BC
Concrete is only 88% the weight of granite...
http://lmgtfy.com/?q=concrete+weight...ite+weight&l=1
MisterPG is offline   Reply With Quote
Old 10-05-2010, 09:55 PM   #273
Well that is interesting to know
I was sort of ruling out concrete because of the weight
...not to mention the amount of work
I am thinking about concrete for my outside bar
Old 10-09-2010, 09:53 PM   #274
Knucklez's Avatar
Rewards Points: 942
it may be lighter .. but it is at least two times as thick. believe me, i just had a piece that was maybe 3'x4'x2" and it was EXTREMELY heavy. 3 guys could barely .. i mean BARELY .. move it. it was slow slow going.
but a lot of the problem was that we had no way of getting a grip on it. i was too afraid to lie it flat and carry it like a table top because i didn't want it to snap in half (probably would have been fine, but didn't want to chance it). so i flipped it on its side and then realized nobody could get a grip on it to lift. ..
but now i see at home depot they sell "gorilla grip" which is used to move sheets of plywood around like this. probably would work great for concrete countertop.
"if you can't be handsome, at least you can be handy" -Redgreen
Knucklez is offline   Reply With Quote
Old 10-09-2010, 09:58 PM   #275
I think I'd build/pour it right next to the bar
Then just flip it over onto the bar to finish it
But the bar is 3' x 10' long....that would be heavy
Was the bottom perfectly flat ?
Did you set it in thinset or something ?
The bar has a flat top...I was thinking thinset would allow it to settle in...& provide support
Old 10-11-2010, 02:10 AM   #276
i just wanted to say thanks for sharing your epic journey with all of us. i just found this thread in a google search on concrete counter tops and am glad i read it!
Hunedo is offline   Reply With Quote
Old 10-11-2010, 09:05 AM   #277
Custom User Title
Rewards Points: 252
3x10x2" you are looking at about 800 lbs. Good luck.
no1hustler is offline   Reply With Quote
Old 10-11-2010, 09:28 AM   #278
Yeah...I could do it in 2 or 3 sections
That would help prevent cracking on such a long piece
Plus make the size manageable
Old 10-12-2010, 12:24 PM   #279
Prince George, BC
Originally Posted by Knucklez View Post
...but now i see at home depot they sell "gorilla grip" which is used to move sheets of plywood around like this. probably would work great for concrete countertop.
FYI, I googled this little gem... Looks like it has a dimension capacity of 1-1/8-inc. I've emailed the company for weight capacity.
~m
Old 10-12-2010, 06:59 PM   #280
One thing I am curiuos about
If I were to make mine in 3 sections
Could I re-use the same mold 3 times ?
Old 10-12-2010, 07:52 PM   #281
Knucklez's Avatar
Rewards Points: 942
re-use the mold? probably most of it. i found that the side walls got pretty damaged when trying to remove the concrete from the mold. but the bottom of the mold (the large piece of melamine) was fine, maybe just needed to be wiped clean.
some pros speak of a "release agent" for concrete molds because they MUST to re-use them for production.
Knucklez
Old 10-12-2010, 08:03 PM   #282
I will look into the release stuff
I wouldn't mind just building one form
Old 10-12-2010, 08:43 PM   #283
jlhaslip's Avatar
Rewards Points: 2,864
Dave,
Your outside bar top can be formed and poured in place. No need to carry it.
And be sure to put in a drip edge...
Short of cutting off a body part, the worst that can happen in woodworking is manufacturing really nice looking kindling. --- Quoted from lenaitch
jlhaslip is online now   Reply With Quote
Old 10-12-2010, 08:56 PM   #284
I've always heard (thought) you had to flip them over to get the smooth finish for the top ?
Old 10-13-2010, 06:53 PM   #285
Knucklez's Avatar
Rewards Points: 942
no matter how good you or a hired pro is, the finished product will never be as smooth as what a mold can do.
however, in your case.. being an outdoor bbq table and super huge.. i would consider pour in place method.
Knucklez
The Following User Says Thank You to Knucklez For This Useful Post:
Scuba_Dave (10-13-2010)
Tags
back splash , concrete , counter , kitchen
Sleeve options for plumbing through concrete? Bruce L Plumbing 6 06-14-2008 09:38 AM
new concrete floor next to old concrete floor mattroos Building & Construction 10 08-28-2007 01:32 PM
My Kitchen Floor-Problems!!! Please Help!!! Fat b Flooring 3 01-25-2007 03:21 PM
Hardwood in kitchen over concrete slab Markvonjinn Flooring 12 05-09-2006 09:37 AM
Need to expand existing concrete pad for A/C unit miketegra Building & Construction 2 07-03-2005 10:27 PM
