ok.. so i couldn't wait any longer on the old kitchen. water damage was getting too much, so i had to stop other projects and start this one.. and unfortunately its a kitchen, so this is painful.. so please be kind
who ever knew this old house needed so much repair? i didn't.. but really, has been a joy to fix. just stressful at times. not to mention depressing when you have to turn down fun events with friends/family so you can "reno the house" all the time.. ho hum..
so onto the kitchen.. the highlight of this kitchen is the concrete counter tops we're going to put in. i'll be documenting that progress AS IT HAPPENS so we'll both see how it turns out at the same time .. to quick link to the Concrete Countertops section CLICK HERE
the nice thing about concrete is that its not that expensive, so if it dosen't turn out - just smash it with a a sledge hammer, bury it in the back yard and pretend it never happened.
thx jiju1943, that's very kind of you. but my wife has already removed the trim i put on (she decided on a different design she likes more) and has decided to go ahead and re-prime and paint. so she has already done most of the work. all i have to do is cut some trim and glue it to the doors (i like glue here cause makes a seamless finish). she will do everything else.
keeps her busy..
in the mean time, i just finished re-eavestroughing the entire house. up on a 30ft boom.. kinda scary when it sways in the wind!
ps. the boom was for the installed decorative molding that was far away hard to reach by ladder.. but since it was here decided to do the eaves as well.
some 11 years later... sadly all the pictures of this thread are gone. boo.. anyway i decided to replace bridge faucet with a single pull down faucet. meant i have to core out a center hole. it was really hard to do... really.
in 11 years i have never put any polish on the surface.. and it still looks like it did day of install.
HINT: make 3 holes in your concrete countertop so you have some options! coring after the fact sucks.
went downstairs to turn off the water - a necessary early step. as i twisted valve closed it started to leak.
i hate these old valves.. i've replaced everyone one in my house that has leaked - which as been everyone that i had to turn off. i suppose i could just re-pack the valve, but i hate these valves. i like those 1/4 turn ball valves, they seem much higher quality.
in any case, the plumbing goes from this valve to a galvenized pipe that runs THROUGH the stairs.. then through a crawl space and up to the main floor kitchen. how rediculous is this? same with the galvenized drain..
you literally almost step on the plumbing walking down to the basement!
oh.. did i mention there is no vent? ya...its on the "to do" list
here's a pic of the countertops before the work really got started.
honestly, they were probably fairly high quality/expensive 20 years ago. they are melamine and chip-board, so not the highest quality, but still pretty nice. i'd like to replace them completely but that would be cost prohibitive.. so our plan is to paint them and add trim (wife's job). maybe after we win the lotto we'll upgrade to solid oak.
a little bit of bleach in a spray bottle and steel wool should take care of that.
unfortunately its gunna get worse before it gets better.. much worse.
here is the plumbing. notice the bulging cabinets? that's from water damage. also more mold.. ok, to be honest, i knew the water damage under the sink was there for a while. but it was lower on the priority list.. but now it is gone as you'll see in the up coming pics.
i'm not sure if my wife is happy that its now gone, or that she's pissed that i didn't do this sooner. ho hum... as a famous canadian says "if they can't find you handsome, at least they can find you handy". i guess i'm really in trouble.. cause he never did give a 3rd option.
the blue styrofoam, no idea who put that there. was there since we moved in. it gets cold under there in the winter, maybe someone thought they would try to insulate with some lose piece of styrofoam without any tuct tape or anything.
now the sink and cabinets are gone. i'll have to rebuild them later with new material. the cabinet on the left there is going to stay, but i can see down at the bottom the wood box that the cabinet sits on is swollen. it must have seen some water too.. i'll have to remove it and see how much i can save.
the cabinet that used to be just to the right under the red bucket (future DW location) has been removed for cleanup purposes. its in decent condition (actually you can just see the corner of it in the bottom left side of the picture below). i am thinking of tucking the dishwasher in this cabinet. i'll have to see if it fits.. will get back to you on that.
see the galvanized drain? also to the right is the water supply, which is galvanized with a copper threaded pipe. there was no shut off valve here, it was located in the basement. in anycase, i cut out all the copper so the pipes stick straight up. this made it easier to remove the bottom of the cabinet.
looks like there is some water damage on the pine plank subfloor (even below the 1/4 chipboard subfloor).
there was a time when we were thinking of just paining the wooden floor. but i dunno.. this chipboard is not the greatest. its thin and in really rough shape. not sure if it will look good, even with 14 coats of white primer.
i'll have to talk to the wife about a floor replacement job. maybe if i pull the rest of the cabinets off the wall, i can quickly lay down some "paint grade" plywood? 3/4" thick?
what do you think, good idea? bad idea?
-off to bed now.. will post more in a couple of days. look'n forward to your comments
as it happens my wife got very sick over the last few days and was at the hostiptal and all that jazz. the nurse comes to the house for a status checkup and says that i need to boil these instruments on the stove for 15 minutes to sterilize.. i'm thinking.. crap.. i don't have a kitchen, never mind a stove!
so i bought me a hot plate from wallmart, nice GE double burner, and bob's your uncle. wife is all better now, and we can use the double burner to keep the food warm while hosting thanksgiving - with the food we make in our new kitchen! :thumbup:
so i notice some cabinets have water damage and some flooring..
the floor i have decided will need a good inspection. the chipboard is going to be thrown out.
looks like 3" wide tongue & grove pine under it..
i removed all the cabinets from the wall. this was harder than it looks because the 4" screws are monsters and the roberson heads where getting stripped. i ended up getting all of the screws up (after much effort!) except one which was too far gone to work with a screw driver. i tried to cut it out but just couldn't get the sawsall in there.
here is what i found in the corner written on the floor.
yes that's right.. there is an electrical wire running just under the floor. so they made a note, which was kind of them, to inform everyone not to put any nails here.
yup.. this is going to be removed and done right. might as well upgrade to GFCI while i'm thinking of it.
i moved the cabinets (except the corner one which was too large to get out the door) outside under the car port. they are sitting on planks of wood. ontop the wood i put some tarps. then i put the cabinets on the tarp. and then folded the tarps up and taped them in place. then i draped a monster tarp over the top. wrapped it in string to hold the tarp and weighed it down with some logs.
ps. that's the old counter top leaning up against the fencing..
pss. dad.. if you're reading this post and you want your tarp back.. sorry.. its in use now..
I hate to add more to your plate, but since you have everything ripped apart, what about doing a copper repipe? It pains me to see that copper/galvanized connection. Looks like it is a direct copper to galvanized with no dielectric union. Bad. I am suprised it isn't more corroded.
We moved into a house 4 years ago that was turn key beautiful. The previous owners did an incredible remodel with lots of quality workmanship. But they didn't update the plumbing. Long story short, we had major leaking that caused a lot of damage and had to do a complete copper repipe. The house was beautiful on the outside, but very ugly on the inside. We are getting the house back into shape, but it has been a long process and probably will continue to be.
I look forward to seeing your progress and glad to hear that your wife is feeling better.
thx for the kind words, and your point is well made. the plumbing stuff is all coming out. this will be a pain in the a$$ because under the kitchen is a smelly crawl space (to be fixed in a future project). but, got to run the new wiring for the DW in that area anyway... so might as well bring some copper with me.
i have a sink and a dishwasher in this kitchen.
from the sink, looking down the drain, the order of connection of things would be as seen below
all plumbing of drain is 2" ABS and vent 1.5" black ABS. i chose ABS because the rest of the house is done with ABS.
the drain line runs back to the main 4" ABS drain in the house in the basement. the main 4" waste line is some 20 ft. away from the kitchen! so i will slope the 2" kitchen drain at 1/4 per foot, for a total slope of 5" (round up to 6"). when i get close to the 4" drain, i will use 2 x 45 (or a "long 90")to angle the 2" kitchen drain so it can connect with the 4" main waste which is below the kitchen drain.
tapping into the main house drain involves a 4" four-banded rubber clamp, and a 4"x2"x4" WYE to connect with kitchen drain (see picture below)
here's a picture of the funky 1950's flooring.. oh, and see top right corner? they weren't kidding about the electrical under the chipboard subfloor... this wire must have been crushed good by the cabinets near the walls.
i can understand why they did this though. accessing the wall from the crawlspace is near impossible because the wall sits in the middle of a 18" thick stone foundation wall. and access from the top would be through the attic, but there is no attic access hole.. only other option is to run the wire along the ceiling, or floor. looks like they chose floor. doubt very much this is to code.. will have to be fixed.
this is cool... found a trap door. must have been for the original kitchen addition build. there must have been no access from the basement (there is a tiny hole now where the furnace has room for ducting).
also confirmed that the joists are 1.5" wide by 10" deep, spaning 12ft. should hold weight of concrete counter. wall foundation is stone, about 18". thick. in all, the concrete countertops (which weigh about 400lbs when done!) will have its weight distributed over a stone foundation and two joists along the wall with the window. along the other wall it will span over the same stone foundation plus many joists. in both cases, i believe there to be sufficient floor strength to carry the weight.
this will come in handy for access crawl space to do wiring and plumbing. :yes:
It's not the "end of the World". Do your research and educate yourself.
(Example: It takes alot of asbestos, over a long period of regular exposure to cause serious health issues. I am not saying that you should thro caution "to the wind", just that, if you did disturb some material, then learn what to do, to properly get rid of the rest of it.)
2 months ago, I tore out the 2nd floor (asbestos tiles) in my new (to me) 1930's farm house. EPA allows you, as a home owner to do your own removal. They ask that you follow the safety guidelines, especially, if it is exterior siding material.
(Just so you know; it's the Commercial, Public, & Multi-Resident Properties, that fall under a different "jurisdiction" and specific licensing, qualifications, checks, inspections, protocol, etc.....in terms of requirements for removal and control)
I don't know for a fact it's asbestos. I just know that alot of asbestos was used for decades in everything from plaster, floor glue, lineoleum, vinyl tiles, insulation and siding so the probability that your tiles are made of asbestos would be high. You can get these things tested very easily by sending them to a lab thru the use of a home testing kit.
thanks peeps, i'm not panicking. actually i was (briefly) trained in asbestos abaitment years ago. i just didn't know it was in floor tile.. all i ever saw was asbestos insulation around piping and also some flange gaskets.
agreed that labs can test, but i don't want to wait. i'll just assume that it IS asbestos and proceed accordingly. i think you might be right after doing some google research. this kitchen was remodeled in the 50's or 60's (based on galvenized plumbing and decore evidence). that was just at the peak of asbestos popularity...
anyway no worries here.. but removal of the felt will be a bit tough.. need to use water based product as sanding is definately a BAD idea.
how about removing felt with paint stripper?
Related Threads
DIY Home Improvement Forum
3.1M posts
319.6K members
Since 2003
